Everything posted by JeffT
I have this model also. My wife is from South Korea and wants me to build it. Its also available here: http://www.ebay.com/itm/220435859097?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
- 96 replies
- Turtle Ship;
- Korean Turtle War Ship
Byrnes table saw accessories
JeffT replied to Neill's topic in Modeling tools and Workshop Equipment
Thanks. -
Can that be demonstrated? I can't visualize how to do that. -
I have no experience with Proxxon but I have a Dewalt which I find to be an excellent saw. Previously I had a Craftsman and the difference between the two is very noticeable to me.
Thanks Jay. I've just finished the binnacles and the next step is the ships wheel. I think I will skip that for the time being while I figure out what method to use in building it. I'll move on to the capstan instead. The following pictures show how the binnacles were made. The first thing I did was glue some strips of wood together to form the basic shape of the binnacle. The practicum method suggests to cut the pieces to size but I found it way to difficult to work with such small pieces. So I cut the pieces to a longer length and worked from there as the following picture shows. The plans suggest that the corner pieces of the binnacles were made of mahogany. I don't have any so I used a stain pen to color the wood. I cut some 1/4 inch square pieces for the base and glued them on. Then it was just a matter of cutting the two pieces out to size. Making the top per the practicum was not optimal in my opinion. It had you constructing the pyramid shape from multiple pieces. I chose an easier way by using the Byrnes sander to create a little pyramid on the end of a 5/32 square dowel. I cut it off and glued it to the top of the first piece. The picture shows the dowel and a completed piece. To make the lantern on top I just used the head of a brass nail. For the color of the top piece I deviated from the practicum again. Instead of gluing a piece of gold leaf on each side of the top, I just used gold leaf paint that I got at Michaels. Much easier. After that it was just a matter of gluing them on to the deck. You may also notice the shot racks on the gratings. I left the brass wire unpainted since i like the way it looks. Another view and one more
Now that MSW is back up and running, its time for an update. I have finally finished the work on the bow after what seems like an eternity. The exception is the scroll work which I'll do later. This is kind of a major milestone in the Conny build as it completes all the major structure and hull work. I can't believe I actually made it this far since this is only my second ship kit. If I follow the order of the practicum the next step will be the outer hull details like the gunport covers, davits, and chainplates. However, I think I'm going to skip ahead to the next chapter and do the deck details first because it seems like it would be too easy to knock stuff off of the hull if I do hull first. Pictures follow.
Jay, I haven't decided yet what to do with scrolling on the bow. I think I'd like to try to carve it but the practicum really leaves out a lot of the detail on how to do it so I don't know. I may try it to see if I can do it. I did see what you did with the hawse pipes and I'm doing the same thing right now as a matter of fact. It does look like the right way to do it based on the plans and pictures.
I use a mechanical lead holder with 4H lead from my drafting/architecture school days such as this: http://www.utrechtart.com/Kohinoor-Adapto-Lead-Holder-MP38148-i1011444.utrecht http://www.utrechtart.com/Prismacolor-Premier-Turquoise-Mechanical-Pencil-Lead-Refills--2-0-mm--pack-of-12-MP33300-i1010974.utrecht and also a sharpener which gives a nice sharp point, like this: http://www.utrechtart.com/Alvin-Small-Rotary-Lead-Pointer--Sharpener-For-Mechanical-Pencils-MP49597-i1017015.utrecht
No doubt about that Jay. The bow has been the hardest part for me so far.
- 732 replies
- constitution
- model shipways
Good to see you have your build log back up and running. Marc - .035 rivets are the recommended size.
- 732 replies
- constitution
- model shipways
Echo by Rustyj - 1:48 - cross-section
JeffT replied to Rustyj's topic in - Build logs for subjects built 1751 - 1800
thanks for reposting Rusty. Looking forward to seeing your updates.
