72Nova
Everything posted by 72Nova
  1. I made up the fore and main stays minus the mouse, mocked them up and I think they'll suffice, the main stay at scale is just under 5.5" in diameter and the fore stay is just over 4.5" at scale and looks about right next to the scale figure. The pendant of tackles are completed using .35mm line served with 100 wt thread and 3mm single blocks, long-tackle blocks where in use from 1733 to around 1773 in the aft pair. Test fitting revealed the main top gallant stay did have enough clearance to pass behind the stay and pendants, so I had to open up the cutout in the top just a bit. Michael D.
  2. I made up the main stay collar using .63mm line served with 100wt thread, the main stay will be .76mm line, these are just slightly undersized, but not noticeable to the eye, this was done before setting the lower fore mast as it was easier to seize the dead eye in the bight, I also rigged the parrel tackle prior, up next will be rigging the lower fore stay using .63mm line while setting in the lower main mast along with setting up the shrouds, all in all, this old tiny vintage model is looking fairly convincing for what it is, thanks for looking. Michael D.
  3. Exquisite work!!. What's the finished length going to be, 40 plus inches? Michael D
  4. The parral is completed using 0.5mm thick styrene for the ribs and 1.0mm rod for the trucks, I did consider doing something different and forming the trucks out of sculpy clay but settled on my usual method at this scale. the parral measures out just under 5mm in height. I did strop the jeer block to the yard using a 3mm single block, 24" at scale. Thanks for looking as always. Michael D.
  5. I was hoping to use the kit supplied fore course yard, but it is far too short as you can see, new one measures out to approximately 6-1/8", at scale is 86', mocking up the top rope I forgot early on when rigging the hallaird for the tie, the deception looks pretty good, up next I'll be fabricating the parral. Michael D.
  6. The timberheads on the portside waste railing are finally competed, along with gluing in the bitts and knightheads, also rigged up the main topmast stay tackle and falls, I was a little concerned with the tight space between the mast and bitts, but the 2mm single block fit nicely. Michael D.
  7. The link on rigging techniques by Mr. Dressel and his beautiful model I've had for a while and refer to it often, my rigging will be based on a combination of James Lee's, RC Anderson and John McKay mainly for the construction of the masts and more detailed illustrations of the rigging, like everything else they all have their varying differences and can be quite vague at times, and one needs to interpret that in a logical way. A few examples: bow sprit shrouds, Don mentions they weren't in use until around 1702, but Paynes engraving clearly shows them, yet Lee's and Anderson never mentions them, also in Paynes engraving all the running rigging runs down the bowsprit terminating in the beakhead area instead of running thru gammoning blocks and up to the fore castle/beakhead rails, what would they be belaying to? It's a fact that the Vasa had belaying pins in this area and seems quite logical to me that SOTS had them, again based on Paynes engraving. Regarding the jeers, I've read of no instances of them being rigged on the upper yards, course yards on early bigger ships perhaps used two jeers with 3 single blocks, this the route I'll be taking. The picture you posted from Andersons showing the early English jeers can be confused for a trestle tree, but I interpret it as the floor of the lower top. This is all good stuff and appreciate you taking the time to look and comment and I love the work you're doing on your SOTS. Michael D.
  8. The colors are striking on this fabulous build. Michael D.
  9. I have completed the timberheads on the starboard main deck railing along with the main bitts, knighthead for the tie and the 3mm single blocks stropped to the base of the mast for the jeers, these are slightly under scale, but look good, this would date the rigging around 1640, but it's conceivable SOTS already employed the use of the jeers at the time of launch, these blocks at scale would be around 30." Thanks for looking. Michael D.
  10. The fitting out of the upper Qtr deck is just about complete minus the ladders leading to the poop deck, next I need to finish up the poop deck then fabricating the main bitts etc, thanks for looking. Michael D.
  11. Work is continuing on the upper Qtr deck, added more cavals, the mizen bits, the knighthead for the tie, mocking up the run of the tie and Hilliard and trial fitting the cannons, still much more work left to do in this area. Michael D.
  12. It was my pleasure John, just glad you were able to make it work they look great. Last year the wife and I did the San Salvador tour out of San Diego Bay, while it wasn't open water, it was exhilarating being on a replica 16th century ship helping asisst in setting the fore topmast sail, quite the 45min experience. Michael D
  13. The staircase's leading to the forecastle deck are finally glued into place along with the railings on the forecastle deck, I still need to add one more step though, the figure stands at approximately 5"-10", scale wise looks okay to my eye. Michael D.
  14. The major construction of the staircase is completed, minus the newel caps, this is a relief as this was very fiddly to construct. Michael D.
  15. With the railing completed, I'll finish up the port side staircase along with completing the 4 remaining cannons on the upper Qtr deck, after that I need to add the timberheads to the railings at the waist. Michael D.
  16. Marc, Yes, they are, while similar to knightheads, cavals are usually affixed to bulwarks, the break at the forecastle and Qtr decks etc, whereas Knightheads are free standing, I believe the ones you are referring to on the SR Marc are knightheads though and I could be wrong, when I built mine, I just used the Heller the plans, maybe some of your better well known sources show them as cavals on their deck plans? Shipman, I closely studied the models of Wolfgang, the Henry Culver model, Don Dressel's, National Maritime Museum in Greenwich and others before I committed to scribing them in horizontally, this seems to be the usual construction method on English ships from what I've found on my limited resources. All the best gentlemen. Michael D.
  17. The cannons on the Qtr deck are completed along with adding the hatch, ladder, cavals and kevels, I still need to come up a railing arraignment though, thanks for looking. Michael D.
  18. Thank you Kevin, always nice to know one's work is appreciated! likewise I love your work on your current builds👍Looking forward to showcasing your blocks! Michael D.
  19. Beautiful work as always Marc, while the blocks might be a tad over scale size wise the eye is the final judge and they look spot on!👍 Michael D.
  20. Kevin's build along with less than a handful are the benchmarks for sure. Hi Shipman, I bought mine about 20 years ago and she's been begging me to build her, when I do, I'll build it bare stick, ironically the Revell Cutty Sark was my very first ship model back in 1969 at age 10, completed it in like 10 days, I did not paint it but did rig it completely. I finally have the gun tackles and ring bolts completed on the forecastle and main decks, quite the exercise, 14 left to do. Michael D.
  21. Ian, I try to push myself to see how much detail I can actually add and get away with it without looking too bulky. Thank you for the compliment! Thank you, Marc, short cuts obviously have to made at this scale to look somewhat convincing, which can be a blessing, I guess, I may have to start the 1:96 Cutty Sark after this to hone my skills on the larger scale...hehe. Michael D.
  22. I finally completed the cannons on the main deck, so I thought! I decided to add the rest of the gun tackle rope. The gun tackles are made up from 100wt silk thread coated with flat clear, knots tied at each end, I used 32g wire for the hook on one end, normally one on each end, for the blocks I simulated them with paint. Thanks for looking. Michael D.
  23. The scale on this one is 1:168, thanks for the compliment Marc. Michael D.
  24. My focus lately has been dressing out the main deck, fabricating the necessary kevels, cleats and cavals along with the cannons, still much work left to do but looking promising. As always, I appreciate the comments and likes! Michael D.
