Posts posted by michael101
hello Moxis
i have talk with Mr Knupfer bay emal and he give me everything i need
just want to make sure :
beside of making planks from wood i need also to cut planks i mean i have 0.5mm * 4mm planks and i want to cut 1mm to make the plank 0.5mm*3mm
can i do it with:
50 mm diameter, 0,5 mm thickness: w-krs-50-05-10
63 mm diameter, 0,5 mm thickness: w-krs-63-05-10
or i need also:
50 mm diameter, 0,3 mm thickness: w-krs-50-03-10
50 mm diameter, 0,4 mm thickness: w-krs-50-04-10
thank you again
Michael.
i see in the proton web
Technical data:
230V. 7,000rpm. Mitre infinitely adjustable up to 45°. Table size 300 x 300mm. Cutting depth 1 - 22mm. Saw blades between 50 - 85mm can be used (with 10mm centre hole). Weight approx. 6kg.
so i can buy 50mm also and i need it for making planks so i no need more than 50 mm
someone can recommend a specific blade with Experience of making planks?
or someone can recommend o blade that can serve what i looking for from that list https://knupfer.info...ageblatter.html (Moxis thank you for posting that link )?
thank you
Michael.
hello friends
i have the proxxon table saw (FET) and i need to buy good blade for cutting / making planks
my blade (the one that came with the table saw) can't cut planks even 1.5mm *5mm
so i want to buy a good blade for that job
which blade is the best for that job? (its not need to be only from proxxon but ni to be 80mm and 10mm hole to fit )
thanks
wow thank you all !!!
I have not read the posts until today
But I thought on this solution
Melted the tin in the mold of the wood part , on the basis of tin ,Then I cut the tin around castingAfter that sharpened the part ,and then I drilled the holes ( measured from the damaged wood piece between the holes by a pin ... )Here are the results :::- reklein, thibaultron, catopower and 1 other
4
hello
im working on the concord stagecoach of model expo
and i want to make some upgrade for some little ply pieces
so i want to cast tin and i need to make a molding for that its a very simple pieces without nothing on that it just for replace
the wood piece
need advice for making mold
best regards
Michael.
- pwwilson1938 and thibaultron
2
i called to the store
and i told hem what i need it for
so he told me that i not need something expensive
and he talk about that model :
http://www.sparmaxair.com/product_detail.php?id=1&r=55
how is it?
for the airbrush i will go on the ultra
H&S Ultra two in one 125533
with:
nozzle set 0.2 mm and 0.4 mm
2 ml and 5 ml plug-in cupsbest regardsMichael. -
thank you!
the point is that im leaving in israel and im not like to order expencive thing over the internet
we have a good website that selling airbrush
Which one to take?
and he has :
Harder & Steenback
H&S Ultra
125503- 80usd
Ultra two in one
125533- 109usd
Evolution CRplus 0.15
126204-156usd
Infinity two in one
126543-287usd
which one to take?
thank you all.
the point with the infinity is that its have a stopper for not to push the batten moreand less
and its will give you the same mount of color all the way ...
is it necessary? because i dont want to make a damage on painting...
and what make the different between single action to double action ?
regards
Michael.
thank you all!!!
someone know something about the infinity ?
http://www.amazon.com/Harder-Steenbeck-Infinity-126544-SprayGunner/dp/B010XWRDSQ
hello everyone
I thought of the idea and it works great !
1.make a photocopy of the bulkhead from the plans with the lines (of the center and WL)
2.now you need to paint the other side of the copy on the direction of the lines from the copy side by PENCIL
3.put the copy on the bulkhead with the lines outside and the pencil "paint" inside
4.Now take a ruler lay it on the line and just mark the line with a pencil
5.by doing step 4 when you marking the lines on the paper you also marking under the paper Because the other side "paint" by pencil
best regards
Michael.
hello
im working on the rattlesnake (model shipways)
now i need to line the water line on the bulkhead(Horizontal line) and the center line (vertical line)
is there some way how to mark the lines of the center (vertical line) and the water line (Horizontal line)?
i mean how to copy the lines from the plans
thank you,
michael.
can someone use a dremel for that job?
thank you spyglass
i made another post by mistake
but there is all the info
thank you
Michael.
hello everyone
thank god i start to work on the rattlesnake (model shipways)
now i need to make the rabbet/bearding line and is my first time to do it (my privius ship its of mamoli and ther is not bearding line )
with the rattlesnake model its recomanded to glue the keel with the center keel befor cuting the rabbet line so i did it like it says on the constraction
i have all the tools from hobby knife til dremel...
but i not have a chisel and i cant find smal chisel in my cantry
only from ebay but it will take a while until i will recive the order from the ebay
please help
best regards
Michael.
What is the best way to cut the rabbet line / bearding line?
Thanks
Michael.
Thank you all !
I'm going to work on the rattlesnake of model shipways
And now I'm checking the plans ...
Hornet The block filler is to smal so I can't do as the tutorial it's will be very smal pices to work with...
CaptainSteve can you explain me the steps again my English is not very well but it sounds interesting the guide that you wrote
Also I didn't understand what you wrote about the levels (what levels mean?)
Thank you
Michael.
blade for table saw (PROXXON FET) for planks
in Wood discussion...Where to use it? Where to get it? What types are best? How to Finish it?
Thank you Moxis !!!
i hope it will be my last question lol have you try that one of proxxon?
http://www.amazon.com/Proxxon-28020-2-Inch-HSS-Blade/dp/B000S6DTT0
