Garward
Everything posted by Garward
  1. Cable - "template" for the direction of installation of chains.
  2. The bottom deadeye and chains fok-masts, the left board are established.
  3. To reach home all ways approach!
  4. Hi, Scott! If you mean glue for fixing of knots on ropes, practically doesn't leave traces shellac.
  5. Hi, Grant! Stain for ropes at water works more slowly (dries more long), usually it is necessary to carry out process several times, but to receive uniform coloring of ropes easier. Stain for ropes at alcohol works quickly, but certain skills that coloring of a rope turned out uniform are necessary. The end result in both cases it is possible to receive the identical.
  6. Hi, Daniel, thanks for the comment! The cast trunks of guns for Le Fleuron and Venus from here http://www.shipmodels.com.ua/eng/accessories/artillery/cannon/index.htm At the request of them it is possible to get in different types: raw after casting and most to process (that I and made), and it is possible to order trunks with processing. Trunks of guns for Montanes are turned on the lathe.
  7. And it is Montanes guns, trunks are also blackened 20% solution of selenious acid.
  8. Hi, Daniel! Here a blackening example with the help of solution of selenious acid of a smooth trunk without a decor (the French gun of a frigate of La Venus). http://5500.forumactif.org/t549-discussion-generale
  9. Hi, Dafi! http://modelshipworld.com/index.php?/topic/454-24-pdr-bronze-gun-le-fleuron-1729-by-garward-m-124/
  10. New glues and other materials with interesting properties recently began to appear more and more, it is difficult to follow all this!
  11. By no means, it is a good horse for the purposes. I too sometimes use epoxy glue, but this matter of habit and personal preferences, after all with various materials it is possible to receive very similar results.
  12. I was connected some time with nondestructive testing of quality of with advanced composites (which included a lot of epoxy applications), since then I treat them watchfully
  13. Hi, Sjors! If you decided to remake chainsplate, it makes sense to replace thus also chains with a wire. By the real ships of that era these details didn't produce from chains. Chains which stand, for example, on my Corsair model, on your Corsair and on a number of these models is an imagination of the producer of a kit, no more .
  14. Probably, we used various grades of epoxy glue, I have generally an experience from the industry. In youth I too was engaged in model aircrafts a little , at me and now there are a lot of colleagues - aeromodellers, but they generally apply various nitroglues.
  15. I also wrote it, relying on the experience of application of various epoxy glues (not only in construction of models) within thirty years
  16. In chains I applied jeweler mills to drilling of openings.
  17. In the ends openings under fastening to the hull are drilled.
  18. And epoxy glues give too rigid connection which tends to cracks over time, especially under the influence of temperature
  19. The deadeye and chains are prepared for installation: are tried on on installation sites, are truncated, the ends are riveted.
  20. Here one more link concerning Knoten & Steke http://www.klabautermann.de/
  21. As well as at a model choice - to whom what glue is pleasant!
