Everything posted by Canute
Clare, I was looking at #6 or so bird shot (shotgun shell ammo), since I have some dark gray stuff. Unfortunately, it's about 3 mm diameter - way too big. Might work in 1/4" scale. The deck and rails look good. Are you using Shipyard paint?
Ouch! Looks like my black case one; which is quite ancient. Another good reason to upgrade the old piece, since it won't fit or work with any of the newer accessories. I got one of these kits as a surprise Christmas present, so I'm closely following. Can't do much else with a rotten head cold. Making dust in my wee "shop" aggravates it.
- 113 replies
- constitution
- mamoli
The Bondo Spot Putty works well. Doesn't shrink or crack, sands smooth. And you get a lot more for your money. Sticks to polystyrene, PVC pipe, ABS.
Cathead, good thought. I ended up using some sanding sticks I got from MicroMark some time back. These skinny sticks only have grit on 2 opposite sides; theother sides are clean. I got right up to the sheer tab and faired the forms that way. I did see the beginnings of a notch in places, but it's not the most critical surface. Still playing with fixing the transom board.
Ski, put some masking tape around those ports to protect the details. The old kits, with raised details, are a pita to work with, but I saved some plastic car kit details with this little trick. And you might try some Bondo glazing and spot putty. Got a 4.5 oz tube for $5-6. Sands OK, doesn't crack. Has some odor, so be careful.
- 42 replies
- Constitution
- Revell
All I can say is WOW! I'm blown away.
- 425 replies
- bounty launch
- model shipways
Jack, Glad you're back in action. Great start with the documentation. Nice palette of wood colors.
- 60 replies
- granado
- bomb ketch
Very nice work there, Matt. You keep raising the bar every time I look in.
- 425 replies
- bounty launch
- model shipways
very cool. Another option for the lens is Mod-Podge. Available at arts n crafts places. Dries clear.
- 396 replies
- Idea
- Bright Idea
Matt, Minwax is my stain of choice, too. I did a quick test of conditioned and unconditioned basswood with some Natural and Golden Oak stains. The conditioned wood is on the upper side of the board, my hen scratch shows the color swatches: I like the Golden Oak after conditioning the wood, the natural was too light. Applying the Golden Oak to untreated basswood was just too brown; I want to show the sun-bleached wood. Several other stains I have on hand are just too dark already. So, my plan is to pre-stain the insides of the planks before shaping and bending. If the process lightens the stain, I'll re apply. I'm working on the transom with a buddy who builds high end doll house furniture as one of his side "businesses". The transom will get some veneer applied; I think the planking should cover it.
Quite the artiste, Cap'n. The sails look perfectly ratty and worn. Let me add another outstanding vote.
- 625 replies
- bounty launch
- model shipways
Cap'n, excellent work. More goodies to add to the launch. Thanks!
Cap'n, what were they thinking? Good call on the veneer. I'm off to my local big box hardware stores to seek out any and all manner of supplies, mostly stains. I've added it to the list. I may have a better shot with my little hole-in-the-wall "Ace Hardware". They carry number drills and brass shapes, along with the usual hardware stuff. We shall see. Wish me good hunting!
Matt and Cap'n Steve, thanks for the info. More technique for my growing bag o' tricks! I'm searching my stash of basswood, down in the basement, for the appropriate wood sizes. As a card carrying, kit-building model railroader, I accumulated a fair pile. Also a lot of plastic strip. Anyway, I plan to redo the transom. That laser etch label just bugs me. The Shipyard HM Cutter Alert kit showed up yesterday. I have this thing for 10-16 gun cutters. I'll need various thicknesses of cardboard to add body to the kit parts, when I start on this little jewel.
Matt, it was touchy sanding around the sheer tabs, but I think the mold looks pretty good. No bumpy spots. The frames will be twisted in the appropriate directions, when I put them on. Did you say you ran the frames from side to side or just do one side at a time? The transom is next. I don't think I'll use the kit part. Lose the billboard, but also the taper amount. I think I'll trace the piece on a 1/8" blank and then plank it with 1/4" x 1/32" planks.
Matt, you have a local hobby shop? Ours only carries Lionel sized trainsand is open random hours weekdays only.
- 425 replies
- bounty launch
- model shipways
Bulls eye, sir. Part of the Federal or Union navy's riverine forces. Was active for just over 2 years. Supposed to be a ram, but it was too slow. And it's available as a 1:200 scale paper model, if you're so inclined.
Slog, you're absolutely correct on having the time to create. All we can do is try. Oh yeah, it is a USS ship. Just not USS Lafayette. You're warm.
Matt, nice job! Those handles are outstanding. I'm hoping to get back in the 'yard today, now that the final visitors have been well fed and sent home happy. You and the Cap'n have set high standards for us mere mortals.
- 425 replies
- bounty launch
- model shipways
Hey Slog, Thanks for the info. Most of my current card endeavors are in American Civil War ironclads, although mostly research. So many ships, so little time... I read catopower's post on Alert and decided to try it. How hard could it be.
Slog, as a retired aviator, my fondness for WWII ships gravitates to oddball aviation support ships. And the Japanese ships are the oddest, to my mind. I built the Chiyoda/Chitose class and hunted for the Nisshin kit, in plastic,with no luck. I was trying to remember what their configurations were in the bow area and vaguely remembered that Nisshin was unique, so I took a wag and wrote that down. Better to be lucky than good, some times.
