Everything posted by JeffT
Just curious, how are you scanning the frame drawings?
- 38 replies
Welcome to MSW 👋
I also broke them. About 3 times. Left them off after the last time.
- 857 replies
- Sphinx
- Vanguard Models
Welcome to MSW
Hi Free. Welcome to MSW
Welcome to MSW
Back at it. Hope you got a little AC time in 🙂
- 28 replies
- vanguard models
- Brixham trawler
Novice is greeting from the Bavarian Alps
JeffT replied to XS400DOHC's topic in New member Introductions
Welcome to MSW 🙂 -
Well, I decided yo go ahead and get a jump on the Sphinx since I'm waiting for the instructions and plans for the Granado. A picture is worth a thousand words so not much to say here that's not already been said so here you go: I have an extra set of hands to help out, thanks little dude A courtesy dry fit shot I wasn't sure how critical this was but wanted everything as squared as possible. Pre-sanding all done. I was a little nervous about doing this off model but I just went for it. On to the bow. Used the angle plate for this too to keep it all square. All sanded. I left a little at the top until after attaching to the hull. I was a little worried about squaring this area off too much. And here they are attached. All the bulkheads are glued on at this point. I glued the bulkheads on the old fashioned way...one at a time squaring each one along the way. The lower deck was glued on using the watered down glue method. I watered the glue down about 90/10. You may be able to see the pencil mark on the lower rear part of the stern section in the last picture. A little more will need to come off there when I do the final fairing. This is the sander I used for the off hull work on the bow and stern. It seemed to work the best for me. This is an ADC mini sander with 150 grit.
Hi Mark. Welcome to MSW
I think someone else had a similar issue which Chris looked into. Check the other build logs.
- 505 replies
- vanguard models
- Sphinx
I couldn't help myself. The box is open so I took some pictures. This is part 1 for the kit so it has all the parts necessary to finish the framing. At least I think so. I don't really know what I'm looking at yet since I don't have the plans. Tom did respond and everything will be in the mail shortly. There are two boxes. One contains the parts for the ship and the other is the parts for the build jig. Most parts are laser cut and they look very good. There are a few parts that are CNC cut I think. The keel parts are somewhere in there too I think, 6B maybe.
This will be my build log for the CAF Model HMS Granado, 1/48 scale. I've always wanted to build a true plank on frame and thought this would be a good place to start. This is to be more of a side project so there won't be rapid progress. I'll open the box this weekend and post some pictures of what's inside as a start.
Welcome!
