Everything posted by Hubac's Historian
So, Dan is correct for the 18th century, but only nails would be appropriate in the seventeenth century. One point for clarification: what exactly is meant by "dead" and "lively" works? Are the dead works the framing of the bow, or are dead works the wales and lively works the planking? This discussion does bring to mind the timber remains that were ressurected from under the parking lot in Cherbourg. If memory serves, there is a picture of a massive timber, which appears to be a section of keel. Whether there is any evidence of tree-nailing vs, iron bolts I can't say from memory, but these are reputed to be the ships (along with SR) that were burned at La Hogue. I believe they found five wrecks. Also of note are the remains of La Belle, which is a good example of a late 17th Century merchant ship. I will investigate these matters and see what there might be able to see.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
So it seems we have a solid concensus among our French speaking friends: the anchor lining was simply a double thick plank trimmed down into the shape of the lining and faired back to the level of the surrounding planking. So, to answer the earlier question about fastenning, it seems that Dan's answer is the best and most probable. For my model, I think this means that I must fill-in all of the current sweep plank lines and re-scribe to match the surrounding plank lines. The problem I see has to do with a few completely non-sensible lines that are really close to the wales. This is one of the pitfalls of the plastic model. I think the solution - the compromise - is to ignore those lines that are too narrow, because raised to the level of the wales they will really stand out, and then scribe to match the others. Thanks for that insight, guys! And Cedric, don't worry; the planning you are doing now will save you many headaches throughout your build. I was equally frustrated when my drawing ground to a halt, but doing some detail work on the hull has re-invigorated my excitement, as I see the small details I drew come to life. Those gains will sustain me for a while, when I eventually am forced back to the drawing board so that I can at least work out the quarter galleries and all of the large figures that surround them. I am hopeful that changing internet providers will solve the problem, as Spectrum/Time Warner is really terrible. Maybe it's just a matter of my modem being too dated. Maybe, at least for a little while, FIOS will be better until it just isn't anymore. Maybe, maybe, but I am not a computer guy.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Here is the link to Cedric's build of La Reyne: Astounding concept!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
That's a fascinating detail about the double-thick planks, Marc. Was that a particularly French practice, or one more generally in use throughout Europe? I have also seen before this detail of running the filling plank between the lower main wales all the way to the stem. Again, I'm wondering whether that was particular to the French. Last night, I happened to be filling this area in, and I chose to shape the plank in line with the forward and aft curvatures, instead of to the stem. The choice was based, mostly, on observation, but also for aesthetic purposes.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Marc, you chose well to apply your surgical skills to medicine, where you can earn a nice living, but they are equally on display in your woodworking. The joinery is superb, and really holds up under scrutiny.
- 208 replies
- le soleil royal
- 104 guns
Absolutely, a pictorial history of setting the masts and spars would be of great interest! I appreciate the time crunch of modern living, though. Like you, I am using Anderson and also Lees to rig the model. Anderson will be particularly helpful for determining mast and spar dimensions, which I will need to do soon, because I will have to step shortenned masts onto the hull platten/base before I go too far with the actual build. I'll be looking in on you frequently for tips and solutions to the more vexing problems, as this will be my first serious attempt to rig a model. the last time I visited the Constitution was 6-7 years ago. Might we have crossed paths then? All the best, Marc
- 196 replies
- plastic
- soleil royal
Actually, like me, he is using the plastic shells. Most of it will be scratch-built, though
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Maybe, my friend, but I will say that what Cedric is doing to convert the kit into La Reyne is the ulimate kit-bash and he deserves all the glory for even attempting it.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Also, to answer your questions: I'm not absolutely positive, but the ends of each plank were possibly nailed with two nails, but probably tree-nailed, and then tree-nailed in-between on frame locations.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Those are excellent questions. What I can tell you is that the anchor lining protects the hull and wales from the anchor flukes as they ship the anchor out of the water and then lash it to the channels, so it's shape follows the arc or sweep of the flukes during this manouvre. The sweep does seem extreme, and that leading corner sharp (and perhaps more prone to rot), but what I am doing (as with most things I am doing on this model) reflects the artitst's view of what I have seen in contemporary sources. I am trying, through my research, to include the missing details of a period ship of this type; the details that should be there, but the execution is always a visual interpretation. I literally just draw directly on the hull until I like any given layout. A good example of my basis for this detail, and its execution, can be found in this Van de Velve portrait of the French warship Neptune, which was a contemporary of SR. http://collections.rmg.co.uk/collections/objects/136158.html In the end, I am interpreting, with my artistic eye, another artist's view of the actual object, which would be subject to perspective and their own artistic choices. As such, these choices are always vulnerable to error. I try, whenever possible, however, to base my choices on the most reliable artistic sources - the Van de Velde family.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Thank you for explaining your process, Marc. All of that seems like a well-reasoned approach and the fairness of your hull and wales and ports is the proof.
