lmagna
Everything posted by lmagna
  1. I agree with Dave By simply adding a resistor in line close to the switch on your unit you can change the brightness of your lights considerably. You may want to get a little higher wattage resistor just in case though, as the current drop you might want for all the lights in the string might cause some unwanted heat at the resistor. You are working with pretty low voltage and LEDs so this may not be an issue but you may still want to check it out. Another slightly more labor intensive method if your lights are not putting out much heat, would be to get some Evergreen Plastic white tubing that has an inside diameter large enough to fit over the lights. Cut the tubing lengthways in half and make short covers over each light. You should get a difussed light through the plastic and if you leave an opening between the top and under the spar deck you should also get light shining upward rather than outward. You could also paint or otherwise cover the plastic to dim or direct the light anyway you want. Someone with more experience may also have other ideas like totally burying the LEDs completely under the gun deck and running strands of fiber optics the terminate in the location you want the light to emit from. just some ideas, hope one or more of them are useful to you. Lou
  2. Great job! I am certain that you will love the final results when you are done and it will be a blast showing guests when they come to your house and see the ship. You might want to set the spar deck in place temporally and see if there is any light leak through the plastic deck before you install it permanently. if there is then you will be able to block it with either paint or foil on the bottom of the upper deck. Looking forward to your further progress Lou
  3. Hello Sam Your carving skills have transformed this small ship into a masterpiece. I am new and have just discovered this build but, I will be certain to follow it as long as you are willing to share the results of your formidable skills! Makes my poor attempt at the Constructo kit look pathetic! Lou
  4. Hello moflea I enjoyed your posting about this build. I am building the same kit although it is an older version and has a different name. So far I have almost completely redesigned the kit and have used almost nothing of the original wood. You are further along in your build than I am and your work looks very nice. I almost wish I had done the same thing and built it more out of the box. If I had gone just a little further the kit would have made a much better early 19th century brigantine than a late 18th century vessel. Looking forward to more installments on your build. I also agree that it is a very small model to work with. Lou
  5. Hello Michael G I have been working with pretty much the same thing, only it is with the 1/350th Minicraft Titanic that I am making for my admiral as a kind of night light. Here was my solution for the battery situation. http://www.ebay.com/itm/2-5-10m-LED-Mini-Silver-Wire-String-Fairy-Party-Wedding-Light-Controller-Adapter-/401346315583?var=&hash=item5d721ac53f:m:msovzGbpbO8O4fm6l_c32vw These lights are pretty much the same as what you have but there are many more lights available if you want. Plus they will plug in so that you will not have to bother about batteries down the line. The inline switch also allows for some brightness control and of course some somewhat useless flashing modes. I wish it had a flicker mode instead of flashing. In my case I am placing many of them into the hull to shine through the drilled out portholes. Then I am lining all the under decks and cabin interiors with foil to stop light leaking through the lighter plastic of those parts. I also will be installing the lights through the keel but I think I will be able to hide the female plug inside the hollow stand with the switch in a convenient location. Good luck on your installation. Lou
  6. Gerhard Thanks for the link. Nicely done patrol boat. I like the jig system you made as well. I am wondering if it could be made to work without the use of a lathe. All I have for rotary work is a drill press. Lou
  7. Thank you for the video Gerhard. I will try and find the other videos on YouTube as well. Lou
  8. "I think they can be had in 1 mm.......but scratch making them seems to be the latest craze." I think that possibly you didn't spell the last word right! Shouldn't that be "crazy" Making a couple or even a few block in 1mm or 1.5mm would be OK I suppose, making enough to rig a frigate, or even worse, enough to rig both this ship AND the Thermopylae could drive one over the edge. In my case I need to use special care as I am not that far from the edge to begin with! At least that is what the Admiral tells me. Lou
