Hank
SPECIAL CONTRIBUTOR
3 Followers
About Hank
  • Birthday 11/05/1946
  • Gender
  • Location
    Mocksville, NC
  • Interests
    U.S.N. history, early USN Sailing Warships, 1960's era USN Combatants
3,372 profile views
  1. KG, Very nice striping, indeed! As a retired designer/draftsman (CAD/Board), your method of striping is quite alive in spite of all the alternative ways available today. For those who might be interested, using a straightedge (or other drafting instrument such as French curves, etc.) as a guide - in order to keep the instrument OFF the material being painted, simply turn the straightedge over and apply masking tape along the back side of the tool. This will allow sufficient space to keep the tool off your material and as KG mentioned, not leave a paint smear. I have a whole set of drafting tools in my case which have tape applied to the underside. This works very well for doing drafting with tech. pens and scribes (and pencils!!). Hope this helps!
  2. Todd (Sorry I got your name wrong on my first reply!), Well, not being into the WoW stuff, I had no idea that they were producing kits - perhaps if this entry kit is popular, they will consider posting this fact on the various ship modeling forums, etc. I'll check out the link you provided. Thanks for the reply re. the weaponry - can I assume that their deck fittings are crude as well, or have they provided decent detail on those? I do my own 3D design and printing - I use Design Spark Mechanical (free version) for the 3D design and currently print with an AnyCubic Photon Mono X 6K LCD printer. The available drawings on NARA of PURITAN (NARA has more that are still not available online) do provide ample information to make detailed parts for a model but some items are a bit doubtful as to accuracy (guesstimating from photos). BTW, your bow emblem looks fine - a very nice design for adding the "sparkle" to the model. Hank
  3. Keith (I hope that's the correct owner of this thread) - I just saw your build tonight and looked over what you've accomplished. Quite impressive, to say the least!! I'm currently designing (3D Design/Print) the parts for a 1/200 scale USS PURITAN (BM-1) and after looking over your photos I see that there are quite a few common parts, such as small cal. deck guns and various fittings. I know there's a 1/350th scale 3D printed kit available (Iron Shipwrights), but I wanted this to compliment my 1/200 scale USS NEW JERSEY (BB-62) model (bookends of a sort - 1st "battleship" and last (IOWA Class) battleship). I'm doing mine waterline as my 3D program isn't real keen on hull design (or maybe it's me!!). I've also noted some possible discrepancies in the kit and don't want those to be incorporated into my project. Anyhow, I normally post on The Ship Model Forum but look into NRG from time to time, so I'll keep my eye on your continuing project. I'll ask a question - what references are you using for your weapons/fittings? I've found a few drawings online from NARA but some are very hard to read (faded due to age). TIA! Hank Strub
  4. Gregory, The difference between the Mk. 28 and Mk. 32 has to do with the front/angled face of the mount body. Here is a cut sheet of the Mk. 32 (I should have provided this in my orig. post) - Comparing the side elevation on this view with the earlier one of the Mk. 28 mount, you'll see that the Mk. 28 mount has an angled front face of 45 If you compare this to the Mk. 28 you will see that on the side elevation, the angled front face on the Mk. 28 is 45 deg. and somewhat higher from the bottom of the mount floor than the similar face on the Mk. 32. But, it's important in building models (esp. EXPENSIVE ones) to get these small details correct. At least IMHO that's a no-brainer!
  5. Well, not to throw a wrench in the works, but from the info (photos) provided on the dual 5"/38 gun mounts, I'm wondering if these are the correct version. The 5"/38 dual mounts that were installed in all the newer U.S. battleships (NORTH CAROLINA, SOUTH DAKOTA, IOWA class ships) were Mk. 28 mounts, not what appears to be the Mk. 32 - but I could be wrong. Suffice it to say, here is a cut sheet of the Mk. 28, Mod. 2 5"/38 dual gun mount that would be correct for this class of ship - The Mk. 32 dual 5"/38-gun mounts were primarily used in cruisers/destroyers. I ran into this problem as well, in building my model of BB-62 which is a kit-bashed 1/200 scale Trumpeter USS MISSOURI kit - those 5" mounts were incorrect and I replaced them with 3rd party parts at the time. Here is a photo of the 3D design/printed 5"/38 dual gun mounts that I've made for my model due to paint issues I've had with those earlier 3D printed (commercial) parts that I originally used when I built this model - This is the 3D rendering of the mount body only - barrels are separate. Perhaps Kevin can confirm whether or not these gun mounts are in fact, the correct models, etc. Hope this helps!
