RGL
Everything posted by RGL
  1. Denier line, I pre planned still the belaying points then use different thickness denier line m, stays are thicker than running, halyards are pale and thin, you have to use thin CA to attach denier line
  2. 3D printed search lights, scratch built search light controllers, masts painted and navigation lights added to the tops
  3. Starting to look like a ship! Funnels and bridge added, then a dry fit of the masts
  4. Done, more weathering when the base is done
  5. That’s coming up nicely, if I may make a suggestion, a few layers of close coat with some foam or spume layered between? Just use a rattle can
  6. Bridge done up with 3 fife rails scratch made. This is the silver grey colour which she had in 1914
  7. As you are aware, the brass is waaay to bright, so dulled down with some diluted green then a wash. Coaling scuttle’s added and a wash to dirty them up. By the time all the dockside dealings added this will just be background canvass.
  8. Got a new light, I’m constantly looking for better illumination Base coat down!
  9. Wooden stick on deck. Sprayed with a tan to get rid of the pre chewed look. I’ll give it a clear coat so it can be weathered
  10. Emdens deck, two shades of brown; this was linoleum and I imagine it would get a bit of fade in the tropics. It comes up black in the old photos but would have been burnt. I’ve given it a clear coat and will mask it when dry. Next is to paint the hull before I can remove the mask and add the brass hold down strips
  11. Continuing to work in the grunge, when upon close inspection I can see seam lines and putty. More sanding to do the patch work repairs and I’ll redo the boot strap and I want to make it a little more defined .
