mtbediz
Everything posted by mtbediz
  1. Yes I can see the concept. I was lazy and didn't add this piece under the gun bed in the plans because it wasn't very visible Here is my concept;
  2. It is time to prepare the carronades that will be placed at the aft of the ship. I painted and varnished the carronades. I cut the capsquares from brass sheet, shaped them with the help of a simple tool I made, drilled the necessary holes and blackened them. The next job will be to secure the carronades to the carriages. When everything is put together they will look like in the last photos. I produce the breeching ropes myself with my homemade ropewalk.
  3. Since I am building this model from scratch, I will need to make this ornament on the bow somehow, but I still don't know how to do it. I hope you find an easy way to do this and I can copy the method.
  4. I've never worked with plexiglass. I had dreamed of cutting the deck as a whole from plexiglass. Of course, cutting it into strips and gluing them can also be considered. But since the plexiglass is transparent, I do not know whether the adhesive layer to be applied will cause a bad appearance. I think that if we cut and glue the deck as a whole, we can more easily camouflage the stains that will arise from the glue.
  5. Dear friends, thank you all so much for the encouraging comments.
  6. Thank you Peter. I really like the idea of a transparent plexiglass/acrylic deck. I never thought about doing this because I had never heard or seen it before, but I loved the idea. Later on another model I will use this idea, it would be really interesting.
  7. Spar deck planking at the aft of the ship has been completed.
  8. I don't stain, Greg. I only apply matte varnish. I made the gun deck the same way.
  9. Greg, I actually decided yesterday how to plank the spar deck. Of course, I had a few options in mind, but I waited for the carriages to be completed before deciding. That way, with the trials, I would have an idea of what the overall look would be like. I applied the options in my mind without gluing the planks and decided the composition seen in the photos, which I thought would not disrupt the integrity of the model. I am undecided whether to plank the center line of the ship yet. I am using 3x1,5 mm hornbeam wood for the spar deck planking.
  10. I started planking the zones of the spar deck that will be under the carronades. As I said before; I will partially plank the spar deck so that the details on the gun deck will be visible.
  11. You can try cutting from 0.5 mm veneer with a sharp blade. I don't think it will be very difficult.
  12. Thanks for your comments gentlemen. I'm on the dark gray side too. I'm guessing it will take on more of a metal look once it's varnished.
  13. Thank you so much for your contributions my friends. I decided to paint the carronades as I found it more appropriate to match the general appearance of the ship. I made two attempts for this, painting one of the guns black and the other dark gray. The black doesn't look very realistic to me, as if the dark gray one is closer to the guns on the real ship. Do you have any idea my friends? Thanks.
  14. Thanks for the feedback, Jon. Before applying chemicals, I soaked the Carronades in alcohol to clean them, but it seems that this did not help much. Now I will try acetone as you suggested. The worn-out look of the carronades also attracted me, but they seemed incompatible with the rest of the ship. A uniform finish would make it look more elegant, and a look like the one in the photo Peter posted would be more appropriate.
  15. I tried to blacken the carronades with chemicals, but it looked like this. Carronade did not blacken everywhere, but it looked as if it had been worn out. Now I will have to decide whether to leave the carronades like this or paint them black. Anyone have an idea?
  16. It's a shame you're having trouble building the kit. The fact that some laser cut parts do not fit properly can be tolerated and overcome to some extent, but sending missing material is unacceptable. You're doing a great job, Greg.
  17. The carriages were painted red and the trucks were installed.
  18. Hi Greg, thanks. The holes that will represent the bolts are not very deep, they are just a mark on the surface (I would say 0.2-0.3 mm deep). Therefore, I will not fill it with anything, I will just paint the carriage red and leave a mark inside these holes with a mechanical pencil. I tried it on the prototype before and saw how it would look, here is the photo.
  19. I continue to build gun carriages. I spend a lot of time because there are so many details. I drilled holes on the bases to represent the bolts, I glued the gun beds onto the bases, I am making the carriage trucks out of wood because I dont have the tools or skills to make them out of metal on this scale, they won't be very visible anyway.
  20. A very good decision wishing you and your family a Merry Christmas and a Happy New Year.
  21. Thank you very much Jon, I also thank my milling machine, it does a really good job. Every home needs one.
