Posts posted by greatgalleons
Hi Thomas, even if the gallery windows are not functional they do look great on your build.
A question on the black painted areas on your build, did you use acrylic paint or enamel. I've heard of using thined down acrylic paint in many layers ,sanding in between each to achieve a nice uniform look. How did you achieve it on this build. Thanks. A.J.
wow I lost a lot of pics on the build log here, I think I have uploaded all the missing photos, hopefully MSW does not have any more problems. I will have to check my other build logs later.
Hey jerry c, yea that piece I added to the top of the frames,the size of the ports in the plans did not leave room above the ports in my build .
Hey Brian , I used three long pieces of hull planking wood and wrapped each with some white cloth material. They are stacked on top of each other the length of each set of stancheons. Then I glued the length of rails on to the bends at the top of the stancheons . I'm not done with the hammock rails yet, I have one more length of wood to wrap with material but this time it has to be longer on one side so it overlaps the inner cock rail and is tied to the rope line to look correct.
- KenW, grayarea, petervisser and 4 others
- 7
- dafi, KenW, CaptMorgan and 3 others
- 6
The jig is made to the size of the ports on the plans, I did not measure it . I don't get to technical with the measurements, if it looks ok that's what I'll go with.
Hey there, I'm looking at the instructions on how to make the hammock rails and stanchions, what is the best procedure in making the stanchions, soldering the u shaped metal to each stanchion or do you have any better advice, thanks a.j.
- petervisser, dafi, Senior ole salt and 1 other
- 4
Nicely done and it only took a year to complete, great dedication and a fine build. Congrats!
Ohh, nice plague ridden bilge rat.
I had just finished the sails for my Scottish Maid build and thought why not make some for this kit while I had the machine out. Not too hard to make according the profile provided in the kit.
Niagara by greatgalleons - FINISHED - Model Shipways
spanker gaff and boom
