![](https://modelshipworld.com/uploads/monthly_2017_06/594c220154a6f_JuliaDelacruz.jpg.7fb548c654153ae17c8e0d7243b347df.jpg)
russ
Posts posted by russ
That looks very good. Excellent work.
Russ
The angle in the frames is not much. Just enough to account for the fore and aft bend in the bottom.
Looks good so far.
Russ
You seem to be well on your way here. I also go very slow, and if that is what you enjoy and how you get the most enjoyment out of it, then that is what is best. Go slow. Have fun.
Russ
Very nice work. Congratulations on a beautiful model.
Russ
John:
Did you cut and fit around each frame? It looks very snug. Nice work.
Russ
- popeye the sailor and GLakie
2
I use a sharp blade, always cut less than I need, and go slow, checking with a sample piece of wood for fit every so often. Use a stop cut at the bottom edge with the flat edge to the bottom. Cut just deep enough, but not too deep. You can always take a little more off if need be. Then cut from the top of the rabbet, down to the stop cut. Cut inside the lines and then fine tune your way to the lines as you go along. Time taken here to get this right will pay dividends later on.
Russ
- mtaylor, GLakie and CaptainSteve
3
John:
This kit has been out of production for 25-30 years at least so I doubt there will be any build logs. Maybe someone has built the kit back in the day though.
Russ
It looks very good so far.
Once painted they should be fine. If you seal the grain on the basswood, someone would have to look far too closely to tell the difference.
Russ
Mike:
The hull looks great. Looking forward to rigging.
Russ
The deck stanchions look great. Very nicely done details. Excellent work.
Russ
Good work. The colors on the deck planking look great. I like the varying shades from plank to plank, especially on a vessel like this. The fastenings look very good as well.
Russ
The paint job looks very good. Nice work.
Russ
I have done this sort of thing before. The piece measures okay, but the eye catches something that is off. That is my brain telling me to get it right.
Russ
Great work on the windows. They look very good.
Russ
Brian:
The hatch looks good, but if it does not please you, then it is worth a little time and some wood to have another go at it.
Russ
The companionway looks very good. Nice work. Enjoy the process. Each piece of the model is a model in itself so you have made many small models that will eventually be part of a larger model.
Russ
Frank:
It looks very good. A nice paint job will be good to finish it off.
Russ
Frank:
Excellent work so far. I am a big fan of these Midwest kits and this one looks really nice. You are doing well.
Russ
Probably the dumbest planking question ever....
in Building, Framing, Planking and plating a ships hull and deck
Mark:
I have always planked the outside first, but that is how I learned to do it. It just seems the natural way to do it. I can see adding clamps and stringers on the inside beforehand to stiffen the hull, but past that, I do not know of a reason to plank the inside first.
Russ
