Philg88
Everything posted by Philg88
  1. Finally the tiling is done! Never again - almost 2,000 tiles individually applied. Insanity. Now on to the rudder, which has considerably less copper sheathing.
  2. The deck has now been glued on and the upper front bulwarks fitted - note the cantilevered section in the middle for the foremast (there is another one at the stern surrounding the mizzen mast). Quite what function they served is beyond me. There is now some work to do on enlarging the slot for the bowsprit since it doesn't fit or rather does not sit in the same place as on the real ship The stern gallery windows are in production on my new 3D printer and make things a lot neater than the previous constructions using 1mm wood or styrene. These were drawn in Illustrator, exported as SVGs then extruded in a free CAD program. Each window is around 13.5 x 11mm (since I forgot to put the ruler in the pic!)
  3. Side heads were featured on the original design and included at launch, one port, one starboard roughly aligned with the fore funnel and overhanging the gunwales. For reasons unknown, they were removed shortly afterwards (meaning a long walk to the john ). When the restoration started in the 80s, they were not rebuilt as they are at the exact point of entry for visitors along the fore gangway. In a typical show of Victorian ingenuity, there was a hatch in the roof where a hose could be inserted and the whole things flushed with nary a mop in sight! Understandable that Billing left them off but I think they will add interest - as will the ash chutes just behind them, which are also missing from the kit.
  4. Deck planking now complete, over 370 100mm planks! Now working on balsa fill-ins to make the hull planking easier.
  5. To save the world's egg-laying population you could use copper carbonate dissolved in ammonia for the ageing
  6. One of the tools I use most often is cheap and home made. Get some 10mm dowel and a pack of domestic sewing needles, chop up the dowel into handle size pieces (60mm is OK), drill a suitable hole in the centre of one end then glue in a needle with CA (aka Superglue). The resulting tools are incredibly useful for applying tiny drops of glue (keep the end clean with a knife) and for generally positioning and poking things. I hope you enjoy your new hobby! Philip
  7. Looks like nothing a bit of TLC can't restore to its full glory! Have fun! Cheers, Philip
  8. I've glued the four deck sections together before planking rather than fit them individually as the instructions show. It is much easier to plank before attaching it to the hull. The "caulking" is 0.3 diameter linen thread, which doesn't fray the way cotton does. A slight modification needed to support the formers for the fore and aft convex sections of the deck - without these supports the formers (part no 120) would be almost impossible to position properly.
  9. Copper tiling in progress. c 900 tiles done, only another 900 odd to go. These are the Caldercraft tiles from CMB at £2.34 per 100. I'm using a general purpose glue rather than CA as it gives more movement time, although CA is used where necessary. Also a snap of the £20 surface gauge I just bought - not sure how you can mark horizontal lines without one of these.
  10. Hey Clarence, Just dropped by to say congratulations on a stunning build! What's next?
  11. For my latest build I have chosen the Billing Warrior 1860, the first British ironclad battleship, which was powered by both steam and sail since those good folks at the Admiralty didn't quite yet trust something that belched smoke. I would have liked to make this a scratch build, but I couldn't find a set of decent plans and the two research books I've purchased don't go to that level of detail on the hull. So, another Billing kit with, as it turns out very poorly done laser cutting - half way through on a good day. Never mind, there are some decent drawings and the usual sparse instructions. She is a monster though and dwarfs the Victory at 1.47 m. Still, at least the hull wasn't copper plated. The box The contents The research books Spot the laser cut Dry fit of keel
  12. Thanks Bob, The timber wasn't too bad - I had to order some more for the hull as there wasn't enough but apart from that it was OK. If you think AL's timber is poor, I recommend you stay away from Billing kits! On my Victory build it was so bad I had to substitute better stuff for both the decking and the hull. Cheers, Philip
  13. Hi Folks, Been back on the Victory build for a month or so. Progress is slow but sure!
  14. Nice looking sander Boyd, even nicer looking ship! Cheers, Philip
  15. Yes, it can be difficult to work around the wiring but I think that the end result is worth it, as shown by your pics above. Cheers, Philip
  16. Yes, I used Longridge's diagram and some Haynes/Internet pics of the real thing. The positioning isn't actually far off the real ones and I doubt anyone will notice, unless of course Nelson is suddenly reincarnated and decides to pop round for a cup of tea. Cheers, Philip
  17. @Napoleon: I kind of made up the lighting as I went along so it wasn't based on someone else's plan. As I recall there is at least one Victory build documented here that has LED lighting but I drew a blank trying to find it ... @Clarence: Plexiglass is cool but wood and brass cover a multitude of sins. The wire I used for both the Mississippi and Victory is AWG 30 with a diameter of around 0.5mm, which allegedly will carry up to 10A (I don't recommend trying it with that load!). That makes it small enough to run two power lines through a 5mm brass tube with an M4 bolt up the middle. Cheers, Philip
  18. Work in progress on the wales, which are not 100% historically accurate, but hey, I'm the naval architect on this build. Also fitted some bits to the prow just because I could.
  19. Boyd, Warrior aside, I was thinking of doing a scratch build of of one of these: http://www.cocatrez.net/Water/FerrisShips/FerrisShips.html of which some schematics are available. Between us ( and anyone else who's interested) we should be able to come up with a credible plan. Thoughts? Philip
