russ
Posts posted by russ
  1. I have some Swann Morton blades and they are very good. I reckon the number 11 blade will do the trick, but I do not use different blades for cutting straights or curves. I just use one blade for all of it. I think it is akin to a number 11. They come in small boxes with enough blades to keep you cutting for years. That is what I would recommend. Be careful though. These blades will hurt you if you do not pay attention.
    When cutting planks, I begin with a first shallow pass over the line I am cutting and then make successive deeper passes until I cut through. I always leave a little meat on the piece and then sand it down afterwards.
    Russ
  2. Al:
    Edge bending is fine where you can do it. In some cases, edge bending is simply not possible, especially if the hull as a greater than normal amount of sheer (fore and aft curvature).
    A lot depends on your personal goals and experience. I have planked hulls, spiling and tapering every plank. It was great fun and I received a good deal of personal satisfaction from it. I did not necessarily need to spile every plank, but once I learned how to do it, I never wanted to do it any other way.
    Russ
  3. Spiling is nothing more than matching the curve of the upper edge of the plank to the curve of the lower edge of the plank it will lay against. Once you match that curve, cut the curve into the plank. Now, you need to taper (reduce the width) of the plank on the its lower edge so that it will fit in the space allotted for it on the frames.
    Spiling is transferring the curve to the upper edge of the plank. Tapering is reducing the width of the plank along its lower edge to fit it on the hull.
    Russ
  4. Al:
    The top edge of the plank is spiled to match the curve of the plank above it and the bottom edge is tapered so it will fit in the space for it on the frames. Other than that, I think you have it correct. You are making one plank to take the place of two where the space narrows too much to have two planks.
    In Underhill's Plank on Frame Models volume I, there is a good description with illustrations of both stealers and drop planks.
    Russ
  5. This boat has very nice lines. Very attractive. You have done a great job so far.
    Your bitts look good. I think that is a viable solution.
    On the anchors, our local schooners slung the flukes over the rail and lashed them to a cleat on the inside of the bulwarks. On these small working vessels, they used what they had and made it work.
    One thing I can point out that could be improved, but it is too late to deal with it on this model. Your chainplates should lay flat and the rub rail should go over them. Your chainplates sit over the rubrail. I made this same mistake on a past model. As I said, it cannot be corrected now, but it is important to note for the future. It does not really detract from the model's appearance. Just one of those little things. :)
    Russ