  6. Glad to see that others are finding Anycubic as being a good printer for both detailed and large parts. I've been 3D printing now for 4 years beginning with a Phrozen Mini and now into the 2nd year with an Anycubic Mono X 6K printer. What could be bought on Shapeways I now make for myself and use the freeware software Design Spark Mechanical for my 3D CAD designs and Chitubox (free version) for my slicing software. I will advise other modelers to make sure they do maintenance on their printers on a regular basis - this includes greasing and lubricating the sliders and vertical rails on their SLA printer with the proper grease, etc. Some AC models (mine included) have mini grease fittings on the underside of the sliders and finding a tip for a grease gun to fit is rather difficult. But, those fittings need to be greased or you will suddenly come to a screeching halt when the sliders freeze up. Proper grease needs also to be applied to the vertical (Lead Z) threaded shaft. The owner's manual and instructions generally don't mention these little tidbits - but are VERY important in the printing operation. Here is one of my latest large scale (1/48) projects - a 6"/47 D.P. 2-Gun Turret which was designed for the WORCHESTER class CA's in late WWII - I designed/printed all the parts for this display model using Phrozen Rapid Black Resin on my Anycubic printer.
  7. Those ARE the twin 5" Practice Loading Machines. These are shown on both the BB-63 1950 BoGP and the BB-62 1955 BoGP (Booklet of General Plans). As for the question regarding the existence of a flag bag abaft the after stack, the answer is "yes" as there were signal halyards employed from the after stack mast and were tied off on this single, centrally located flag bag. Here is a snip of the plan view from the BB-62 (1955) BoGP of that area - it shows the loading machines & flag bag being discussed - These items were unchanged from the 1940's and we still had the flag bag intact aboard USS NEW JERSEY when I was serving in her in 1968-69. I scanned this copy of the 1955 BoGP when I was at NARA in 2016 and the hand written note indicates changes made for her 1967 refit for Vietnam using this set of general plans. I have a set of the 1967 BoGP for NEW JERSEY, but haven't had it scanned as yet. This copy was in "fair" condition as evidenced by the quality of the scan. Additionally, this overhead shot of IOWA in 1944 should be conclusive although the flag bag can't be seen - Hope this answers your questions.
  8. Thanks for posting - a most interesting discussion. I tend to agree with her that CUMBERLAND, along with other U.S. ships thru our history, has never gotten the recognition they deserve.
  9. After reviewing the current status of books on the market (online), I've further revised my pricing as well as making a correction to one of the titles. Here is the revised List #1: Again, I have many more for sale, but this is a good start. Many of these titles are now hard to find or are out of print. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  10. After receiving some feedback from other members of the forum, I've revised again the pricing on several of the books listed - I have many more for sale, but this is a good start. Many of these titles are now hard to find. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  11. I've revised the pricing on List #1 - see below - I have many more for sale, but this is a good start. Many of these titles are now hard to find. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  12. I am beginning to clear out my shipmodeling bookshelves - I will post lists of books I have as I can get them categorized, etc. If and when these are sold, I will update the list. Here is list #1: I have many more for sale, but this is a good start. Many of these titles are now hard to find. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  13. Dennis, Sorry to chime in after the fact, but I know Model Monkey personally, we are both North Carolinians and both U. S. Military vets. I have purchased parts from him and his quality and accuracy are excellent. I'm glad you were able to find his products suitable for your use.
