CDW
Everything posted by CDW
  1. Here we go with the Roadster portion of the Revell double kit. Changed my mind and decided to go ahead and build it now rather than wait. One of the reasons I hesitated on this particular build is because of past experience and memories of having built this model before. The roadster body shell is a real pain in the rear to prepare, being that it is assembled in no less than 8 pieces, and those pieces are by no stretch of the imagination a good fit. Anyway, I'll try to give it a good shot and see what I can do to make it presentable. No guarantees. I don't intend to spend a too much time on it but there will be reinforcement, filling and sanding to do before primer and more sanding. Let's give it a go for old time's sake. You'll notice I have the floor pan taped in place...this is to keep the body pieces in the correct alignment while the glue dries on the upper parts of the body. Same thing with the rear portion of the body, just taped in partial alignment while the glues dries in the front. All these glue joints will require some strips of styrene on the inside of the body shell for reinforcement. There's not enough surface area to keep the glue joints together through the rigors of filling and sanding without it. The lower body pan must stay removable in order to install the finished body on the chassis at the final stages of the construction process.
  2. This will complete my work on the dragster. The roadster will follow at a future date. I have a ton of these old, nostalgic, unbuilt car models in my collection. Can't spend too much time on most of them to have any chance of building them all. Maybe one week each at the most. Some I will make an exception for as the kit may be interesting enough (to me) to warrant more time. Thanks for following along, for all your "likes" and comments. It's been fun!
  3. I wanted to finish the model today, but ran out of gas, figuratively speaking. The decals are old (1994) and were cantankerous. I was lucky they worked for me at all. Very thick. Decal colors were suboptimal at best but back at the time, they were par for the course. If you tackle one of these old kits, be prepared to spend a lot of time cleaning up parts. Every single part need attention and some of the parts should actually be replaced or reworked. As it is, they will build into a decent shelf model but won't be contest material on their own merits. I added ignition wires and a rudimentary fuel line. Other than that, everything is box-stock. When I take back up to finish, need to install the radius arms, the tie rod, drag link, parachute, and windscreen. If everything works out, will post final pictures for this one over the weekend.
  4. Thanks Bruce. I mixed a few drops of white into the color cup of my airbrush and the result was a much more subdued, subtle silver, closer to the box art. It's not an exact match but much closer than before. Once the decals are applied, I think it will be okay.
  5. Comparing the silver to the box art, it looks like the 1:1 car had some white mixed in with the silver. I'll experiment with some white mixed in with my silver to try and get a closer match.
  6. Put the first coat of silver on each body panel, then dry fit the chassis into the lower body shell. Will paint and build out the remaining pieces that are internal to the body shell, add fuel lines, a magneto and ignition wiring before gluing down each body panel. After that will mask off the engine and interior compartment before giving the entire assembled body another coat of silver to unify the color. When spraying metallic paint, it's next to impossible get each individual body panel to look the same without it all being sprayed as one unit.
  7. @yvesvidal Could one of these be incorporated into the model, to be removable to show the turret detail? Could be very interesting. FUJIMI 1/200 Equipment Series No. 3 Battleship YAMATO Type 94 46cm Triple Turret 4968728020358 | eBay
  8. Spending an inordinate amount of time cleaning up the parts. Every single part requires attention. Even the little slots in the wheels have flash to clean up. 😄 Chassis is painted in Tamiya gray metallic lacquer. Engine block Tamiya red lacquer. Other metallic shades are various AK Xtreme Metal paints and a few are the AK Super Chrome ink. Trying out a dry fit here. Lawn maintenance received full attention today. Very little time for modeling. Tomorrow is another day.
  9. I wanted to show you another "chrome" paint. This one is manufactured by AK and called Super Chrome. The bottle calls it an ink, not paint. It likes to be sprayed on in a heavy coat, not light mist coats as you might do with Alclad chrome/metallic paints. Very easy to apply. Does not require a base coat but needs a smooth surface. I applied a much reduced Mr Surfacer 1500 black base under my parts which goes down very smooth. The part on the left was painted with AK Xtreme Metal aluminum. The two valve covers painted with the Super Chrome ink. To me, it's a very convincing chrome finish and much better than the funky chrome plating that was on the parts originally. In the background is my body shell painted in Mr Surfacer 1500 primer. The body will be painted with Mr. Color super silver, then clear coated with lacquer, decals, then more lacquer over the decals.
