Cabbie
About Cabbie
  • Birthday 09/01/1962
  • Gender
  • Location
    Castlemaine Victoria Australia
2,466 profile views
  1. Hello Roughy I bend my planks by boiling water and soaking for 2 hours or more after they have been shaped. Sometimes they will get a double dose of boiling water. Then I pin them in place until they dry, usually for a a day. I haven't tried this with the thinner veneer planks, but it might work. The planks I am using are 4 X 1 mm.
  2. Love your work Glen, I have been following for a bit. This planking idea is certainly an art to learn. I am doing a Vanguard Alert currently. Is the wood pearwood, I am using this on my Alert and I have found it very good to use. Cheers Chris
  3. Go easy on yourself James, they look darn good to me as well. Good to have some one showing me what to do again, except mine keep getting side tracked.
  4. Howdy Scott keeps looking better as it goes. Fully masted, rigged and with sails she will be majestic to look at.
  5. Marvelous thanks Toni that makes it much clearer. Chris
  6. Also are you reading that the Garboard plank is an even taper from stern to stem, or do you think it is mainly parallel and just widens at the stern and tapers at the bow? BTW I hope all is well up there and you are coping with covid 19 ok. Hooroo Chris
  7. Good evening to all Working my way through this model and finding it very enjoyable. But can someone explain to me how and why the garboard plank has the hook down up to the stern post? Not registering in my brain. thanks Chris
  8. Hello Ji Yes there seems to be a lot of adjusting, fiddling to get things sitting right with some of these kits. Do a test nail into ply and see if it splits or not. The deck needs to be held down somehow. Some people use a heap of elastic bands, I have glued a timber strip between the bulkheads at the top of the b'head and used clamps to hold deck down. Probably won't hurt to nail into the b'heads. And i have used screws at times to hold things in place whilst the glue dries. Make sure your keel is straight and every thing is squared up before putting deck on. Hooroo Chris
  9. Still can't see why they want them, card details name and address seems to be good enough anywhere else. They will have my money, why does a Spanish bureaucracy need passport/id numbers. Maybe in your case collecting an insurance payout is fair enough, but i would be sending a small amount of money in. Wouldn't be getting mine anyway, not going to buy anymore AL kits. Hooroo Chris
  10. Hello Neddie just came across your log, your boat is looking very good indeed. I think the first lesson to be learnt is "keep going", paying off for you. As far as tools goes i use one of these. Couldn't do without it, no quite PC for some but with the disposable blades, which last a fair while, it makes a lot of things easier to do. I adjust the blade by tapping with a hammer down near the blade. Cheers Chris
  11. G'day Pete and welcome to MSW. It looks like you are off to a strong start. yes the planking is certainly a tricky part of model boat building. I am waiting on this kit myself and am very interested in seeing what you do. I know very little about ship boats in general and know nothing of the kit. If you want something to help build up your skills have a look at this, https://thenrg.org/the-nrg-store.php#!/Half-Hull-Planking-Kit/c/41410202/offset=0&sort=normal I just started this one. Thanks for the link to the other log as well. Hooroo Chris
  12. Just looking through the new site and in order to create an account or use the instant checkout you have to give them your Id or Passport number. To me that sounds a bit strange. https://artesanialatina.net/en/autenticacion?back=my-account
  13. Oh well mark there is always a first time for everyone.😉
  14. You should have i think your keel and stem timbers already shaped in the kit. Maybe you can use them to check the shape of the bow or find a scrap bit of ply to mark the shape on and cut it out to use as a template.
  15. Mine was done this way as well, but it was mostly flat. Hard to say what is needed until you start to fair the hull. What you could do is screw it on dry and then see if there is enough material available for you to sand it flat. If not, then glue it on and fill with car filling bog or builders bog. it was placed centrally and flush with the bulkheads at the top. Cheers Chris
