Posts posted by mbp521
Good day everyone,
A little work has been done on the build. Unfortunately not a whole lot since this thing called a job tends to get in the way of my fun time. Anyway, I have planking complete on the hull as well as filled, sanded and painted. I made the mistake of using gloss paint in the hopes that it would fill in some of the voids i may have missed during filling and sanding. Nothing that cannot be remedied with a little sandpaper and some flat white. This is my first painted build so I dealing with a learning curve when it comes to painting. On the good side, this will give me the opportunity to apply a little more filler and clean the hull up a bit.
One thing I did notice is that when I installed the keel on the bow, I some how managed to make it a little long. Now the deck pieces are about 1/4 too short cover the bow. Not sure how I managed to do that. Must have given the bow a little too much rake when planking. I may be able to extend the bow a little to cover this up since I am still not real happy with finger joint on the deck pieces and will probably lay down my own planking. I'll give this some more thought and hopefully come up with some sort of solution.
Hello everyone. While I am not new to the ship modelling world this will be my first attempt at a build log, so please excuse any errors while i work my way through this. While I love the older period sailing ships, I recently tried my hand at steamers. I picked the Artesania Latina King of the Mississippi and enjoyed the build so much that I wanted to attempt another steamboat build. After reading several build logs on MSW and the reviews of the kits I decided on the Model Shipways Chaperon. I really like the quality and detail of their kits, and after completing the AL KotM, this is a real step up.
I actually started the build a couple of weeks ago and while researching some of the builds came across Kurt Van Dahm's post for his article on his build of the Chaperon. Since I want to do this model justice I purchased his article to help me along the way. Since Kurt was so gracious to make this information available, I figure why not return the favor and start a build log.
Anyway, like most, I won't bore you with the details of the kit contents since this has been done already, and jump right in with the build. Since i just now decided to start a build log, I have very few pictures of the beginning, however going forward I'll try to take more as I go along.
Any and all comments and suggestions are always welcome. Thank you for looking.
-Brian
Here is what I have so far.
Starting the hull. Bulkheads and stringers in place and first row of planking.
Chaperon 1884 by mbp521 - FINISHED - Model Shipways - Scale 1:48 - First Build Log
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by mbp521
After a little bit of thought and I came up with a solution. Instead of tearing down the hull, re-planking and installing a new keel, I decided to just extend the deck a little to compensate for the extra length.
I used the main deck pieces and made a paper template, then traced the edges on a piece of scrap. I used the pieces the decks came from, that way I only had to make one cut and the inside of the "addition was a perfect match for the deck.
Then I cut out the extensions with a little CA placed them on the bow, using the station notches as a guide to get them perfectly in place. A little sanding to shape, and Viola, problem solved.
I know this little extension throws the authenticity out of whack by making this fine boat a little longer than it should be, and you hard core Steamboat aficionados please don't think less of me, but to scale it only adds about a foot to the length. And who knows, maybe during the lifetime of the actual Chaperon and over zealous captain ran her into a dock at one time and the ship workers had to make some modifications. Anyway, I am happy with the results and will press on.
Thank you for looking,
-Brian
