![](https://modelshipworld.com/uploads/monthly_2017_06/594c220154a6f_JuliaDelacruz.jpg.7fb548c654153ae17c8e0d7243b347df.jpg)
russ
Posts posted by russ
- BANYAN, popeye the sailor, Martin W and 3 others
6
Thanks for the kind words. I am pretty sure they led the shroud through holes in the outer edge of the spreaders. There is no indication of eyebolts in that photo, although that area is rather obscure. I will go with the holes.
Russ
I just found your log. Very good work. Enjoy the new shipyard.
Russ
- Blighty, Cannon Fodder, Elijah and 1 other
4
Popeye:
Thanks for the kind words. I used Paintshop Pro. I created the image in CAD, and then saved it as a pdf, copied that as a jpeg and brought it up in Paintshop Pro and used the negative image function to reverse the colors for the black ribbon. I painted out the black areas around the ribbon a bit and then printed it on the white decal paper. I sprayed it a couple of time with the Clear coating, let it set over night and then applied the next day.
The spreader will get sanded down just a bit. It is almost right on scale or about 3 inches square, but just a little work will make it look a little lighter. Not much is really needed.
Russ
- popeye the sailor, mtaylor, src and 1 other
4
Ken:
I love those little details.
Russ
Your hull planking looks very neat. Nice lines.
Russ
Pat:
Thanks for the suggestion. I sealed them with a clear layer after they dried. I used to build plastic kit models back in the day as well.
Russ
- popeye the sailor, src and mtaylor
3
Hamilton:
I agree that practice with tools makes a lot of difference. Also, the right tool for the right job. So, a few different blades and some practice will be a great idea. I have to do this a lot. It is par for the course.
The joint in the profile former is something that many of us deal with. It just needs some fine tuning. The key is to not remove too much material at once. Go slow, measure a lot.
Russ
- Tigersteve, Eddie, hamilton and 3 others
6
Good job. They look great.
Russ
Biloxi schooner by Russ - FINISHED - 1/48 scale - POB
Thanks guys. I realize that it is not the best looking work around here, but, believe it or not, when you stand back and look, it passes the "five foot" test.![:)](https://modelshipworld.com/uploads/emoticons/default_smile.png)
Russ
