mtbediz
Everything posted by mtbediz
  1. To plank completely correctly, spiling is required, particularly from the lower end of the wales to the keel. However, we don't know if the wood Dave will use for the second layer planking will allow for lateral bending.
  2. I noticed this too. Your ship has a Bluff bow. Making the garboard shorter seems difficult. To create a planking pattern that matches the photo you've attached, you can apply a planking pattern similar to the one I've tried to draw on your photo in the second layer. To do this, you could end the planking from the bulwark down to the lower end of the wales, then work your way up from the keel. Sorry, I am not good at drawing on the computer but I think you can understand what I wanted to show.
  3. Yes, I guess with that thought, I also mounted the pin rails in place before the carronades.
  4. Yes, Greg, I visited that historic monastery. It's an incredible structure. The Sumela Monastery is a Greek Orthodox church built in 386 AD. The exact time it took to complete is unknown. It's located within the borders of Trabzon province on the Black Sea coast of northern Türkiye. Detailed information about the church is in the Wikipedia link below. https://en.wikipedia.org/wiki/Sumela_Monastery
  5. Sorry for the late reply, Peter. I don't actually remember why I installed the pin rails before the carronades. It would probably have been more appropriate to install them after the carronades.
  6. Yes, this is the right approach. In my Essex model, I frequently encountered this question: "Well, didn't the sailors fall through these gaps?"
  7. I only faired the first bulkhead in the bow before gluing it in place, because that one had a lot of sanding to do. I used my sanding macine to do it.
  8. Not really! Just sitting by the pool, sipping my vodka and watching my grand daughter Bon appetit to you too.
  9. For sure it is hot! but not where I am sitting down right now
  10. I hate to say it, but your garboard planks are unfortunately incorrect. They've climbed too high, which will cause plank congestion in the bow later. If you want to plank your ship correctly, remove the garboards now and remake them as shown in the photos. If your ship has a second layer planking, take this into consideration when making the second layer planking. Other than that, everything is going great so far.
  11. I'm so sorry if I'm bothering you, Peter. I'm just trying to understand and help. I know you won't remake them all over. If you used pre-made eyebolts, it was even easier. All you had to do was to bend the hooks perpendicular to the eyelets. Just keep that in mind for future hooks.
  12. I make the eyelet first, then bend the hook part perpendicular to the eyelet so I don't need to twist the hook. I know it's too late to tell you this, but keep that in mind; you'll want to try doing it like this on your next build.
  13. Welcome to the forum. The result you've achieved so far with limited hand tools on this challenging model is truly impressive. There are a few other modelers in this forum, including myself, who are building the same model and sharing insights. You might find inspiration by joining us and seeing how we tackle various challenges.
  14. Sorry, Greg. I've been away for a while and didn't realize you'd started building the Constitution. I used a scroll saw to cut the gun-deck curves on the bulkheads.
  15. Greg, I have a reversible hand drill like in the photo. I use it when necessary.
  16. Peter, when drilling soft and thin woods before, turning the drill in the opposite direction helped me drill without splitting the wood. This information may come in handy in the future.
  17. Let me also point this out, I cut the pieces a little larger and do fine tuning with sanding machine.
  18. Drilling first and then cutting usually gives better results and reduces scrap. That's how I usually do it."
  19. Your model looks great Peter. Just curious, did you ever consider leaving the gun port lids open?
