G.L.
Everything posted by G.L.
  1. Thank you Derek, Michael and Christian. Your reactions are very stimulating
  2. 14.30 The chain plates are glued and nailed to the bulwark after they have been blackened.
  3. 14.29 The chain plates are attached to the bulwark in different angles in the extension of the shrouds. To determine the angle I place a stick in the mast step. With a piece of string at the mast head height it is easy to draw the line of the angle on the bulwark.
  4. 14.27 I put a brass nail trough the eye strop and the chain plate rings to fix the dead eye in the strop. The nail is sealed with a drop of tin solder and the excess of the nail is cut.
  5. 14.26 Both sides of the eye are filed to make space for the eye strop rings.
  6. 14.25 For the chain plates I fold the end of a brass strip around a 1,5 mm drill to make a small eye.
  7. 14.24 I solder on both ends a small ring, sliced from a brass tube. Afterwards there is some file work to make both sides equal.
  8. 14.23 I file the tops of the cut ends flat and melt a drop of solder tin on it.
  9. 14.22 To make the dead eye strops, I start with turning a brass wire round the remainder of the hard wooden stock of which I made the dead eyes and I cut it in rings.
  10. 14.21 To drill de holes I push the wooden disks in the big hole, I turn the hinge upside down an drill out the small holes.
  11. 14.20 To be able to drill the holes in equal positions in all the dead eyes I make a little auxiliary tool. I drill a hole with the same diameter as the dead eyes in one side of a hinge. In the opposite side I drill the three holes of the dead eye.
  12. 14.19 With the railing in place, I can make and place the dead eyes I turn a cylindrical stock in hard wood, I believe it is ipe and make grooves in it, using a round file.
  13. Patrick, Your loose hand is very steady. Maybe You had a Grimbergen Tripel before painting. I like it that You paint in a way that the wood grain remains visible. G.L.
  14. 14.17 To make a good fit for the horizontal, I make paper templates:
  15. Thank You Nils. 14.16 Inside the transom there are 2 vertical and 2 horizontal knees as strengthening. The vertical knees:
  16. But done is done. I continue to glue the steps. The upper side of each step must be horizontal. Because the hull is cambered the after side is of each step has another angle. I sand them to the right angle with the band sander.
  17. Only now I look to the 'end view plan' of the entry steps and I see that on this plan the step is placed just on top of the outboard trim. A small inequality between the two plans? Apparently it was not necessary to cut a piece from the outboard trim.
  18. According to the plan, the second step from above is positioned on top of the lower outboard trim so I cut the necessary length out of it.
  19. The sides of the steps have also the same profile. I shape them, using a 3mm mill.