  9. No problem on the reply, I am being a little off topic anyway. Glad to hear you made an extended Fathers Day of it all. Now you will be extending into my birthday, (Tomorrow) As for eBay, my preferred method is to hold my bid until the last fifteen seconds or so, (Ten is better but a little nerve racking) and bid the very highest I feel I can justify. Sometimes that is as much as twice or more than the showing bid! Much of the time I win because it is possibly unexpected by the other bidders and there is very little or no time to counter my bid. On the times I lose I at least have the satisfaction that I made the winner pay a much higher price than they would have. I did that a few months ago on a bid for a Fair American solid hull kit in 1/96, (+-) scale made in Holland by a company I never heard of. I placed my bid with something like 30 seconds to go and darn if one of the other bidders didn't manage to place another SIX bids before the bidding was up! I still won the bid because he only made small bids instead of going for broke but the extra few seconds cost me $30 extra! I tend to stay away from Oldmodelkits.com because they seem to be a bit over priced in most cases. Just my opinion. What is over priced when you can find it nowhere else? I am looking forward to how your 1/96 scale blocks work out as I also have some spare plastic stuff in the stash box and if your's turns out I may do the same when the time comes, but I still cannot help but think they will be massive at this scale. I also think you are right in that 2mm blocks seem to be about the smallest available commercially. I wonder if Chuck could make them to order in a smaller size? Another alternative I have been considering is using the small (1mm?) craft beads then filling and painting after rigging. Lou
  10. Denis Hope your dog walk went well. Isn't this Fathers day? The day that the other half is supposed to do all that kind of stuff? In case you haven't found them yet the links for the two eBay listings are : HERE and HERE I am surprised that the first one does not have any bids while the second already has two! I would think that having two 1/96 scale kits would be better than one. I have the problem of hording kits that I find interesting. It is a bad habit but in the long run tends to save a ton of money. I have model kits that when I bought them were VERY inexpensive. If I was to buy them now in some cases I would be out hundreds of dollars for each kit. I also went through a phase of building 1960s prototype, endurance, and Can Am sport cars some of them are now worth several hundreds of dollars each if I could find them, and others are available no where at all. Ever hear of a Bre Hino Samurai? At any rate it is interesting on what you intend with the rigging on this kit. I was thinking that what I was going to do when I built it again was to rig it with the little loops provided and then fill them in and paint them so they would look like solid blocks. Lou
  11. Where do you get the time for a blog? I am feeling a bit overwhelmed just trying to keep progress on the dumb Constructo kit that I stupidly thought would be a "quick build". Now I am adding the 1/350th Titanic, with lights, to my list and I want to do the Sultana as a gift as well! I'm retired and don't seem to have that much time! By the way there are a couple Revell Thermopylae listed on eBay for what seem to be a good price in case you don't think you have enough to do. One of them is a dual kit sale that also includes the Cutty Sark. Just trying to be helpful. I'll go back to my corner now. Lou
  12. Hi Denis Yes I found your Thermopylae build and started reading it last night. For some reason I thought it was going to be the plastic version. It may be a little too late on the Jolly Roger but did you consider leaving the mast footing intact and removing some of the base of the bowsprit? I know it was glued in but I would think you could have still removed it, shortened it and reinstalled it without too much issue. After all look at the almost invisible repair you did to the ratline piece! Lou
  13. I will have to look up your build on the Thermopylae and see what you have done with her. I had not done so as yet because to be honest Clipper ships are not my favorite subject and second you do not provide links to your builds in your signature so I have to take the extra effort to look them up in the search feature of the forum. (I'm lazy) I have now corrected my slothfulness, (Is that a word?) and will be reading your post probably today. Lou
  14. Hello Denis I have been lurking about several of your builds, in fact one of them has gotten me in some trouble! I was reading your Titanic build and the Admiral saw it and made it clear that instead of building all the "Junkie looking" models that I like, that if I REALLY loved her I would build HER a large lit version of the Titanic of her own to be placed on her personal TV as a night light when she watches TV at night. Adding sound so that it plays the music from the movie would have to be considered as well of course! So now I have accrued a 1/350th Titanic, (eBay) and means for lighting, and have identified the photo etch stuff that will be required. I have not lit a ship to this degree before and I have never worked with photo etch stuff at all, even though I have scratch built brass stuff for small plastic ships in years past. Now I will have to do it, just because of you! I also have this kit, (Jolly Roger) in my horde and at first when I thought of getting