rwiederrich
  1. Pat....after agonizing (sic) over the selection of the plan....and now to enjoy your execution....is a thrill. This is in keeping with your acute attention to detail. Fantastic job! Victoria is looking awesome. Rigging her will be equally so. Rob
  2. Hang in there Keith. Along with experience comes confidence. You'll piece it together. The principles of standing and running rigging are generally universal.....so if you can grasp the simplistics of each group...you should be able to do well. We'll be here....if you need a hug. Rob
  3. I finished up the initial planking and began adding wood filler. I know it looks rough....but a goodly amount of sanding and several coats of filler aught to do the trick nicely. Rob
  4. Here we go....blocking it up and making its bulkheads true...... Guess the bug bit ya hard Vlad...... Glad you're making a go at it too. I'll be watchin closely. Rob
  5. Rich...it should be you who needs to be encouraged. Even though you have crossed this bridge before...it never is easy and I will continue to pray for a quick recovery and comfort for you and your wife/family. I hope, in some small way, I can provide a distraction from what is really a challenge. My techniques are generally unorthodox and in turn, produces their own special set of problems. Still....if I can point out any pitfalls with any process....I always will. The mess is always forgotten when the final result is achieved. And as is my habit....I'll use whatever medium is at my disposal to achieve my desired results. Cuz....paint covers a multitude of sins. Heal fast and stay encouraged. Rob
  6. I know I'm kinda late coming in here...but what kind of wood filler did you use...if I may ask? Rob
  7. I aided the planks by brushing construction glue over them..both inside and out. this way...when sanding the planks will not flex separate of each other and prevent a smooth surface. One thing I'm a bit concerned about is that not all the frame bulkheads transition smoothly to the next. When I flared the bulkheads I check each to its neighbor with a plank and assumed they all followed the same way. But I discovered that I should have gone the extra mile and laid out a string pattern across the bulkheads to check more closely the smooth transition between bulkheads. I'm sure the issue was not in design of the bulkheads but more in my assembly. Many of the bulkheads fit the keel plate somewhat loosely....and even after my aligning and squaring of them I could have misaligned the bulkheads in question when I assembled and glued them all together. All these small issues are associated with fit of the components and my misreading of it during construction. No matter......a goodly amount of sanding will copious amounts of filler compound and we will be smoothed out. Rob
  8. Indeed. And if I need to, I will also trowel a thin coat of dental compound over the wood hull to smooth out any uncanny defects that sanding alone won’t correct.
  9. Did some work tonight...I finished up the starboard side and am 1/3 finished with the port. Lots of sanding and filling are in order too. #10 is too large and #3 is too short or narrow. Rob
  10. I've hooked you Vlad. Several slight issues I have identified. Several bulkheads are slightly out of contour...causing the planks to slightly deviate from a smooth surface(this can be corrected with wood filler). I found that while sanding...there is some flex of the planks because the space between the bulkheads is slightly excessive. So I remedied this by applying a good coat of wood glue to the inside of the planks..which when dry will significantly stiffen or make rigged the planks seams. I'm using CA glue and accelerant so things are moving quickly. The port side has reached the section where each plank will need to be modified to compensate for the curves that intersect. Today I hope to gain some ground. I plan on finishing both sides before I add the gunwales. I want to paint the waterways and probably add the deck before I do finish the gunwales. I determined that if I were to finish the gunwales first...before the deck, I would have a tough time sanding and finishing the deck without interference and possible damage to them. So that is my plan....currently. Rob
  11. Rich, remember, I have much work to do on her stem and I need to cut her strakes to mimic the stem as it abuts the hull. Plus the over exaggerating of the planks at the beak of the bow at the head of the forecastle will also be reduced and the sheer of the monkey rail will be refined
  12. Again...don't worry about the stem or stern or keel. I have to thin them down and make sure the strake junctions are clean and tight. This is the method I prefer..because it allows me great latitude when trimming and filling. Then these members simply get glued on. Rob
  13. All the contour errors have been since filled in...but here is the beginning of the transition from the bottom to the front which sees the most plank corrections.
  14. Don't get all upset over my process..... I will cut the stem and stern post and add them after the planking are done. A bit unorthodox, but it works for my process better. I did a slight amount of sanding and determined that to prevent any flex of the planks I needed to apply a copious amount of wood glue to the interior of the planks....after that dries things will be far more rigid. Rob
  15. Spend some time in the shop laying down planking....lots of sanding to follow. here is today's work.
  16. I spent a little time on the hull last night after a busy day of church and picnic. I began to install the strakes and plank the hull. Like as in the Flying Fish build Log, I first added the waterways and the planksheer. My metal clamps work very well too. I'll work on it again today for a bit and will provide some images then. Rob
  17. I wish to explain to our visitors who may have questions about this log. My intent was to build a scale model of Glory of the Seas...the last clipper built by shipwright Donald McKay (Unlike my first attempt which suffered from many inaccuracies. On these pages can be found its discontinued build log)). The initial model You see on these pages was built by me to identify errors in the original plans drawn up by author and historian Michael MJelde and to make experiments with certain building materials and techniques....that may or may not be used in the actual construction of the true to scale model of the same. Its scale was 1/72 As the discussion continued and collection of data came in during research and contributions to the project of other *Glory enthusiasts* became more mature and final.... A new and more accurate model was begun on the ways.....the most recent and current pages reflect that effort. I hope to now continue with the log as a complete construction of said vessel in the newly posted scale of 1/96. Thank you for your patients and understanding as we(my fellow enthusiasts)....and I, specifically, now set out to scratch build from newly developed plans this magnificent last American (West coast) clipper. Rob
  18. Vlad...the most important issue was keeping the keel all level and true to itself. That is why I made the jig to align and hold the keel straight while I fashioned the bulkhead braces. This ensured the hull would be straight prior to planking. And planking itself can put stresses on the hull...if you don't plank both sides simultaneously. Rob
  19. When fairing the bulkheads using planking, it was evident several bulkheads had been over extended. I laid the planking on the bulkheads to establish continuity of form and I discovered the error. I simply sanded them into proper contour. And then rechecked.
