wrkempson
2,379 profile views
  1. I use TurboCAD. Concerning the table of offsets, I have never used them. When the actual lofting is done on the floor the offsets are soon abandoned at any rate. Perhaps my efforts will be useful to you. Wayne
  2. This is a worthwhile project, but much more challenging than it would seem at first glance. Full speed ahead, Vddoc! You will be finished in two years. Keith, I understand your Tally Ho tally. You could add me to the list, but I never sought to build the boat. I have, however, lofted out the working lines, a set of frames showing the bevel, and lofted out the axial pieces. That exhausted my commitment to the project, so I am done. Here are some screenshots of my work if anyone is interested. This is the plan lines from the internet reworked and reconciled. There are a lot of decisions one must make to fill in missing information on this boat. Tally Ho Master Lines.PDF This picture shows the axial pieces indicating the joinery and frame placements at the heels. Also shown are the lofts of the frames. Drawing1 Frames and Keel.PDF Wayne
  3. I have so enjoyed your work on Euryalus these past several years. In every aspect you have produced a masterpiece. Thank you for allowing me to look over your shoulder during this journey. Wayne
  4. There is a nice discussion of the bread bin configuration in Euryalus vol 1, p. 111. Your final conclusions (door or lid) will be defensible in either case. I did not find a treatment of the matter in Goodwin. Lavery, p. 189 states that bread was wrapped was not stored in casks, hence I suppose the bins. Perhaps the bread room employed racks. I looked in TFFM but did not find anything in a quick search. Wayne
  5. I am enjoying your progress. The level of precision is remarkable. If memory serves, there are three openings aft the capstan labeled "Gra," "tin," and "g" which is to say, "Grating." Also, apertures labeled "Hatch" or the like can have gratings as well. Dashed lines on these openings indicate a shelf in the timber to receive the grating. Well done and inspiring. Thank you for sharing. Wayne
  6. I have used the plastic chains and channels. I suspect this is what you mean by the "platform" for the shrouds. I also used the kit's deadeyes and lanyards (the round things with ropes between them). The only part I discarded was the preformed shroud and ratline piece (looks like a triangular ladder). So, using the plastic parts, I set up the shrouds as was done in real practice. The final result was quite pleasing. You have already chosen plastic as the medium for your model, so there is no real requirement that you use wood deadeyes. I have followed this procedure on three of the Revell 1:96 models. They have gone the way of my childhood and are no longer available for photographs. I'm pretty sure eyebolts are not the answer. The choices really come down to setting up wood deadeyes or using the procedure I outline above. I wish you the best as you complete your model. Disclaimer: perhaps I presume too little experience on your part, but your use of terminology tells me you are at the front end of the learning curve for rigging a model.. Wayne
  7. Terry, I think your observations in the original post are entirely correct. I might add that there are some conventions in ship plan drawings that are not to be found in the actual construction of the ship. Rabbet lines are one such convention. The dotted lines on the body plan are indeed indicators of the depth of the rabbet, but the actual lines would be quite fiddly (read: almost impossible) to loft and would be of no value at any rate. On the profile plan the "flat" stretch of the inner rabbet line is not in fact flat; but since it varies from the width of the garboard plank by fractions of an inch there is no good purpose in lofting the actual shape of the line in a basic drawing. I have lofted this line myself and can tell you the amount of curvature is virtually nil (but only virtually, it is real nonetheless) and is possible only in CAD or some such overly precise drawing tool. At any rate, the finally shape of the rabbet must be cut in situ so drawing it with precision is not productive. So, your inner rabbet line ultimately should be lofted on the basis of the how the frame line is finished off at the keel, another process in the drawings that is done more by convention than by geometric accuracy in the older drawings. As you point out, the inner rabbet line derives from the intersection of the frame line (equals the inside face of the planking) and the plane of the side of the keel. I have seen modern drawings where these lines are done accurately. I don't know about the era in question for your ship, but suspect there was still a bit of simplification going on. Now, add to all this the taper of the keel fore and aft and you have quite a donnybrook. I have no conclusions for you in all this, just some observations to agree with your final game plan. Berger's drawing may be neither in error nor mistaken. More likely it simply follows the conventions of the day which the men in the yard would know to adjust during construction. None of what I have to say relates to the shape of the garboard. Finally, the notices made of the DTM plan ring true to my inexpert understanding. It looks like it may have been drawn using accepted conventions and a modicum of guesswork (regarding actual bolt placement, garboard shape, etc.). Usual disclaimers inserted here, Wayne
  8. I have no knowledge of Spanish practice regarding the rabbet and the keel. I say this to excuse myself from comment only because I would like to be helpful but my knowledge base is restricted to English ships. I do observe, however, that on RN drawings the keel is more of a convention than an actuality. The men in the yard would not use a drawing to cut in the rabbet. So, to answer your question one would have to know the practice of the Spanish yards. All of this is to say: I don't know. Wayne