started in building ships again after A LOT of years of not building I was going to build it as either the La Flore, or the Hermione. I built it as a much younger person some 35 or possibly 40 years ago and at that time I though it was a great kit and made into a very nice model, (But you know the memory can be misleading when you get to my age) that was why I have two of them on the shelf! So you need to quit doing this kind of stuff! I am already trying to get a Brigantine done to give to a friend for his birthday, get time to start and build the Admiral's Titanic, and I want to build a MS Sultana, (Also already on the shelf from years ago) for one of my sons who has expressed an interest in that kind of ship model. I only have so many years left at my age and I need to get some of these done before they become eBay inheritances for my surviving kids to sell! All aside though I do enjoy looking at your builds and am interested in seeing how this one turns out. Lou
  15. John Thanks for looking in and providing another source of information. Of course it turns out that I do not have Hahn's 'Ships of the American Revolution'. I have, in fact I am presently reading, his 'Colonial Schooner 1763-1175 and I have his plans for the Rattlesnake. That means I am unable to read your reference and make any comment on Hahn's description of the Lexington. I also would prefer not to discount to much on the research of people far more versed on ships of this time than I am unless I was able to obtain some very convincing undisclosed information. I do not think I was questioning length and number of guns in dismissing the Lexington as a possible subject of this model. What I have done is take a kit that at best is kind of a representation of an early 1700s brigantine rigged ship with both a raised beaks head style forecastle and a fairly large great cabin and quarter deck. I think that the kit was designed that way so that they would not have to provide as many guns per kit because of the broken deck both fore and aft. All guns under the quarter deck and the forecastle are hidden. To me a small ship like a brigantine of less than 100' in the late 1700s would not have had an enclosed fore castle, merchant or purpose built warship. I know that there are ships that are an exception to this but I think they are uncommon. So I did not build the forecastle at all and shortened the quarter deck to what I thought was more proper for the time and type. I also extended the shear rail and enclosed the bow. By doing these things it turned out that the looks of the ship are considerably altered. I started looking to see if the new looks could lead to a real ship that would be close enough to use as a pattern. I ran across the the above described book by Davis who used the 'Lexington' as a basis for his model. The pictures in the book looked very close to what I was building so for a short time I kind of ran with it so to speak. I had some doubts on the model in the book but who am I to question someone who writes a book about his 'scale' model? Looking elsewhere though it became almost instantly clear that whatever ship Davis had built, it was not the Lexington, in my opinion for what it is worth possibly not even the right war! The Davis model is a fully open spar/gun deck ship with no quarterdeck or any cabin structure on the deck anywhere. It has more of the looks of a Cruzer class of Brigantine of the turn of the century as well as the brigantine Niagara of the war of 1812. Unfortunately this was not the period I wanted to do. I wanted the American Revolution, and I wanted to retain a ship with at least a quarterdeck. So for this reason I resigned myself to having to build somewhat of a fantasy ship that I have started to call the 'No Such'. Hopefully I am able to carry it off and it will at least look like a believable America brigantine of that period. I will now have to get Hahn's book and read your references! I think I am doing as much, possibly more reading than I am building. This whole thing started as #1, I already own it. #2 my wife bought it for me something like twenty years ago, so I probably should build it. And #3 I thought I would give it to a friend of mine as a birthday present later this year. He likes ships but is not a modeler so I was pretty sure he would not pick it apart to badly and be able to enjoy it. As it is, it has turned into a full kit bash where the only wood from the kit that I have used is the carved hull, and that's been heavily modified! I need to quit changing and get on with the build! {:^) I still would like to do it right though. Lou
  16. Joel I do have the book on the Irene, along with the plans that were included in some of the editions. And yes I also could see that Davis's Lexington looked more related to that class of brigantine and others built for the Barbary war, 1812 war, and Napoleonic wars. That was why I changed my mind as to why my 'kit' could not be done as the Lexington just by leaving the forecastle but keeping the quarterdeck. I would need to remove the quarterdeck as well and do a few more hull alterations to make the bash believable as a Cruzer or similar era vessel but it would be possible. But I was looking for a Colonial Brigantine not a turn of the century ship. So the search continued and after the elimination of the Feldman Lexington I decided that this kit at least would have to be more generic and to try to be fair to the time period rather than a particular ship. Lou
