CDW
Everything posted by CDW
  1. I should have mentioned above but forgot...on some of these extremely fine brass detail parts such as the rails that go around the funnel, I am using Mr Color clear lacquer as the "glue" to attach the parts to the plastic. I think that CA glue or acrylic glue tends to obliterate the details too much and I want to keep the molded details intact as much as possible. I believe they will stand out nicely once it's all painted and pin washed.
  2. The small size of the details are forcing me to work in shorter durations to give my eyes time to rest. Parts fit are very good so far. Well engineered kit, but as it always is with detail sets, cross referencing between the main instruction sheets and the detail set instruction sheet proves to be a hassle to say the least.
  3. Mosquito eyelashes. 🤥 They are parts of the superstructure support gussets components.
  4. I have reached my small part size limit. Anything smaller than this, I cannot do. Too small. Need to have my head examined for attempting these.
  5. Some of the superstructure photo etch is small and tedious (understatement).
  6. By the way, I acquired a conversion chart that gives the correct correlation/cross-reference of the many various paint colors that match Mig Ammo paints and their color numbers. I am not going to post the chart here as I am afraid it may be proprietary and not suitable for posting on the net in a public forum. If you want a copy of what I have, send me a PM and I will share it with you.
  7. I've learned that when working with a detailed model on this small scale, it's important to work over a surface that will catch your small dropped parts and not allow them to bounce and wind up in places unknown. If you are anything like me, you will drop parts. They are so small, it's just part of the game. I found that laying a white terry cloth towel over my work surface will catch the parts when I drop them and make them easy to spot, gray parts on a white surface. This funnel is nowhere near complete, and it already took seven separate parts to arrive at the stage as you see it here. Lots more parts to finish it.
  8. Got a bit of bad news from my local hobby paint supplier when I learned that there will not be another shipment of Mr Color paints for another 6 - 12 months. Not certain of the cause, but it might be Covid related. On a positive note, my supplier became the US distributor for Mig Ammo paints. I've had good results with those in the past but they were hard to come by. Now they are here in my town in full stock. Will have to learn the conversion for them as almost all Asian models give color call outs in Mr Color reference numbers.
  9. Yes, the pieces for the upper decks are included.
  10. The secondary and main guns got a coat of light gray, then the tops of the turrets will be done in a medium gray.
  11. The rear deck now in place, the main deck is ready for guns and superstructure components.
  12. Those are not the photo etch chains. Those are the molded on chains which I chose not to remove and replace with two dimensional photo etch chains. The wooden deck calls for removal of the molded chains and replacing them with photo etch. I think that's a bad idea in this particular case because of the quality of the Flyhawk molded plastic details.
  13. I mixed three parts Tamiya flat white with one part Tamiya flat buff and I think it's pretty close for a match. After it dries, will use a little dark wash and it should be good to go. Need to come back and detail touch-up those molded chains.
  14. Started laying down the wood deck pieces. The molded anchor chains are quite good and acceptable, but unfortunately must be removed in order to install the small wood deck pieces around them/under them. The replacement for the chains is photo etched chain and not quite as nice as the molded chains because the PE chain is 2 dimensional. Maybe I will test some paint to try and match the color of the wood deck and just paint the small deck areas around the molded chains and that way leave them in place.
  15. Main guns ready for paint. There are more secondary guns to do.
  16. I can hardly believe how small some of the parts are cast. Parts 10 and 11 are so small, they are lost in the creases of the face on the coin.
  17. That works perfectly for straight gun barrels, but the Scharnhorst gun barrels are stepped down. Larger diameter at the base then smaller diameter for the length of the barrel. The brass barrels are turned on a lathe to achieve that step in diameter.
  18. While the injection molding is superb on this Flyhawk kit, the brass barrels do make a difference. Here I began working on the secondary guns first by cutting off the plastic barrels. Our dog gets daily injections of insulin to control his diabetes. The left over syringes come in handy as micro drills as they are super sharp and very thin, much thinner than any of the twist drill bits I have. By far these are the smallest barrels I have worked with to date.
  19. Curing the new paint in the dehydrator at 105 degrees F. for a couple of hours. This makes the paint very durable and resistant to damage from handling later on.
