Everything posted by baskerbosse
Hi Dan, Yes your observation is correct, Vasa's guns are not 90 degrees to the centreline, they are pointing in a fan pattern, roughly 90 degrees to the hull side. As this was before the days of line battle. Great looking Soleil Royal. Cheers! Peter
- 450 replies
- soleil royal
- Heller
I agree, It might not be immediately visible, but given a few years (and especially summers), thin spars eventually permanently bend with even the smallest tension on the rigging. I'm currently restoring a Revell Victory that I built as a child, probably late 1970s. Most yards have a bend backwards. Also since the plastic becomes brittle with age, slightest brushing against thinner spars snaps them without any resistance. Chers, Peter
No, the rigging of these deadeyes are quite different; Got this from Fred Hocker many years ago(from memory): Pass the lanyard half way through between the four hole deadeye and the collar's top end and seize it there so you essentially have two lanyards. Pass one end through the lower middle hole of the six hole deadeye, then through the closest port side hole of the four hole deadeye. Then up through the closest hole on the port side of the six hole deadeye, followed by the furthest port side hole of the four hole deadeye. Lastly through the furthest port side hole of the six hole deadeye and then down to the stay collar of the four hole deadeye and seize it there. Repeat for starboard side. (starting through upper middle hole of six hole deadeye) All holes used! Hope this helps? Peter
Yes, that should be a fair enough belaying plan. Probably be an even better one in Vasa II though, I would guess.. 🙂 The plans that Fred would have posted was probably the old museum plans. They are still pretty good, but as you said, has some errors due to new research discovering new things. As for the main stay collar, it is correct with six holes for the upper deadeye and four holes for the lower. It is thought that fore, main and mizzen stays were all rigged this way, though it's only for the fore stay that both deadeyes survive. You will notice that the main halliard is in the way when you try to rig the mizzen stay in the same way. This stay will need to go on the port side of the main mast in order to provide clearance for the halliard.. Hope this helps. Cheers, Peter
Looking good! The dotted line is the outline of the port side of the mainsail. The dotted block you see is for the clewline.
Looks good. Found the plans (the older ones from the museum), here's the relevant area for the sheet. (the line in the top left, coming through the block then tied to the poop kevel, is the mainsail brace)
From what Fred said, they removed the previously installed pinrail to investigate the original fastenings. This would put the kevel just in front (and above) the gun. And yes, there would just be a hole, as the sheet then doesn't change direction...
Keval looks good. Might want to move it a bit though (sorry). I don't think the run of the sheet should switch direction when going through the bulwark. It would make it difficult to sheet home. Also, there's no sheave there.. Small detail: The sheave is pointing a bit to much downwards, compare with Waldemar's side view above. Cheers, Peter
It should be somewhere between 50 - 60 centimeters between the horns, real size. RC Anderson's book is very good, but I'd go with museum plans where possible, as these are based on evidence found on the ship. There are errors though, and Vasa II should bring things up to current understanding. (avoid Mondfeld -Since, as Fred puts it 'almost everything is wrong' there) There was no real 'standard' at the time and there would be differences in how things were done, region to region and even from ship to ship. Note that while the ship itself was built under contract with a dutch shipbuilder, rigging in the swedish navy at the time was contracted out to to a Scottish contractor, John Clerk. While the rigging has similarities with dutch rigging, there are clear differences (the halliard ties going through sheaves in the cheeks for example) Another example of a ship rigged by a scotsman in Denmark and sharing some of these features with the Vasa is seen in this famous ivory/silver model of Norske Løve from 1654: https://www.kongernessamling.dk/en/rosenborg/object/ship-carved-in-ivory/ Peter
Followup of Vasa I by Fred Hocker et al, published by the museum. Vasa I was mainly focussing on the hull and the archeology, Vasa II will be mainly about the rigging. It's been in the works for over ten years now and has grown to now be two books, plus a set of plans. (Vasa I book)
Hi Michael, Looking back on your thread I noticed you installed this pinrail: According to Fred Hocker, this pinrail was a mistake in the reconstruction and was removed from the ship in 2006. A pinrail here would not work and would interfere with the guns, (plus there are not many lines to belay here) A reexamination of the evidence/fastenings on the ship indicates that there was most likely a large horizontal cleat or a kevel here for the main sheet. There are many details like this that will be included in Vasa II, (maybe coming out at the end of the year?) Cheers, Peter
Note also that in general, lower gunports are bigger than upper gunports. This dates back to earlier plans for armament that specified smaller guns for upper gundeck, this was later changed to a standardised complement of 24 pounders on both decks. Also, the small messenger port would be nearly invisible when closed, as the port lid profile matches the wales: Just an FYI for those who may not be aware, Google Scholar is a great resource for scientific papers, such as the paper by Fred mentioned by Waldemar above. Cheers, Peter
Looking great! Some more details that may be of interest. Top circle -small square cabin window, Right, -pumpscupper, plus that the aftmost gunport is smaller on both sides. Cheers, Peter
Hi Michael, It has been well established that there is no way the collar went through the deck, as that would require a corresponding arrangement below deck to take the collar, and there is none. It has been debated quite a bit in the past and there are indeed two holes in the deck that would seem to be perfect for the purpose. There are however no traces of the collar having been installed below deck and that arrangement does not work on the real ship, which is why you see it rigged around the bowsprit there. Hope this helps? Peter
- 454 replies
- Union Steamship Company
- Stepcraft 840
(and 3 more)
Looks excellent! The top one is right side up, but written old style right to left. Confused me at first too. Looks at first glance like it says 'Sakami'. 🙂 The bottom picture is upside down. Great work! Peter
I like the depth charges on rails. I have two destroyer kits, now I realise none of them came with depth charges.. 😞 🙂 Cheers, Peter