  17. Hello Joel Doesn't take all that long to type up a short conversation here. Back when I was a gainfully employed contributor to society, I spent more time commuting to work! Now that I am retarded, my commute consists of getting up, showering and dressing taking the dog for her walk and then the rest of the day is mine, subject to the whims of the Admiral and resident crew. I suppose one could say that all modeling attempts are a product of material on the real vessel available to the builder at the time of the attempted model build, combined with the interpretation of that material and how much you want to believe the interpretation of other researchers who provides the material in the first place. This seems to be especially true of the vessels we are choosing to build from this time period. It seems that for every person who states that the material presented is a true representation of the vessel in question, someone else says that there is something wrong with the research. I think I may agree with you on Davis's Lexington, that his model was 'close enough' in his eyes to be represented as the Lexington. Heck, if he had been right I may have done the same thing and used his rendition as a basis for my rendition and of course added my own misconceptions and short comings in ability and kit limitations to the build. If I wrote a book or was famous as a reliable source in some other way then my kit could also assist in passing along the 'look' of this type of Brigantine as being the Lexington and others would possibly accept it. I this case the Davis model seems to have been overthrown in favor of the Feldman model seems to be primarily based on a painting, (Which of course is another interpretation by yet another artist who obtained his information either personally from a hurriedly produced sketch that was taken back to a studio and rendered into a more completely detailed detailed painting or drawing. Or the painting could have been based on a sketch or description provided by a third party! Don't get me wrong I personally believe that the Feldman model is by far the more accurate or believable of the two, and will be the standard for years to come, if not indefinitely. But who is to say that sometime down the road some other material may show up, or someone researching the Lexington will present a better argument and the look will change yet again. You can be pretty sure it will not be me! I am within limits perfectly willing to let people who have better training, better access to sources, and more time do the research for me and all I need to do is agree with them that their take on the resources if correct, or that they are full of it. Or it could be like in many cases somewhere in the middle. I have only done primary research on a couple of vessels, and only one of them was to the detail we are discussing. I have been researching the schooner Lanikai off and on for probably twenty years and while I have enough to build her now in probably could be considered a stand off scale, (Standing WAY off) I would not be happy or proud of the results enough to say that what I built was 'the Lanikai'. Hope that makes some sense to you. In any case the information has been so scarce and the need for interpretation so great on a twenty first century vessel that I have both narrative and pictures of, I can only guess how hard it is for people dealing with small vessels from almost two hundred and fifty years ago. I do not envy them, especially when there are people like me lined up twenty deep looking to see just how accurate their work is based on how they, (The viewer) feel! Here I go again rambling on and on! trippwj While in essence I agree with you, I am not so sure that it is quite so black and white. Merchant ships were built to a different purpose true, and this influenced many things like the shape of the hull, rigging design, and deck layout, but were they so much different? It seems like time and time again ships of almost any given size short of a ship-of-the-line were purchased from civilian use and weaponized so to speak. I cannot say that I can find many discrepancies in the one or two masted smaller vessels of the time being better or worse armed depending on the vessels original use. It seems like how much the owners were willing to spend and what gunnery was available was far more an issue than construction. In fact I think that there were cases where after capturing an American converted Privateer the British cut down on the number of guns, size of guns, or both, and it is clear that their resources were far greater than the original owners and they could do pretty much as they desired. It is obvious that I am nowhere near as well read as yourself and I could be completely full of it, but I can not help but think of