Lukasvdb
Posts posted by Lukasvdb
Thanks for the compliments Jason and BE!
If find it really challenging to add some realism to this model. It's hard but is very satisfactory when it comes out like you want it to.
Hi Guys!
Some more progress to report.
I did some scratchbuilding on the bulkhead. Based on the works of jean boudriot. Not easy but I like it! It still needs 2 extra timberheads but Ill get there in due time. This is how it looked before.
And this is how it looks now:
Also the other railings are attached. Fit was not great. but that is an issue that comes back a lot in this kit. It seems some parts are warped or bent. Just an old kit I guess.
I also made a little investment in turned brass cannon barrels to replace the kit barrels of the 8 pounder cannons. This is how it looks unpained/unblackened:
A big improvement on the kit pieces:
Stay Tuned!
- egkb, GrandpaPhil, Beef Wellington and 1 other
4
Starboard side is also done!
A huge milestone reached for this build. I have to admit I have to get used to the look now after she has been so long without her gun port lids. But I'm happy with the results. Needs some cleaning up here and there but that will be taken care of when I feel like it.
Hope you guys like it!
- Blue Ensign, Robin Lous, clearway and 2 others
5
- Barbossa, egkb and Beef Wellington
3
Hey all,
in the above pictures you can see that the ropes for the cannon port lids are a bit unfurled. I don't want them to stay like this as it won't look good in the end. Sloppy even.
What do you think I can use to get the lines tight again? Beeswax, some white glue, CA glue?
If necessary I can redo them but I'm not a big fan of that option
Every suggestion is welcome!
Edit: drilled all the holes for the lids on the starboard side. Holes have been drilled in the lids and 0.5mm copper wire inserted. All have been tested to fit in the holes in the sides of the ship and they fit (some after some adjustment ofcourse) fairly well. Pictures will follow later!
So some more updates!
I tidied up the ropes along the ladders on the sides of the ship. I didn't like it and found a cleaner way to tie ropes. Rope, Needle and CA glue looks soo much better!
Before:
After:
A small but for me noticable difference in the overall appearance and finish of the ship!
I have also started drilling the holes for the gunport lids on the lower gun deck.
First I made a jig:
Then I drilled & test fitted the lid. Using 0.5mm copper wire to strengthen the joint of course!
Succes!!
Me happy. Now repeat this 27 more times
I also tried making some rigols but I'm not sure wether I'm going to install these or not. Here in dry fit
Happy with the results of tonight!
Now I need sleep
Until the next time!
Grtz
Hi all!
So some more progress to report:
I fitted the sternchaser ports and based my work on the books of Boudriot. I'm happy with the result and it defitinely adds realism to the model. Heller provided two single plastic blocks without any detail that would have looked so sad
Some cleaning up needs to be done, painting for example but nothing major.
That's it for now, I have some great plans to continue with!
- Blue Ensign, Ray1981, WackoWolf and 2 others
5
Just look at this little guy, he's so proud of his 36pd cannon!
another one is proud of his nice little 8 pounder but his mother never thought him any real manners, been at sea too much you know
see! here he is sitting on the balcony of the stern galleries! Enjoying the view and the fresh air
that little rascal
as you can see I closed up the ceiling above the balcony with some plastic sheet. Otherwise there would be an ugly gap left when everthing is closed up. I believe it looks much better this way!
I also added the wheel, and the quarters for the officers (or is it calles something else?)
- clearway, Beef Wellington, Barbossa and 4 others
7
Hi everyone!
So I have finished rigging the cannons on the upper gun deck. Now I have to finish them off by making rope coils laid out on deck. Does anybody have an idea how to make them? I have tried but am not satisfied with the results.
Thanks!
No problem Ray.
You can find my build here: http://modelshipworld.com/index.php/topic/5836-le-superbe-by-lukasvdb-plastic-heller-1150-first-ship-of-the-line-ever-built/?hl=heller
You can use whatever you want
any questions, just ask.
HMS Pegasus by Blue Ensign - FINISHED - Amati/Victory Models - 1:64 scale
Beautiful work B.E.!
Very lovely idea to produce a book of your build.
An original idea!