- 208 replies
- le soleil royal
- 104 guns
I've been slowly organising the bow structures. The hawser inserts have been glued in, re-inforced along the back edge, and faired with a little putty. That enabled me to layout and engrave the "hunting ports," simply copying the 1" spacing of the guns that preceed it. Honestly, I feel I may have engraved a little too deeply, but there will be several layers of paint and a series of washes that will minimize that to a degree. The hinge strops were cut from thin styrene sheet, and although it is not really visible in the following pictures, I was able to nicely simulate the hinge strap nail heads, by pressing the point of a common sewing pin into the back of each strap, three times. I still need to make small ring pulls for the port lid lifts, but I'll have to experiment to find a method and material that looks good in scale - they are so tiny! I'm learning a few things about tiny metal work on Popeye2Sea's SR build log, right now. The work he's doing, there, is really astounding! In the meantime, though, I am building up the anchor linings. These pictures don't show it, but there will be a filling piece between the lower main wales. After gluing in the first strake, parallel with the lower main wale, I realised that I would need to adjust and taper the second strake so that the following strakes aligned better with the planking and middle wales. Maybe I should have redone and made this adjustment on the first strake, but I think if it really bothers me, I can putty the joint between 1 and 2 and re-scribe; there-in lies the beauty of plastic. To finish, the anchor linings will he sanded flush and for texture with really coarse 50 or 60 grit paper. I will simulate their treenailing, just as I eventually will for the rest of the hull with the tip of a hypodermic syringe.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Hello Henry, I've been reading through your build log with great interest and amazement at your scale rigging achievements. Your metal work (chandlery) is some of the best I've seen, and I am heartened by many of the suggestions for improving the appearance of the carriages. I know you have discussed the outboard to inboard leads of sheets and tacks - and all of the inherent problems the kit presents on that subject - but I wonder what your thoughts are on chesstrees. Since I won't be using my kit's quarter galleries, I am thinking about salvaging the greenman figures from the quarter deck windows and using them as chesstrees. I suppose a lion face would be more period appropriate, but a greenman is not un-precedented. What are yor thoughts on chesstrees? Kind regards, Marc
- 196 replies
- plastic
- soleil royal
I suppose I see, now that your wale locations are indicated on the bulkhead patterns, but what about the rest of the layout? Going that extra step will certainly assist your efforts to convincingly tree-nail the model, as is evident in other pictures I've seen of your exterior planking. And one more question for the evening! It would seem that the un-planked balsa/bulkhead hull would be fairly fragile, however, as your planking progresses, have you noticed that the model both seems and is substantially more solid/rigid?
- 208 replies
- le soleil royal
- 104 guns
A few points of curiosity for me, Marc: With regard to your plywood bulkheads, it appears that the lower section of each bulkhead is a separate piece, before the filling of the balsa. It appears to coincide with a particular waterline. Just wondering why? Also, I'm wondering about the first layer of planking that comes up to just beneath the main wale. It seems that it is perfectly flush with the surface of the faired-in bulkheads and balsa, which would mean that you had to have first cut a rebate into the bulkhead frames before assembling anything. It's hard to see, but this appears to be the case. I'm just curious as to why you wouldn't lay down a first layer of planking over the entire hull. The rebate seems like an extra step, although I'm sure you had good reason for doing it this way. One more question: your layout of the wales and all of what would be the actual framing, onto the un-planked hull is all perfectly fair and straight and regular looking. How do you go about transferring curved lines onto a curved object and have it all look so neat? Also, I like your solution to shaping the headers of the quarter deck ports; very clean!
- 208 replies
- le soleil royal
- 104 guns
I have taken many of my cues from both Marc and Michel because they are they only two I know of to fully immerse themselves in study of the ship. I am so glad that you are posting here, now, Marc! As I say to everyone who doesn't know your ship, your work is peerless, and this model I think, when it is complete, will become the grandest vision of what the ship once was. I am personally indebted to both you and Michel for freely sharing information and your passion for one of the least understood "Great" ships. I'll certainly be following with great interest!
- 208 replies
- le soleil royal
- 104 guns
While I love this Bakhuizen portrait, I agree that he is to be taken with a grain of salt. The Van de Veldes are a different animal, though. They hold a much higher degree of credibility, in my book, because there is such good consistency among portraits of their better known English and Dutch subjects. From a construction standpoint, it would simply make more sense to have support at the extreme edges of what is already a lightly built, and vulnerable structure. But one can never go wrong to follow what is known, and that is Berain's intended decor. Ultimately, I will mock it up both ways, when the time comes for that, and see which makes more visual sense to me.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
For half a minute, I considered simply adding extra figures at the corners, as I will soon have extras from Popeye2Sea but that would spoil the thematic harmony of the decor; there are only four seasons, not six. Although, here in New York, it only seems as though we have two seasons.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
I also believe that this is what is intended by the stern and quarter drawings by Berain. Lately, though, I have been stuck on an idea about how exactly, that main deck (I had mistakenly written "quarter deck" balcony, above, but that is the top most, single window on the QG) gallery is to be supported, where the corner wraps to the QG. What I'm looking at and thinking about is an enlargement from this Van de Velde attributed painting of the Battle of Barfleur. I wonder whether you have seen this work before, Marc: Soleil Royal is facing off against Britannia, in the center of the painting. The painting, itself, is quite large: 4' x 8', which would mean that the section containing SR would, itself, be large enough to discern some sense of detail, if only one could view it in person. The trouble is that nobody seems to know where this painting currently resides. It is most likely in private collection. Anyway, when one enlarges SR, and focuses on the area where the corbel supports to the main deck stern balcony reside, it appears that the outer figures of Winter and Fall are placed a bit further outboard than shown in the Berain stern drawing - such that the arms of these figures appear to literally support the corners of the stern balcony where it wraps to the quarter galleries. You'll have to maximize the image in your home browser (is best to get a big enlargement) to even see the fuzzy detail that I'm referring to, but it seems possible (and practical, for that matter) that the builders might have made small variances from the intended ornament, in order to more reasonably support the stern balcony, at the vulnerable corners.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Welcome, Marc. I'm so glad you decided to bring your model to MSW ! The forum is in for a real treat.