ships like the Lexington who were able to hold their own against their naval built counterparts even though if possible in most cases they preferred to avoid personal damage by evasion. This can be seen even almost two hundred years later with the Graff Spee who's job was raiding merchant shipping of the enemy in 1939. When she engaged three British cruisers that on paper could have at least held their own. The Graf Spee almost sank the HMS Exeter and severally damaged the Ajax in a battle that lasted about an hour!. Most historical accounts I have read say that the Graf Spee handled with a different frame of mind would have had little trouble finishing off all three ships. There is some controversy about the few shells that did hit the Graf Spee and what possible damage they caused, but the result was the same in that the Captain decided he could no longer escape the British with the inevitable result of the loss of the ship. Didn't the Bon Homme Richard get pierced for something like forty two or forty four guns on three decks? And she was worn out by the time John Paul Jones commanded her. Thanks for the list of references. If possible I will be looking into at least some of them. It is always interesting what books other modelers find usefull. Lou
  18. Hello vossiewulf When you first posted the size/spacing formula, I read it as minimums allowable for a given vessel and gun combination. So if you had a designed length of 'X' and under ideal conditions had to make no concessions for rigging or other factors, you would have the ability to pierce the hull for 'y' number of guns of a given size and still give them the required field of fire and operational area. If the hull was slightly longer but not long enough to accommodate another piercing/gun then you could either add additional spacing between ports and keep the same number of guns, or go to a smaller cannon and carry more guns. I would have to assume that hull design and displacement ability would also be a factor on gun size but I am trying to keep this just about port size and spacing not getting an engineering degree in ship building. A good thing as I am still struggling with the fact that design formulas say that the port is wider than its height and they still look square in all the pictures and plans I look at! Time for either new glasses or brain! Joel I did not say it before, but your build of the Lexington has been one of the guidelines I used when I started modifying this kit. I looked at the lines published by Davis for the Lexington and at first thought that his Lexington was close enough to use as the ship for this model and I would be able to build a 'real' ship with a history rather than a representation of a type. But then I saw your build and it is obvious that the two Lexington s don't have much in common other than they are both models. Unfortunately for me, the lines and documentation I have are for the Davis hull and it has been proven to not be accurate, your version is, or at least is according to more resent research. In addition the shape of the kit I am bashing has a closer resemblance to the Davis build. I do intend to continue using your build as reference though whenever possible, just because it is so well rendered and I know you will make every effort to insure it is 'right' historically and dimensionally. Also a little off subject but in relation to your comment about recoil, I have a little experience in this area it so happens. In my younger somewhat misspent years I tended to hang out with a few slightly deranged individuals, (We were all police officers if you must know). One of them, along with several machine guns and other rather odd pastimes had managed to acquire what I remember as a three pound cannon barrel dated in the mid late 1800s, sometime after the Civil War. I could be wrong about the shot size but i do remember that it had the same bore as a beer can! This fact and the emptying of many said same and the navel bent of all concerned led to what I suppose was to be expected from those involved. it was decided that my friend, being single, needed to have the cannon displayed in his front room for all to admire and that this would require the building of a proper navel carriage, even though none of us had any idea if it was a navel barrel or field piece. Heck, for all we knew it was just a starting cannon for racing or something. Little matter, ignorance is bliss. We did build the carriage and it turned out fine, especially considering our state of soberness during much of the research, design, and construction. I do not know when it happened, or for that matter who brought the idea up, but somehow the bright idea to actually fire the silly thing was presented and no one was sober enough to counter the idea. The rest of the story is pretty much history as we proceeded make cannon 'balls' out of a surplus supply of beer cans partly filled with Plaster-Of-Paris. The purchase of lethal amounts of black powder, (I think we stayed a little more sober about this time) some configuring of lines we thought 'should' hold against the recoil that we had no inkling of how to anticipate