Everything posted by CDW
Delahaye 135 by CDW - FINISHED - Heller - 1:24 - PLASTIC
CDW replied to CDW's topic in Non-ship/categorised builds
Fenders now have primer and paint. Paint color is midnight blue, another metallic color. For contrast, the final picture shows the color combination used for this model. -
Thanks guys. You know the old saying, absence makes the heart grow fonder. Sometimes it helps to step away from a hobby for a period of time and change up a routine. I used my swimming pool more this past summer than I've ever used it before, plus got a lot of projects done around the house. -
The fenders show the odd use of multi-colored plastic in construction of this kit. A good layer of primer coat will quickly solve that issue. Interior is very simple, but will mostly be unseen anyway. The finished body is what I'm after with this kit. Love the art deco lines of it. -
Take a look at the 2nd photo in my previous post. After I looked at the photo, I noticed something I had not noticed when I sprayed the model. There are a few small specks of something that go unnoticed until closer examination of the model. This is where I let the paint run out in my airbrush cup which caused it to spit. With metallic paints like the silver I am using here, these specks become very noticeable, particularly after a clear coat goes on top. I know better than to let my paint cup run dry like that, as it's not the first time that's happened to me. But it's worth noting to my friends who may not have experienced this phenomenon before. Always keep your airbrush paint cup filled particularly when spraying metallic paints. At this point I will give it a second coat to try and hide the specks. -
It's a lacquer, Ken. -
This top coat is Splash paint, the color is Argento Nurburgring. If I remember correctly it's a Ferarri color. Of course, a gloss clear coat goes on top of it all once everything else is finished. -
Here I am laying down Mr Surfacer 1500 black primer on the car body. The final color will be silver. For the fr and rr fenders and a stripe that runs down the length of the body, will use a light color Mr Surfacer 1500 primer with a final color of blue. -
PS: I am also wondering what the two boxes located on the bottom of the chassis behind the fuel tank were used for? They look like battery boxes. -
I was thinking the same thing about those 2 six volt batteries. There were a lot of times when I wished my old '51 Chevy (my first car) would have had 2 of those batteries instead of 1. Six volt systems were notoriously slow starters and the lights always seemed dim. If I remember correctly, a Nash Metropolitan I once owned also had 2 six volt batteries. They were located under the little rear bench seat. Seems like the Nash batteries were connected in a parallel circuit, but again, my memory may be faulty on that. -
I painted the interior in a basic light brown color with the seats a darker leather brown. I glued the door panels/side windows inside the car body then test/dry fitted it all together before I do some final detail painting in the interior before gluing it all together. As you can see, the interior is not going to be highly visible at all once the model is finished. After gluing the front and rear windshields in place, will have to carefully mask the glass before priming and painting the body. -
You have to feel your way in the dark with some of this kit's assembly. There are no locator pins so it's trial and error to be certain of the exact positioning of lots of parts. The interior parts along with the fender wells are particularly fiddly. It's interesting how they used the various colors of plastic to mold the kit parts. Not a whole lot of rhyme or reason to it. -
Yes, the alignment did need a little tweak. I think I got it about as close as it's going to get. I keep looking and thinking about about the assembly and painting of the interior, the fender wells, and body of the car. This one is going to be a little tricky. The interior door panels are molded as one piece along with the side windows in clear plastic. I'm going to need to get the whole interior assembled and painted before I paint the body, and I will need to have the fenders and fender wells assembled with the body. Part of the rear fender wells are attached to the interior parts. I'll figure it out, just need to take my time and not rush through it. -
After assembling the chassis, engine, and radiator, everything got a coat of semi gloss primer before any color coats go on. The assembly was a little fiddly, but it looks authentic to me when it's all said and done. -
I'm going to slap the 1st guy who tries to look inside the window to see it right on his noggin'. 😄 -
You know the term, "tip of the iceberg"? That's what you're seeing of my model stash. I will whittle it down eventually but will never build all of these. -
Please don't follow my example, Papa. I am a bad influence in the excess stash department. -
Thanks OC. Got caught up on other matters, all is well. One of the things I did was to pull everything out of my hobby room then cleaned it all spic and span, repainted the walls, hung everything back on the walls, put in new work tables and a display cabinet before moving everything (almost) I had cleared out and put it back in the room. Taking advantage of a store closing sale at a major department store, bought the big work tables and display cabinet at an extremely favorable price. Just the way I like it. -
After taking off the entire summer from model building, decided to kick off with a build of the 1:24 Heller Delahaye 135. Don't know anything about the 1:1 car, but like the body styling, looking quite 1930's in appearance. Long hood and a sharp coupe top. My copy was damaged in transit long ago with a crack on the top. I patched up the crack using a piece of sheet styrene plastic on the inside and some putty, sanding on the outside. Will build the various sub components then paint them all before final assembly. It's interesting the various shades of blue colored plastic Heller uses in the manufacture of this kit.
Wow Mike! Your planes turned out spectacular. Great job on those. The real professional model builders carefully cut the excess clear carrier film along the color separation of the decal before placing it in water. They do this with a straight edge and a new scalpel blade, only cutting lightly, just enough to separate the clear film from the colored. It's painstaking and tedious, but it gives the best results without any silvering. In addition, the pros don't use a clear coat under the decal either. They just rub the area where the decal is to be placed to polish it a little before applying the decal.
1930 BENTLEY 4.5 LITRE by MadDogMcQ - AIRFIX 1:12th Scale
CDW replied to MadDogMcQ's topic in Non-ship/categorised builds
Beautiful work. I love your Bentley. What a classic! The chrome/aluminum plating on the model is exceptionally nice. -
My old house I grew up in (in Tampa, Florida) had a large cellar/basement with dirt floors. It was filled with wine racks, but don't recall any wine being stored in the racks. We also had a huge attic in that old two story house where my big brother had his Lionel train layout.