  9. Am I following a good approach, or are there features of Fusion 360 that I have overlooked that would make this easier? I believe your approach is sound and you are not missing some "secret." Programs dedicated to ship hull design handle things pretty well it seems (I have not used one to date), but hulls are fairly challenging for programs like Fusion 360. On the TurboCAD forum a ship's hull is something like the Holy Grail of lofting. How do incorporate the station lines that couldn't be used in the loft + rails? It helps when all the stations have the same number of nodes. I sometimes add a node to account for a missing water line. The key is not so much that the added node is on the same plane as the water line as it is that the computer can loft "node to node" (I just made that phrase up). How do I close up the shape at the bow? Think of the rabbet on the stem as a kind of station line, draw it and loft to it. This will get you in the ball park but is not the total answer. Come to think of it, I'm not sure anyone really knows the total answer. At the gripe a lofting will do some funny things. Of course, added stations at the bow will facilitate things quite a bit. How do I force curved edges of a body like the one below into straight lines that can bend at sharp angles? Your picture illustrates the basic problem of lofting a hull. You can think of the lofting process as akin to the computer connecting your stations with splines (with the fit points falling on the stations). Now, in your illustration the lowest spline (so to speak) takes a downward drift in order to set up for the hard upward turn. Doesn't it look like a driver who swings wide left to then turn right? The closer the stations are to one another the less the swing which is why adding stations can help. The same thing happens at the bow in the area of the gripe. At the rail the problem is evident again, but is more easily fixed by using the rail line to create a loft which is then subtracted from the hull. Now for the necessary disclaimer. I am not trained in CAD nor do I work in the field. The above is the result of my own experience. I remain open to a more perfect way and bow to the expertise of others. Wayne
  10. Mark, I found this and it may solve your problem. My copy of F360 refuses to load for some reason so I can't check it out, but it sounds to me like the answer you need. https://forums.autodesk.com/t5/fusion-360-design-validate/rotating-3d-wood-material-in-render-mode/m-p/7905382#M155048 Wayne
  11. A work around for TC Deluxe is to put your monogram on the barrel, then create a tube around that section of the barrel that has an inside hole that matches the barrel as to angle but is (say) an inch larger in diameter. Then subtract the tube from the monogram and you will be left with an upper surface of the monogram that is curved with a radius parallel to the barrel. Takes but a minute.
  12. Breathtaking. The level of detail is amazing. Congratulations on your work. It seem to me you must have a very large file for this project. Can you give us an insight into how large? What are your render times for the complete model? And, just because of curiosity, what is your computer set up? I would guess you have a pretty good bit of horsepower. Thanks so much for sharing. Wayne
  13. See above post #22. Does Solidworks have something called a Style Spline and is that the same thing as a Bezier? I can spell Solidworks and that exhausts my knowledge of the program. I may be confusing you by using the names given to spline tools in TurboCAD. At this point, it seems to me that splines and their control points all use the same equations, but differ in how one manipulates the control points. To be sure, I am not the person to opine here in that my acquaintance with mathematics falls in the interested hobbyist category. There are videos on YouTube that explain Beziers and the history thereof using basic algebra. That and a series of Google searches constitute the foundation of my awareness of the math involved. Wayne
  14. I am with Druxey on this. Take a look at this part of EdT's log on the Naiad (a vessel of similar size and construction). This is page two of his log, Find post #57 and begin reading. You will find many helpful photographs of how the internal planking might be done. As a further caveat, Steel says that the limber strake is drawn on the inboard profile plan as a line parallel to the cutting down line (which amounts to the bottom of the keelson). On Steel's plates this line for the limber strake runs the length of the keelson, although as Druxey ponts out it is fairly impossible to place a single plank this entire length and so the channel ends much sooner The original plan from RMG shows the limber strake line the full length of the keelson. I did not build Euryalus. Perhaps Allan can give us some better insight here. Wayne
  15. You ready for this bit of wisdom? It depends. I used something that TurboCAD calls Beziers which is fit points plus control handles for every point. I have more trouble with the other versions of the spline (by control or by fit points). I find "fit points" easier to use than "control points" and Bezier easiest among the three. So I would say use what makes the most sense to you. I would expect there to be a learning curve on using splines. rtwpsom2 says he prefers the control point splines to Beziers, I have the opposite preference, mostly on the basis of what I am most accustomed to using. I like Beziers but have seen some lines drawn with fit points and control points that were just as good. Use what falls most easily under your mouse. There are folks on this forum who do CAD for a living, and I would greatly appreciate reading their insights on this. My CAD work and knowledge is purely that of the interested amateur. Lately, however, I have been trying to use arcs rather than splines. Sometimes that works out, sometimes it may be more trouble than it's worth. I hope this helps. Wayne
