rwiederrich
  1. No my friend.......a dental hand piece or a Dremel and some cut-off wheels
  2. I'll be making lots more. In conjunction with my angle control wood ones I aught to be ready for planking. I received all the scale deck planking today from BlueJacket as well..... Rob
  3. Here are few other angles and a demonstration image of how it works. these are easy to make and anyone can make them. They hold tight and secure. Rob
  4. Spent a bit of time today modifying spring clamps to be my planking clamps. This is just a few of them......notice the cut out. This holds down the plank as the clamp grips the bulkhead...all in one.
  5. Vladimir....I recall when we first encountered and you had just begun or shortly begun your Cutty Sark build. I was telling you of my passion for American clippers and especially for Donald McKay clippers. You became enchanted as much as I . I had initially begun my own study for my first build of Glory over 14 years ago and started the composite model in 2010. It is amazing to me to see where it has all come. I met Richard several years ago and he explained of his own passions for Glory. It wasn't until Richard and I began a serious study of Glory when you brought your own talents of design and Cad ability to the table. It probably wouldn't have happened as quickly and proficiently if we hadn't had the expertise of Mike Mjelde and his willingness to accommodate our desire to create the most accurate version of Glory that had been produced thus far. Now we find ourselves at the beginnings of your own Glory build. The results of a near year long compilation of many researchers and Glory historian buffs. What a fantastic journey. I can't wait. I will be following this log with great anticipation. I hope to be creating my own build log of her soon myself. We can bounce off one another on construction ideas and material uses. I have already developed another clamping system and am planning on mods to the framing to accommodate more to scale entrance and exit dimensions. Your participation in the fulfillment of this next build of Glory of the Seas cannot be underemphasized. I appreciate your willingness to help myself and Rich in the acquisition of your fine scaled bulkhead frames. It would be cool if someone like Nic of BlueJacket ship crafters would be interested in making Glory of the Seas a new addition to their fine line of finely crafter model kits. And here we go....... Rob
  6. One thing is interesting about name boards, they were typically removed while not in port. Open sea travel was a tough business and many items not removed and stewed away...... we’re washed away and lost. Some clippers even removed their figureheads in fear of losing them in a rough sea and then replacing them when in port for a showy effect.
  7. Well I started this thread in Aug of last year, but I was working on the plans for a hull build many months before that. I’m waiting for Vlad. No pressure on him, because he’s been awesome. I’ve also been working on another clamp design that I think will rock. I can’t wait.
  8. Well it has been a year since it all started. So now we’re waiting on the bulkheads and Vlad is busting that out as quickly as possible. I’m prepping as much as I can till then. By the way Vlad, I received the Glory book so now I need to set up a signing date with Mike. I assure you Keith you won’t die before I get started
  9. Well, I’m going to paint her black with a pearl white gunwal and houses and a soft blue waterway. She will probably have varnished yards and top masts. I will build her lower masts and probably paint the recesses between the iron bands white.
  10. Well there you go. I was sure there was a nautical term aloof to us all....identifying the condition. Thanx Sailor for enlightening us. Almost sounds frontierian...then nautical. Maybe so. Rob
  11. Model shipways makes a similar clamp. It clamps onto the bulkhead and the pins press down against the newly applied strake/plank. Basically the clamp does two things. It holds the new plank against the bulkhead while your glue sets...doing this by holding itself to the bulkhead just below the plank. The design is sound.....however...when the hull begins to curve at the bow and stern...the pins if not adjusted to the offset pin hole...will NOT comply with the bend of the hull. So I made some mods to accommodate that issue. Here's a crude drawing
  12. You are doing a wonderful job for sure. The top three images you chose to model....and I can see why..the sails are fuller and appear more active in the animation of their design....where as you suggested the last image the sails are trim and taught. This is easily seen by the fact the top 3 images the sheets are relaxed...allowing the sails to billow...where as the last image the sheets are drawn in tight and the sail is fully bent. In your example your sails are fully bent and you still achieved the fullness of the first 3 images. Sail(I know) can be arguably subjective. The point that you added them...and with functional accuracy demonstrates a knowledge of their function and control. And a sailing ship without her sails is either in port(where they would be stowed) or the modeler left them off to allow better viewing of their rigging details. Like yourself....I preferred to present my model(Great Republic and Glory of the Seas) as they would appear at sea...where she would have been most at home. The discriminating eye can find the finer details if they are modeled.....and sails and their rigging, make up part of the finer details. One last question: Did you add the jackstays to the yards then lash the sails to them....in your search for the *Finer* details? (And what about those gin blocks?) Rob