  10. Don’t you love the way spellchecker ‘corrects’ spelling incorrectly? soluble not solvable (my previous post). Working from my iPhone. 🫤
  11. The body shell is intended to come apart in order to reveal the entire chassis assembly later on. Mine won’t be removable. In order to get a smooth body shell, I temporarily glue the panels together using acrylic glue. After sanding, the panels can easily be taken apart to fit the chassis inside. The glue is water solvable.
  12. Absolutely, please do follow along. Hope you enjoy the trip down memory lane. Yes indeed, they are great parts donors for custom projects.
  13. This nostalgic kit comes all the way back from an original release by Revell in 1963, the Tony Nancy 22Jr Roadster and Dragster kit. Two complete kits in one box. My particular kit copy was re-released in the late 90's or early 2000's. When you open the box you find some very flash-filled and crude parts by today's standards but nevertheless, the kits can be built into a very reasonable facsimile of the original racers. I spent some time today cutting parts off the sprue trees and cleaning them up by sanding filling and sanding some more. Lots and lots of flash and parting lines on these old kits. If you get a chassis frame that's not warped, it's a miracle. These early dragster kits were notorious for having warped chassis but this can all be worked out reasonably well with a little persuasion and care. To start, I am building the AA gas dragster kit first. I don't intend to spend a lot of time on these kits but will add a few extras here and there to modernize them a tiny bit. Will try to get a good paint finish on both. You'll notice I almost always start by stripping all the chrome from the plated parts as they are so full of flash, once they are cleaned up the plating is rendered useless. Priming and painting them with metallic lacquers will do a more than adequate job of giving the appearance of shiny metal. Follow along and feel free to share comments as we travel down a nostalgic path that many of us took while building these kits in our youth. I sure did.
  14. Looking forward to your build of Yamato!
  15. Wow, that is nice. 3D resin printing is a game changer. The details are so clear and near perfection. Light years ahead of molded plastic.
  16. Bugatti T35B, Winner of the 1st Monaco Grand Prix 1929, Found and sold unrestored more than 80 years later - Finished as it was found. This was a very pleasurable build, made possible by an excellent kit from Italeri, and most of all, by all you who followed along, made great comments, your likes and encouragement. It's time now to evaluate and contemplate my next project. PS: I ended up installing a set of magnetic bonnet strap attachments, as opening the bonnet would be rather impactable or impossible if the latches and straps were glued in place. Believe me when I tell you, installing the little windshield and the bonnet straps were by far the most difficult part of the build. A real pain where the sun don't shine.
  17. Thanks Greg. It's been a lot of fun building and finishing it. Probably the best Italeri kit I have built to date, everything fit well and was not over-engineered. A lot of parts but not over the top.
  18. Tomorrow, I'll build the bonnet straps, add the windscreen and some touches of paint/weathering here and there, then this one will be finished.
  19. Stunning model, your finish of it is superb. I’ve heard nothing but good about Perfect Grade kits and your model shows why they are so highly rated.
  20. Excellent looking model kit. Contains a lot of extra parts to do it up real nice. I like the surface detail on the model, too.
  21. It's almost there now, the finish line. Just a couple more days at the most.
  22. Starting with the previous state pictured, I mixed Mr Color sail color with my Bugatti blue to make a lighter shade of blue paint. Then this was highly diluted with thinner before spraying high spots all over the model to give the appearance of paint fading. After that, oils were used to shadow and create oil stains along the louvers of the body pan. Last, Mr Color silver paint was used to create paint chipping effects on the louvers and scratches/chips on the body in various places. Your milage may vary, but when I do a diluted highlight spray as mentioned above, I turn the pressure down on my airbrush and use a much more controlled, light trigger pull to put the paint where I want it. The idea here is to highlight, not to overspray or repaint the entire model.
  23. Thanks Alan. There are always newer and better tools it seems.