and we were ready to mount the gun in my friend's pickup facing out over the tailgate 'gun port', that I am now almost certain was not within the guidelines we have established in this posting.We then headed out to a relatively safe place we used often when my friends went to shoot their machine guns. Safe being relative as being safe for others, was not quite the same as safe for us should anything go wrong. After all don't you want to be 45 minutes from help in the middle of nowhere when a cannon blows up in your face? So the 'gun port door' was lowered and the gestimated amount of required powder, based on possibly faulty research, was tamped into place and the required deadly projectile inserted. The recoil line was set to stop the travel of the gun before it went through the rear of the truck cab bulkhead. We had no idea how violent the recoil would be. A fuse in the touch hole and a mad scramble to get as far away as possible in as short a time as possible resulted in a GREAT cloud of smoke and flame and a considerably smaller puff of dust in the backstop down range. After all that we wondered what we would see when the smoke cleared but much to our surprise the cannon only traveled a little over half the length of the truck bed and stopped on its own! From that point on we were able to play with the charge a bit and even tried our best at aiming somewhat until we were at last able to hit a single poor tree. The results were impressive. While it did not knock the tree down it did blow all the bark and part of the wood as well from an area of about a foot and a half! Pretty impressive for Plaster-Of-Paris! Lou
  19. Hello Joel Thank you for the additional information. I still have not located my copy of the Davis book but I know I own it so it is only a matter of time before I locate the box that it has been stored in all these years! With three stories, a basement and six bedrooms it has to be somewhere, the house is only so big after all! One of these days I have to kick the last of the kids out and take over a space that is only for ME and be able to have access to all the books, models and just plain stuff that the Admiral claims do not match the decor of the remainder of the house. I am trying to convince her that what would fit the decor of a 120 year old house better than a lot of books and a few period ships? Anyway back to the subject at hand. I am trying to replicate or create if you will a realistically believable late 1700s American brigantine, possibly a privateer not originally constructed as a warship. Much like your model of the Lexington. In some ways I know that what I end up with will not truly fit this requirement as the hull is too fair for most merchant ships and other similar factors arising from the fact that it started life as a model kit that was designed to be more of a toy than anything else. All that aside I am a little impressed that the hull is even now taking on some believable lines and I would like to improve on that if possible. So the numbers I would be looking for would be for guns that are more in the line of four, six, or possibly nine pounders that I am almost certain could be placed, in fact would have to be placed, much closer together than 10 feet apart. On the other hand I will jump at the idea that the guns can be placed in conjunction with the masts with little fear of problems. The guns that came with the kit are a scale six foot barrel. I have spent much of the day looking at as many drawings and pictures as I could to see if this was a closely adhered to rule, or if it was a suggestion in ship design that was desired when building a warship from the ground up. I found as many cases of guns lining up with the masts as I did cases where the back stays and chain plates had to be moved to accommodate the gun port. So with no true numbers to plug in at this point I am leaning toward gun ports that are small enough to at least protect the crew from being completely exposed. With a sill that combined with the overall size, prevents the cannon from popping out the side when the ship does a hard roll, while still being large enough to allow the useful elevation, depression, and angling of the gun and carriage combination. If I use that kind of layman's formula it appears oddly enough that the kit plans supplied with the model are surprisingly not far off at all. Their height and width are the same though which at the scale I have decided to use would make them 24" to the side with each port being spaced eight feet apart. It looks like the ports could be slightly smaller and closer spaced but even at this size if I put two guns inside the great cabin just inside the forward bulkhead, I would have a broadside of seven guns! Reasonably respectable for a Brigantine with an eighty four foot hull length, even though two fewer guns than the Lexington. I am thinking though that twelve guns for this size ship would possibly be more balanced, especially if they were six or nine pounders. HMMMMMMMMMMM decisions decisions. Kind of having fun though with a less than desirable kit. Since I cannot dream of the "Whatever Name" being recreated to give honer to the original I can never the less give considerable thought to the bits and pieces that made ships like 'Whatever Name' what they were. Hopefully it will also be tolerable to look at at ranges of less than across the room. That is the hope anyway! Lou
