Garward
Everything posted by Garward
  1. Hi, Sjors, I am glad that my messages on construction of Montanes help you to build San Ildefonso .
  2. Thanks for an assessment of my work!
  3. Hello, Anja, many thanks for an assessment! I will try to publish the detailed description of construction further.
  4. Many thanks, Michael! I surely will show a design and rope walk work, but a bit later.
  5. Continuation Service of ropes for blocks (a string of Gutermann Skala 200, Col. 464).
  6. Continuation Production of ropes for brake (diameter of 2,5 mm, strings of Gutermann Tera 30, Col. 131, 3 strands on 10 threads) and roofing felts (diameter of 1,07 mm, strings of Gutermann Tera 60, Col. 131, 3 strands on 6 threads).
  7. Continuation Wooden parts (pear) are impregnated with linseed oil after which drying are covered with the diluted bituminous varnish.
  8. 11. LAMPS Racks, twisted of a brass wire, are soldered to the bases, assembly on cyanogen glue. Ready lamps are blackened and mechanically patinated.
  9. 10. CHAIN Dead eye from a set with a diameter of 4 and 5 mm from Ramin are replaced with dead eye with a diameter of 4, 5 and 6 mm from a pear. For these dead eye the corresponding chain are made of a brass wire with a diameter of 0,75 and 1,5 mm. The template in the form of the brass core with a diameter of 7 mm pierced under diameters of dead eye is used.
  10. Continuation Production of buckets tubs (levels from a pear are cut off on a wedge on FET jig save, are covered with a black pigment, are stuck together in the cylinder on an axis from a round timber with a diameter of 6 mm; the cylinder is pierced on a cone 18 x 21 mm высотой25 by mm and drilled).
  11. Options of decorative registration of an artillery post various modellers.
