Everything posted by mtbediz
mtbediz replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Hi Greg, I used 0,7 mm brass wire. -
Hi Peter, I used a round nose pliers, needle-nose pliers and side cutter. I will tell you how I made the double eye bolts with photos tomorrow morning. It's not so difficult. -
If you mean the eyebolts on the gun beds, then yes, I won't be adding tackless to them. Because I added a tackle to a carronade to try it out and I didn't like the look because it looked too crowded. After all, the model is ours, we can do whatever we want. -
Great job Greg. I don't know the quality of the ropes you're going to use for the rigging, but if there is any fuzz on the ropes, a quick run of a lighter flame over the ropes will remove the fuzz and make it look much better. Just a tip before you start.
- 58 replies
- Santa Maria
- Ships of Pavel Nikitin
I admire Xken's metalwork, but there's no way I'll ever reach that level. I didn't try to join the rods together by making a central hub, I concentrated on joining them together by soldering neatly in the centre. Because I couldn't convince myself that I could make such a hub to scale. After a few unsuccessful attempts I found a method that gave me a satisfactory result. As can be seen in the photos I fixed the 0,7 mm diameter rods on a flat surface and soldered them all together in the centre. Here only the diagonal rods are in single piece, the other four are separate pieces. I then bent the rods using a jig and fixed it to a jig to solder the horizontal rods. I find the result satisfactory but the excess solders still need to be filed down. -
Yes Peter, that's the plan. -
All fife rails are complete. At this stage I decided to make the canopies. While making the canopies I will solder the connection points. I will not be able to make the cube shaped elements in the connection points on the real ship in this scale. The canopy in the photo is a prototype I made to design how to do the job. I will not use it. Now I am working on a jig that will do this job properly. -
Yes Peter, I exactly drilled them with a 1 mm diameter drill bit. -
Thank you Phil. Pickle was a great rest stop for me after Essex. -
I answered because I knew it would be difficult for you to find the answer you were looking for in my log. I didn't want you to get tired -
Thanks Greg. Yes, the masts go under the gun deck and fit into slots in the false keel. You can see these slots in the MS kit plan. You can also see the mast holes in the gun deck in the photo. -
Thank you Jon. I was very inspired by your work when I started building this model and I still benefit from it. I would be happy if I could help others too. -
Thanks Greg. I have a basic DB250 and a FD150 lathe. I don't have a PD250. I used the DB250 when I made the fife rail stanchions. You can work soft metals like brass, aluminum and copper with all three lathes. I bought the FD150 about two years ago and haven't had much use for it. The FD150 and PD250 are lathes that require a bit more skill. If you are thinking of buying a lathe, I would recommend getting the basic DB250 first. If I had my thoughts back then I would reconsider buying the FD150. They are quite expensive machines and I still don't know how much use I will get out of them. If I had to choose between the FD150 and the PD250 right now I would choose the PD250 because the FD150 is a very short lathe and a bit of a pain to work with. -
The rigging of all the guns are complete and I started making the fife rails. First I fabricated ridding bitt knees. To make the stancions I shaped the 4x4 mm pear bar with a file on the lathe then I opened holes and channels to represent the sheaves. -
If you used CA when gluing the carriage parts, you can try using pure acetone to separate them without damaging the parts. Pure acetone has the ability to dissolve dried CA. I have done this from time to time. But you should use pure acetone, that is, the diluted acetone that women use to remove nail polish does not work.
Thank you Greg. Now that I think about it, it would have been better if I had stained the blocks, but I just applied matte varnish. -
Thank you so much.
