petehay
Everything posted by petehay
  1. Trying to go minimalist and only use the pad while at home.
  2. The next step is to create the four main ribs by bending and attaching to the numbered forms. The instructions say you can soak the 1/16" strips in water for 15 minutes and they will be pliable enough to make the curve. My attempts at this just ended up with a lot of crimped wood. I resorted to the Midwest procedure of adding ammonia to the soaking water. I then used tiny clothes pins and medicine bottle caps to form the half circle. This was much better. Pete
  3. This is the first construction step (and the one I had so much trouble understanding in the instructions) gluing the 1/16" square stock to the keel and continuing up the stem.
  4. I seem to have solved the upside down image problem and can now proceed. The original images are the kit "in the bag", an attempt to show the small size of the pieces, and a shot of the keel, transom, bow, and strip wood all stained with Minwax Jacobean stain. Let's hope I have better luck formatting my next post. Pete
  5. I don't seem to have the option to use full editor on my iPad.
  6. Here I go with my first build log. I am hoping that this little $9 POF kit will help me get my feet wet with planking. I've had trouble deciphering the instruction sheet and have complained about the poor quality photos included. I sent a copy of the instructions to MSW member Mahuna and he got me started. I am creating this log on my iPad so I hope the photos are OK. Here we go...
  7. Well I opened it up for the first time last night and yes my plans have the same misprint as yours. Here is a link to a pretty extensive photo log of the virginia https://picasaweb.google.com/Aquarius.7777777/ArtesaniaLatinaSchoonerVirginia1819 Maybe that will help us both. Pete
  8. Rebecca, I've used both tea and coffee to tint watercolor paper and it works great but keep it out of direct sunlight. It can fade in unpredictable ways. Pete
  9. Thanks all for the replies regarding my book question. One of the members of the model shipwrights group that I just joined is bringing his copy to the next meeting for me to look at.
  10. I would also like to hear David's comments regarding gesso. I used it as a primer on the balsa hull of my Sakonnet Daysailer and ended up with a finish as white and smooth as the styrene plastic of a Revell model kit. This worked on the Daysailer as it looks like a fiberglass hull but it was not what I was after. Pete
  11. Beautiful job. Your workmanship is an inspiration. I will be using this build as a reference for alot of things. Pete
  12. This kit is still staring me in the face. Anyone willing to try to talk me through the instructions if I send the PDF file?
  13. Are you using double-sided fabric tape (like the Singer brand), or just regular double-sided "scotch" tape? Pete
  14. Price. That and the build logs on the old MSW site. Others seem to have successfully completed the model ( Virginia 1819) and didn't seem to have too many complaints. I have not started this build yet but I purchased it to be my first attempt at a planked hull. Pete
  15. Can't wait until you get to the sails. I'm still struggling with getting the sails right on my first build, the Sakonnet Daysailer by Midwest. Pete
  16. I decided to give the sails a try. Got a little heavy handed penciling in the seams and had to wash them back a bit. What is two-way tape? Do you mean Double sided?
  17. Bob, The Grand Banks Dory was my first scratch build. In fact it is my first completed boat. I just completed it last week. I used the plans from the Shearwater site but built it half size at 1:24 scale. http://www.shearwater-boats.com/doryinst.html I am going to try to attach a photo taken with my iPad - not the best quality but I'm pretty proud of this little guy. Pete
  18. Ken, I picked up some Watco Danish oil (natural finish) and tested it this evening on some mahogany and basswood scraps from a previous Midwest kit and it looks pretty good so far. I brushed on a liberal coat and let it sit 30 minutes, wiped it down and put on another coat. Waited 15 minutes and wiped again. I'll let it cure for 24 hours(?) before putting on another coat. I hope I'm doing this right. Pete
  19. Janos and Buck, Thanks for the responses. I'm going to build the dinghy first, then use Danish oil to finish (unless someone here talks me out of it). Pete
  20. I want to practice using an oil finish. I have chosen Midwest's Dinghy kit to be the guinea pig (before attempting the AL Virginia). Do I oil the pieces before assembly or oil the completed model - or a combination of both? Hints or tips? Pete
  21. I'm toying with the idea of displaying the daysailer with the sails down as opposed to removed. Like when you would be docked at a marina for a beer. Is there a term for this? Where does the jib get stored? Pete