Very interesting, Marc. The changes are subtle, but effective. Not only did you relieve dead space around the quarter deck guns, but you gave just enough breathing room to the frieze above that it does not look cramped. Most significantly, though, the acanthus escutcheons are better aligned with the gunports. Will your main deck stern balcony wrap to an open walk at the quarters, with the two-window amortissement set in low relief against the ship's side? Or will the quarter galleries be completely closed?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Marc, what specific aspect(s) of the quarter gallery did you have to change? Can you show an original and revised drawing?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Are you kidding?! If I think it would be "of some interest for you guys?" Marc, people need to see what you are doing. Your model is incredible and an interesting counter-point to Michel's equally impressive model. Of course, if it were up to me, this would be a site entirely devoted to Soleil Royal, but I am an obsessive fan of the ship . Please post pictures of your ship.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Hello NekO, Great to hear from you! Yes, thank you for your kind comments. The protective sweep of planking that matches the thickness of the wales; this is a detail I will be adding, just after I scribe in the "hunting port". I wanted to get the placement of the port right before adding in the sweep of thicker planks between it and the next port aft. My decision to scribe the hunting port - as opposed to actually cutting it in - is based mostly on the fact that it wasn't an armed port. Also, this is one detail where I can allow myself to be a little lazy and not go the extra mile. What's new with the Royal Balsa, these days?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
With the continuous bolting of the wales complete, I turned my attention to the hawser insert pieces, and I think I've done a fairly Doogie Hawser job of surgically in-letting the port side hawser piece. The issue at hand is the dark ridge that you see, here, on the starboard side. The planking is moulded and intended to be a smooth continuum, but the piece does not fit flush, and this is unnatural. However, after using my fabulous Dremmel Micro to cut a diminishing rebate into the mounting edge of the piece, the aft edge sits flush with the rest of the planking. This is not at all difficult to do, it is simply a matter of holding the piece in place, as you scribe the lower edge of the upper wale into the plastic, and the upper edge of the lower wale, with a single edge razor blade. An emmory board cleans up the transition and the piece fits perfectly. A little work on the aft joint, where it meets the hull, is required in order to minimize the need for putty - a touch of Squadron, though, and a little judicious leveling should make that transition line completely disappear. I will have to do the same on the starboard side, obviously, and I will also have to fill and re-drill the hawse-holes, back closer to the stem, after I have performed my magically surgical widening of the hull, at the stem. Just as the prior example illustrates my desire to make this model look less like the plastic kit that it is, the next example strives for a greater verisimilitude with real practice. Here, I am showing the transom profile, which previously, I had trimmed back a generous 1/16", to the mounting ledge for the transom piece. That's why the hull thickness seems so exaggerated, below the main wale, because it includes the mounting ledge. The reason for doing this was so that I can model-in the round-up of the square-tuck stern. However, even after grinding away the existing mounting ledge, the side planking still is way out of scale. Ordinarily, with plastic models of this type, one would glue in the transom piece, and then fill-in any gaps - and then maybe, maybe scribe back in the partially filled plank lines. As I will be building up the transom and stern from scratch, on the other hand, I saw this as an opportunity to thin the hull wall at the transom edge to a more scale-realistic plank thickness. Into which, I then engraved the plank butt-ends This process also creates, on the inboard hull a new mounting ledge for the transom planking that will be installed later. Rinse, and then repeat on the starboard side! Following that, I will glue in the hawser pieces, and then scribe-in and detail the 15th "hunting port," at the bow of the lower battery. As this is already a fairly long build-log, and I've only just gotten started, I will periodically mention "the truth," or what "should be." What the first battery should consist of is 16 piercings (to be consistent with what is known of SR1), with 15 armed at all times; the 16th "hunting" port at the bow would only be armed by shifting the next gun, aft, into position when SR (and La Reyne, for that matter) were appropriately in pursuit of the enemy. For my purposes, even a vestigial scribed 15th port - while it's not 16 - is still closer than 14. Comme-ci, Comme-ca; a compromise of sorts.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