  13. This image shows the right pin in the lower slot for flat strakes......and the right pin removed and placed in the upper slot for strakes following the deep curve of the bow or stern. I modeled the clamps after one I saw on ModelExpo. They are made of hard maple. I'm getting as much done in preperation for this fantastic build. Rob
  14. In anticipation of getting some bulkheads from Vladimir...I have ordered decking and strake timbers for my Glory build. I ordered from several suppliers..wanting to ensure a good quality and quantity of timbers. In preparation..I spent some time in the shop today and I designed and made 10 identical planking/bulkhead clamps. They work by clamping onto the bulkhead and by way of steal pins...press down on the strake as it is drying to the bulkhead. In makign them I included a feature by way that the same clamp can hold strakes flat against the bulkheads that are amidship and by way of the right hand side pin that has two slots...I can use the upper slot for the strakes that are following the curve of the bow and stern...but maintaining a parallel clamping surface to the bulkhead. Here are the ten clamps all in a row. They use a wing nut and bolt to clamp the wings together against the bulkhead. Rob
  15. Wonderful work Bruma...excellent. You said you scratch built each yard....did you also make the gin blocks as well. I see you fashioned the truss for the lower topsail instead of using the Revell solution. Wonderful attention to detail. Will you be belaying all the sheets and bunt lines to their pins? She is coming along nicely. I am interested in your assembly approach....I constructed my Great Republic mast and yards off model for ease...did you do something similar? Awaiting your next install. Rob
  16. Interesting....however...I tend to believe this is just another optical illusion we are seeing. The curve of the bow viewed from below the profile can give the illusion it is bowing down...when, if you look at the drawings it does no such thing. The half model of the James Baines only reinforces this phenomena...because it to is viewed slightly below the profile. IMV....all we are seeing is the curve of the bow and from this particular angle it appears to bow down....going in its natural curve. Just hold a cup up and look at it from the side...its edge is flat...but then rotate it slightly so as to look at it from below its profile and the edge begins to bow down. My observations anyway. Rob
  17. Great pictures guys....really amazing stuff. I spoke to Mike as we prepare to meet again for another book signing and some good conversation. He informs me that he has been " 'revisiting' the construction period when Glory was under construction. It's going to help him understand better, fifty years removed, how she was actually built and what was entailed in doing so". In addition to Duncan Mcleann's accounts. It sounds exciting and I'm looking forward to any new conclusions. Rob
  18. Interesting for sure. I made 2 figureheads in that scale before. One of Athene on my 1/96 mod version......and the Highlander of the McKay clan for the Donald McKay
  19. And that means when using the laser cut bulkhead plywood for the keel and stem..you will need to sand it or replace it to just half of the 1/4 plywood thickness. If you want to be accurate. At up to this point we have been trying to be as accurate as possible. Rob
  20. Oh man.....that is running your own business math....I get to work and I forget everything....cept what I'm doing at work. Thanks for setting me straight Nic. Rob
  21. Thanks Nic....I knew it was 1/8"=1ft...an 3/32" I originally wrote those but changed them...cuz I was at work working from memory...an my memory is slippen it appears. Thanks for helpin an old man out. Hey...by the way...can I order just the wood strakes for planking the hull from say..... your Red Jacket kit? Rob
  22. ? Let me get that right. My great Republic was in 1/128...where 1/32"=1ft. So 1/96...3/16"=1ft? Or somewhere there abouts? I'm assuming the plywood used in making the bulkheads is about 3/16" thick. And if my calculations are correct...I will need to reduce the stem and stern boards by half.....to keep things in scale. One thing I dislike...is when a modeler(Myself included in the past) doesn't reduce the provided keel to keep it in scale...although every other aspect of their model is in scale. See what I mean from my own error...even though I had no choice to make this change with the Revell hull...it still looks out of scale and clumsy compared to the real ships stem. Rob
