Everything posted by Siggi52
I'm with you Druxey. From the, I think six 60 gunner who where build after the 1745 establishment, the Tiger is the only one where the lining is drawn at the plan. And that is I think, because it's a ship build at a privat yard. So the plans where a little more detailed, also with the art work. With the models it's not the same, but the modellers would show the ship. So some small things where left out ore where simplified build.
Hello Druxey, for this time, or ship typ (60 gunner), I think it's not so unusual. But often the anchor lining is not drawn in the draughts or build at the models. If they where'd there, or not, I don't know. Here some examples, the Centurion 1732 A Warship 1745, even with a bolster below the wales Ipswich 1730 Standart 1782 (64 guns) And a warship 1735 And then arose, when looking at this picture a question. This model has the hinges on top of the lid and not as I build it, under the lining. I build it so, because at the second picture the hinges are there at the lid, but the left one is under the lining. Godwin wrote that they replaced the lining when it's worn out, so I think the Hinges must be under the lining. May be it's a shortcut of the modeller of this model?
Thank you for your likes and comments, and here the reason why I started to make the hinges. I would have all port lids ready for painting when I at least paint the hull. But there are those who get the anchor lining. But now they are also ready.
Thank you Keith, yes it's a lot of work. But I think, bending them from sheet brass is't easier. For the Dragon I made it the same way.
Hello, I'm busy with building the hinges for the port lids. For that I chiseled with an engraver a die out of a piece of steel and hardened it. The hinges itself I build from copper wire, hammered slightly flat, bent one end back and soldered it with tin Then I hammered it into the mould filed the surface at the back flat and at the disk sander I cut the sidelines flat The drilling I made by eye, 0,65 mm Ø And with that I rounded the back of the hinge And that is it, also with a prototype of an hinge pin. The pin is made from 0,6 mm brass wire. So, I think that I'm busy with them the next days. Today I build 10 hinges within 1,5 hours and I need 84 of them. 😟
Thank you Jorge for the compliment and also Noel for the explanation, you where just a few minutes faster then I.
Thank you Matt, and also all others for there likes I cast the cannons from tin with 2% Antimony.
Hello and many thanks for your likes Today I finished the anchor lining. Now are only the port lids left.
Thank you Keith and also all who give me there likes. It is done, also the port side is ready. The next thing would be the anchor lining.
Thank you Druxey and all others, also in advance, for your likes that was also first my intention, but they are so small (1,3 X 1,5 mm) that I did't risk it to destroy them when doing this. In this case, if you start carving from the outside, you are with the grain at the save side. And later come those, who go over the upper wales, and you must carve also from the underside. So I thought that it is saver this way.
Hello, today I could proudly present the first installed rigols 😓 First I draw them at the computer Then followed a sawing marathon And here they are. I carved them at the ship. There they are fast and could't move, so it is also healthier for the fingers. To the right is the jig for the high.
Thank you Matt, and also all others for your likes Today I finished the rail at the star board side and some small things at the gun ports and there lids. Just to mention the dimensions of the rail, she is 4,5 mm broad and 1,2 mm high. The next things are the rigols 😧
Hello, yesterday the carpenters profiled the planks for the sheer rail and produced a lot of shavings. Today we fit them in at the port side. After I got a little routine with the ends, it was an easy job. Tomorrow we will make the starboard side.
Hello Keith, no, the painter had a lot of work with the lids and the rest of the gang had to plan how it's going on with the rails and rigols.
Hello, and many thanks for your likes. today I finished the gun ports so far, that they fit and being painted. The rest comes, after I painted the outside of the ship.
Thank you Mark for the compliments. For the pillars I used no special cutters. But I used needle files to rund the steps.
Hello, and many thanks for your likes and wishes. After a short break between the years, I'm back at the shipyard. Now all port lids at least are build, but not all are lined. At the picture above you see the lids without lining, flush with the planking. At the picture below the lids have already the lining, and they are now not flush with the planking. All who where not ill with measles ore what else when it came to addition at school, know what is now to do. And that is not a shortcut ☹️ Above without lining and below with lining. At the picture above the lids are looking more like at most historic models. At the Centurion (below) is interesting, that they build the lids just plain, without the bulky wails or thick planking on top!
🎄 The shipwright (thats me) and the crew wish you all a merry Christmas, a happy new year and stay sound in this complicated time. 🎄
Hello, the bits and gallows for the main mast are ready. I changed also the sprouts of the elm tree pumps. And here some pictures from the gun deck
Hello and many thanks for your likes, Thank you Jason, the next update is not far away. The main and topsail jeer bits. For that I think I have to change something with the chain pumps fore handle. Sorry I do not know all these names. But that will take some time and thinking.
Hello, and many thanks for your likes and comments If you think you are ready, then it comes. I forgot the elm-tree pump 😳 So I activated the carpenters, and they build the extra carlings and ledges for them.
Hello, and many thanks for all the likes the painter has all the beams, carlings and ledges painted and the carpenters have reinstalled them. I think, that is here the last action for the next years 😲 Before I set them permanent in, I have to finish the outside of the ship. From the forge came the rail for the stairs.
Hello, the carpenters have there work done. That is the region where you later will see through the deck down to the gun deck. The next days I think, has the painter a lot of work 🙁
