Everything posted by markjay
Looks like an informative place. Great Just Great
markjay replied to rudybob's topic in New member Introductions
Need a seizing tutorial
markjay replied to Michael Scarborough's topic in Masting, rigging and sails
FYI, Jay Brent has several other U tubes that are pretty good in showing and explaining other details about the rigging process. Sort concise and to the point. Highly recommended. -
Check out this U tube video. -
Welcome to MWS.
New member from Arizona - Hi MSW clan
markjay replied to cknilsson8404's topic in New member Introductions
Welcome to MSW. Where in AZ are you? -
Accurate copper plating
markjay replied to allanyed's topic in Building, Framing, Planking and plating a ships hull and deck
I think Caldercraft sells a 1/64 scale copper plate that is etched (no dimples) in sheet form. You may also want to check out Bluejacket. -
Greetings to MSW/NRG Members and All Ships at Sea
markjay replied to Michael Scarborough's topic in New member Introductions
Wow and welcome. -
Welcome to MSW.
Wow thanks fellows. In a way that was the way my thinking was going. I plan to using a cloth tape measure. Measure stem to stern at the waterline. Measure midship waterline to keel to stern and stem. Times two. That should give me a rough square inch amount to work with. Caldercraft sells a 1/64 scale copper plate that is etched (no dimples) in sheet form. I'll find out how many square inches a sheet covers and work from there. Probably not cheap but I do not like the look or working with foil. As always thanks for the help timely response and knowledge sharing.
Bulwark color
markjay replied to markjay's topic in Painting, finishing and weathering products and techniques
Thanks both of you for your information and DrPR for your valued research. -
Hello all, I need help in finding out the bulwark color for American privateers built around 1811-1815. I've seen deep red and green used on the Price De Neufchatel. I've looked at the Smithsonian's on line model image of PDN and can't make out the bulwark color. Is either correct or just builder's choice. Any help is appreciated.
If you haven't down load the Alert construction manual on the Vanguard site. It it give you a great overview of the project and what to expect. Good luck.
