JSGerson
Everything posted by JSGerson
  1. Ken Forman is always a wealth of experience and knowledge. Jon
  2. You got the brass bands real snug to the mast without any voids and they look great. Any particular method to accomplish that? My first thought when I saw the pictures before I read the post was that you sliced up a brass tube, but you obviously didn't do that. Well done!! Jon
  3. A single wire around the the deadeye should work perfectly fine. No one will aware what is stropping the deadeye or notice, much less know, that it is not a double wire like the real ship. There will be a whole more interesting things to look at on the model when you are done. You are making a model, not a miniature replica. You've got s good design for your deadeye to strap connection. They will be very pretty when done. Jon
  4. I agree with you that 0.6 mm or 0.7 mm wire would provide better results and would be easier to work with. Jon.
  5. Marcus,K.: I took another look at 35208 and you are correct, it is "risers." I stand corrected.🤔
  6. From what I surmised from the images Ken provided, he did not attached the deadeyes to the chain plates. He twisted the wires stropping the deadeyes creating a tail which was then inserted into the channel. The chain plates were laid on top of the tails and extended to the hull. The "joint" was eventually covered over by the channel cap hiding the false connection. A little bit of modeler's sleight of hand.
  7. I read it the same way but made some minor corrections (typos, different interpretation of words, & omissions) in red. Note the term "viz." means "in other words" (I had to look that up). This plan has been drawn as a matter of record and comparison with Navy Yard Boston Midship Section Plan No 34526 BU C.S.A No 130241 which has been approved by that bureau subject to checking and revision to bring it in accord with additional data as may come to the attention of the commandant before any work is authorized and or started. Plan A ?? per original specification is not to be strictly followed in reconstruction. Some features will however be incorporated viz.: height of main hatch coamings, diagonal risers chamfering edges of wales and black strakes installation of third strakes etc. Whether this helps or not, 🫤 I don't know.
  8. I'm surprised that the MS plans don't provide plans for these parts. I copied what was provided in the kit with a centimeter scale for your convenience. Jon
  9. I sent these images to Mustafa as well. It shows what the actual connections look like to help guide you. In my opinion, your idea should work better if you use the stronger boxwood for the channels instead of basswood. Jon
  10. The MS plans are based on the 1927-31 renovation with some more recent details scattered about. What makes this renovation unique is that it added the top gallant rail, which has since been removed in more recent renovations. I checked Marguardt's AOS book on the USS Constitution and the 1812 configuration. Surprisingly, it showed no sheaves. Sheaves did appear in later configurations of the hull that he presented. As an aside, I can't believe/understand why sheaves would be on the gun deck. You're in the midst of battle, the command is to move the sails. You are going to have run down a ladder to another deck to pull on ropes and get your subsequent commands relayed to you through one or more people with the noise of a battle in a confined space? Doesn't make sense to me. To be sure, I would DM MrBlueJacket for clarification/explanation. He will respond to you. Jon
  11. I feel like I have built up an unwarranted reputation. Yes, I have amassed a wealth of pictures and plans, but I am no expert. When it comes to interpreting historical designs, I am a babe in the woods. I wish I could help, but the USS Constitution is an enigma and full of contradictions. I have yet to see a full set of plans for just one era. What I have reminds me of that old Johnny Cash song about building a car one piece at a time with parts from different years. That what I have, plans from different eras but not one complete set. Sorry I'm not more helpful Jon
  12. I got curious by your statement, "Both sheaves are at gun deck level..." According to Model Shipway's plans (see attached) , there are 4 (1927 version) sheaves per side in the spar deck bulwarks, not the gun deck. I believe you misspoked. The question as whether to include them or not to me at least, is a question of scale. At 1:96 they will disappear as they are black on black and very small. If it is a question of accuracy, yes I would put them in, just by drilling a couple of holes and a groove between them to simulate the sheaves. The sheaves are there whether or not the ship is rigged for sails; it's part of the hull. The same argument could be made about the bow and stern boomkins. They are used only for the sail rigging. My model won't have sails, but I have added boomkins to the bow so far in my build. This is only my opinion, I like detail. It is what separates one model from another. I hope this helps Jon
  13. Now that you point it out, I checked my pictures of the actual ship and those caps are made of copper. I hadn't paid much attention since I'm not working on fabricating those yet. I can buy a Uxcell 1Pack Copper Flat Bar, 5/32" T x 3/8" W x 10" L Copper Bar from Walmart. Hopefully, I should be able to slice that up that softer metal easier than the brass. Jon
  14. I painted the small connector blocks on the brass railings which are barely visible. The caps are larger, more prominent, so yeah, I would like to use brass. We'll see when the time comes. As for buying major modeling equipment, I don't think so. I figure I've got a couple more years on the Conny and most of the woodwork is done save for the masts and yards. I turn 79 this November, so I will be in my 80's by the time I'm finished with her. I'll probably start thinking about reducing the stuff I accumulated over the years. Jon
  15. Your fife rails look great. I don't have a milling machine so I'll have to work out another method to fabricate the brass caps. Off the top of my head, I suppose I could buy a 5/32" (I think that's the proper dimension) square brass bar and slice off 1/32" pieces, like cutting a loaf of bread, to make my caps. Worst case, I could just paint the wood tops brass color. Time will tell. Jon
  16. I always like to share the photos I've collected over the years. Jon
  17. Mustafa, I saw your request for channel images. While we wait for Gregg's photos, here are some of the images I have that may help you. Jon
  18. One of the hardest areas to photograph is the seat-of-ease location because the public is not allowed to go through the bow access ports. I have just 4 or 5 images with just partial glimpses of the bowsprit and the seats in that area. An ideal shot would be from one of steps on the bowsprit looking aft, downward into the bow. If you can get one of the museum employees or Navy men/women posted on the ship to use your camera to go into that area and photograph anything and everything, from all angles they can, that may help a lot of future model builders. When I was there back in November 2014, I thought of that too late and my available time was running out. And now, since the 2015-17 restoration, the bow topgallant rail has been removed, so there are even less current images available. Enjoy your trip. Jon
  19. Excellent workmanship. I would expect nothing less from you! Mine should look half as good as your by the time I get that point. Jon
  20. Beautiful pieces or work! What method did you use to add the brass caps on the posts? Jon
  21. Drill a round hole in to vertical bitt no wider than the width of the horizontal post. Cut two pieces of square stock to the length that will exposed horizontally plus an addition length that will fit into the drilled hole. Round off one end of the horizontal post so it fits into the hole. Do the same for the other side. Thus you have a square peg in a round hole and it looks like it passes completely through. Jon
