rwiederrich
  1. Thanks Rich. As you recall….I made those boogers months ago. The slight cant is to permit unrestricted passing of the shrouds and their lanyards up toward the mizzenmast tops. As the stanchions pass the shrouds they begin to plumb up and go around the stern where they, again , cant inward behind the shrouds. Now, onto the cabin. Rob
  2. Thanks Vlad. Those stanchions are about 3/16” tall. Sweeehu. Tint stuff. Rob
  3. Well I went against my own judgment and I opted to go ahead and finish up the aft railing. I will add the iron bar rail at the head next. I got called away. Rob
  4. So much nicer, I think you’re there. I like the flatter windows Rob
  5. Great job Vlad...but I hate to point out this but the trim on the hood is double lobe on the top and triple lobe on the bottom. The top trim matches the trim of the plankshear. Love your sub-deck work..wonderful. Rob
  6. Right...you're talking about the brackets that supported the original wheelhouse roof overhang? Good observation.....I need to find that in an image if it is possible. Rob
  7. Nice to see we are on the same track.....in different scales. Wonderful. Rob
  8. I'm still certain there is ornamental bracketing on either side of the overhang....it only makes sense and would be in the context of the overall architecture and design of the building. IMV. Rob
  9. Thanks so much Arina....it is a real labor of love. So many of us are really putting in the time to make sure she is as accurate as possible. It is funny to think how this entire process evolved and how the right people came together with a similar passion. All of us standing in the wake of what Mike began so many years ago. Tell him we are getting along. Rob
  10. Yes....I'm not so sure the windows had a complete round top...it's all guess work from here....but curved can be an issue for craftsmen...since all other windows are square....I think adding them or not will not break the bank IMV. Rob
  11. I'm still curious about the doors Rich. If they swing, as Mike portrays...they are laying too flat against the house wall to be fully natural. But the presence of a door knob on the left of the door is very peculiar. that indicates the door is swung open fully...but the door appears to be wider then the opening for it. However, that opening is blocked by the machine structure in the foreground. Looking at the door frame to the right....in the same picture shows the door frame in relations to the window next to it. Suggesting the open doors entry is wide enough but is simply blocked from view as stated earlier. Back to the door......other images show sliding doors on the fore cabin and on the boys cabin....it would seam continuity would be in order and that the aft cabin doors would be sliders as well. The base edge of the door gives an indication that the door is a push, then slide to the right(from inside) style door. but that nasty door knob throws a wrench in the idea of a sliding door. Quite confusing for sure. Evidence leads us in several directions, without giving us truly any concrete answers. So if the doors swing out....and that is indeed the door knob...the doors swing out to the right and we are looking at the paneling of the inside of the door. Which is mimicking the paneling of the outside of the door.🤪. Looks like more artistic license is in store. Rob
  12. Great drawings Rich, but there are actually only 9 stanchions across the front not 10. The images you posted show this clearly. However, you windows and doors and the recessed panel work is super and I will try to incorporate these drawings in my impression and build. Rob
  13. Mikes drawing shows a curved house but the image on page 56 shows the rail for the house to be straight, if you look at it closely, plus the same image shows ornamentation where I suspected the two other doors. Rob
  14. Fantastic job your paint work is spot on it’s beautiful, took a lot of time I’m sure, steady hands. Rob
  15. It would seam if we were to follow the natural layout of the main cabin and dining hall the doors would follow this natural arrangement. Cept for the incorrect outward swing of the exterior doors which slid sideways. Rob
  16. Oh yeah.......my last build was her as originally built by Donald.....NOW...I'm stepping her up. I'll have two models of her...one as original and one as fully modified. Though there will be hull discrepancies(With old one), the deck houses and furniture will be to her original design. Donald was a spearheader by adding catwalks on his deck houses....namely on the Lightning and on the Donald McKay. Glory may not have had them originally...but they do mirror that of Donald McKay, as he was a visionary. It made access across the decks far easier and was actually a staple on many DownEasters and the larger German Iron Square Riggers. Now that I finished the channels and deadeyes......I'm going to work from the stern forward and begin work on the aft(Poop) carriage house and helm. I will work the house but not glue it down...cuz I want to be able to remove it so I can work on the rail. But I do not want to add the rail first, because it will get in the way of the carriage house construction. I need the room and space to add the railing because it will all be one piece. Its corrected forward stanchions, that are canted inward to allow for the shrouds and lanyards to freely pass to the tops will be determined with the cabin off the model. Its going to be a back-n-forth operation. Once the railing is established and secure......then and only then will I glue down the carriage house. Oh.....I hope others noticed that the leading edge of the overhang of the house does have an ornamental carved bracket. One on each side. Campbell draws one out in his cabin comparisons in his clipper ship book of American and British cabin designs. You can see the ornamental bracket just through the deck machinery of that photo of the deck house front. Rob
  17. Thanks Pat. When I have uninterrupted time, I can speed along. There is so much I do not include in my logs....a lot of back stage stuff...like the process in making the chainplates.....and channels. Those were completed days ago in assembly line fashion. I will now add the additional single channels and chainplates for her 2 additional backstays that were added during her 1872 upgrade. The main chainplates are from round iron bar, where as the new plates are of flattened plate/bar with out the use of preventer plates. the entire plate was bolted to the hull similar to plates of costal schooners. Quick, easy and effective. They need to look intentional and have similar molding...but still look like an addition or afterthought (which they were). Rob
  18. Making the chain plates was tedious and repetitive. But I worked fast and uninterrupted. Now I’m going to make the mod chain plates and channels that were added after 1872. Rob
