Everything posted by mtbediz
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
Hello friends. I haven't posted the photos for a while but that doesn't mean I am not working on my Santa I was just lazy to post the updates. Apologies my followers (if I have followers ) I am sharing what I have done so far without text. By the way I am modifying the kit trying not to use some metal cast object and making them from wood as much as possible.
- 54 replies
- mantua
- santa maria
Thank you so much my friend. I am following your build with a big interest and inspiring. This is my second Santa Maria build, if you are interested I have a log for it on MSW as well.
- 54 replies
- mantua
- santa maria
I built up the forecastle bulwark and did the planking bulwark outside. I used the laser cut rail of the poop deck and planked rail inside and outside.
- 54 replies
- mantua
- santa maria
Forecastle, channels and the rudder are in place. The forecastle deck was planked wıth 2x3 mm walnut strips. The rudder and the chammels were planked with 1x4 mm walnut strips.
- 54 replies
- mantua
- santa maria
I finished the second planking. After a light sanding I glued the wales and futtock riders. I used 2x4 mm walnut strips for wales and 2 layers of 2x4 mm walnut strips for the futtock riders.
- 54 replies
- mantua
- santa maria
The second planking is complete. Dear friends, I would like to ask that if it is a good idea to add the treenails or false nails on the hull of this model. What do you recommend? Thanks in advance. Scale of the model is 1:50
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
The second layer of planking of the hull continues. The port side is complete and the other side is close to the finish.
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
- 54 replies
- mantua
- santa maria
Hello friends. Due to the problem with my laptop I have not been able to post the updates on my SM for a while. I installed all the decks and planked them, I attached side sheets and did the bulwarks inner plankings, completed hull first planking with 1,5x5 mm basswood strips instead of 2x5 mm balsa strips given with the kit. I completed stern planking. I started the second planking of the hull with 1x4 mm walnut strips given with the kit. Here are the updates.
- 54 replies
- mantua
- santa maria
I decided to make treenails with the toothpicks. I drill 0,8 mm of holes on the planks and insert the toothpicks with a little PVA. After glue dries I snap the toothspicks off and sand the suface for finishing. By the way, I glued the poop deck as well.
- 54 replies
- mantua
- santa maria
All of the decks given in the kit have simulated planking on them but I will cover them with walnut strips to get a more realistic look.
- 54 replies
- mantua
- santa maria
