Garward
Everything posted by Garward
  1. Hello, kiwiron, I is glad that you like the Montanes model!
  2. Hi, Carl, many thanks for an assessment of my work!
  3. Hi, Nigel Thanks for an assessment of my efforts on improvement of this kit!
  4. General view of established deadeye and chains of a foremast, mainmast and mizzen-mast (the left board).
  5. General view of the hull (the left board) around a mizzen-mast with the established bottom deadeye and chains.
  6. Bottom deadeye and chains mizzen-masts, look along a board.
  7. The bottom deadeye and chains mizzen-masts at day lighting, the finishing covering isn't put yet.
  8. Bottom deadeye and chains mizzen-masts, left board are established into place.
  9. Installation bottom deadeye and chains mizzen-masts, left board.
  10. Each type and grade of glue have the appointment and many of them are suitable for wood pasting. What do you mean by the term "wood glue"?
  11. Soleil Royal guns http://forum.modelsworld.ru/topic8074start15.html
  12. Hi, Harley! Model on which I gave the reference, not my production therefore as lines to lay flat in it I not are made I can to tell. In the models I apply almost such method as described here Steve to receiving lines to lay flat.
  13. Hi, Carl, I too found them not in any place, I was lucky: at institute where I work, devices for hardness measurement are used
  14. Octahedral preparations and yards become by the sizes specified on drawings. The method of production of octahedral preparations applied by me allows to supervise their size (for example, side width) with an accuracy of 0,1 mm.
  15. Photo carronades MS Syren you can see here http://gallery.shipmodeling.ru/main.php?g2_itemId=126077&g2_page=5
  16. As a result the yard with an octahedron in the middle turns out. It is easy to make similar profiles and in other places of a yard.
  17. Octahedral preparation is pierced on the lathe in the right places to a round profile.
  18. Here still information: octagon portion of a yard can be done on the lathe of such preparations http://modelshipworld.com/index.php?/topic/1734-manufacturing-of-laths-of-an-octahedral-profile/
  19. As assembly plates, and also anvils, etc. measures of hardness for Brinell (НВ), applied to calibration (checking) of devices well are suitable for measurement of hardness of metal: steel tiles of the set hardness with one polished (non-working) and one polished plainly - parallel surfaces. After the working polished surface is used (it is covered with very superficial prints of balls), measures become unsuitable to application for the intended purpose and jump out scrap metal. Some such used measures with a hardness about 400 НВ (for steel very high hardness) and well ground non-working surface, I "lifted" literally from a floor and I use for construction of models (see, for example, photo on the previous page). Possible sources of measures of hardness - all industries where devices are applied to measurement of hardness of metal: various laboratories of mechanical tests of metals other.
  20. This model shows Montanes in the state since 1805, when its bottom covered with copper plates. From 1794 to 1805 years Montanes in the bottom of the copper plates was not.
