russ
Posts posted by russ
  1. Robert:
    Great work. No one cares what the frame work looks like since it all get planked. The main thing is to get it to a point where you can plank it.
    One thing I see and I am sure you see it too. The aftermost filler blocks appear a bit too full yet. The closer you get to the outboard edge of the bulkhead, the more it needs it. Just a little more fairing there and it will be fine.
    Russ
  2. That is a good solution.
    You can also make the seizing out of a separate line. Form a U shaped loop against the gammoning, leaving a free end or tail dangling a bit below where the seizing will be applied. With the loop in place, wrap the long end of the line around the gammoning several times moving upward from the bottom edge of the seizing, leaving the loop exposed at the top and the short tail exposed at the bottom of seizing. When you have several turns of the seizing, cut the long end of the line so that there is a little left over. Then feed that end into the loop. Now, tug on the end of the line at the bottom and it will pull that loop and the free end of the line beneath the seizing and it will be secured there with nothing left showing at the top. Then trim the tail flush with the bottom of the seizing and you are done. This will work anywhere where you have a seizing and you do not want to leave a cut end visible.
    Practice this on some spare thread to get the hang of it.
    Russ
  3. Meredith:
    Nice build so far. The overall color scheme is very attractive. This is going to be a fine model when completed.
    Now, to answer your questions.
    1. the belaying pins should be darker. Light/medium brownish. That will fit better in your overall color scheme. Another option is to get some brass belaying pins and use a brown metal toner. The reason I mention that is because the brass pins tend to have a better scale look because the heads are not so thick. However, the wood pins will look better and not so thick, if they are darker.
    2. the breeching on the carronade should be slightly thicker, but it is not that bad an issue.
    3. the tiller blocks could be a bit smaller.
    All of these suggestions will help improve the overall scale presentation of the model. When using a darker color scheme, having light colored belaying pins (and a lot of them) will make them look wrong. The tiller blocks, if smaller, will place them more into the context of the model, meaning scale presentation. On fittings, when in doubt, the general rule is to err on the small side.
    Russ