  20. I know that this is a relatively old posting, but why not locate the LED or multiple LEDs deep in the hold and let them run fairly bright? Connect fiber optic cables as needed, routed to the locations where they are needed. That way you are able to simplify the amperage draw by using fewer LEDs and still get light where you want it. Lou
  21. Thank you Jaager and vossiewulf I was also thinking that the use of the horizontal winch VS the capstan was a matter of number of crew available to both handle the rigging while at the same time hoisting the anchor. American ships of the Revolutionary War period carried very large crews for the size of the vessel but that was for prize crews and battle matters and I did not think the ship would be designed around the excess crews available when being used as a warship. By the same thought I was wondering if the capstan was primarily a navel device not often found on civilian vessels or was installed as you say primarily on larger vessels due to the weight of the gear but I could find no evidence to support this as I can find plenty of small ships in the schooner and brigantine size ranges with either winch method installed. I may just continue with a capstan as I have already made the alterations to the rest of the ship design to accommodate it and as the capstan head is already provided with the kit I will at least be able to use SOMETHING that comes out of the kit box! As for the gun ports, I will have to see if I can understand better reading the formula and plugging in the numbers that match this hull. I decided that this ship will be 1/96 scale rather than the 1/100 that Constructo uses because it is a more common scale and after all what does it matter what scale they call it when it has no resemblance to anything that ever floated if built stock out of the box. I have a copy of Davis's Built up Ship Model somewhere in my stuff from years ago, before my last move. I am just now trying to get back into model building after about twenty years and am still looking for everything! I am surprised that the ports are not completely square with equal height and width. They have always looked that way to me in pictures and on plans I have studied, and I thought the height would be determined by the gun carriage and that the cannon barrel would be centered when at a neutral elevation. On this model as I am building it I will be able to carry up to 12 guns, (All I have of this size on hand! I wonder how many real ships were outfitted in this manner? More of a all I can get rather that all i can carry!) Not having the guns line up with the masts may also be an issue if I want to maintain equal spacing while still avoiding the back stays. I may have to work on this for a while, and as I already said find my book and do some reading. Thanks again Lou
  22. Hello Hopefully this is where this question belongs. I am in the process of kit bashing a Constructro Sentinel Brigantine into something that would possibly been used in the late American Colonial period. I have come to the determination that the deck layout on this kit was established only for the fantasy of the kit makers so that they would not have to supply as many parts to make something more realistic. So far I have reshaped the hull, altered the bulwarks to meet at the bow, not installed the raised forecastle, shortened the quarterdeck and raised the cabin slightly. I have also changed the angle and curve of the transom to what I think is a more realistic shape and angle. After I figure out how I want to develop some camber in the spar deck, I will be planking it instead of using the Mahogany printed deck supplied in the kit and then start building the required deck furniture. This is where some of my questions arise. First off I want to place a ships boat over the cargo hatch between the masts instead of hanging two boats from davits each side of the quarter deck as depicted in the kit design. This in its self is not really a huge problem as there is enough distance between the masts to allow this style of carry. The problem arises in the fact that the kit uses a capstan located just aft of the cargo hatch and forward of the main mast. This was in my opinion a poor location for a capstan in my opinion so at first I decided to relocate it behind the mainmast and shortened the quarterdeck to free up the space required. This also allows me to place the ships boat at deck level instead of on elevated cradles that would allow access below the boat. After some thought, (and already making the alterations of course) I now wonder if using a horizontal winch located just behind the bowsprit forward of the foremast would be a more proper design for a vessel of this size and design rather than having a capstan installed at all? At this point I could go either way without too much trouble. Secondly, trying to think ahead a little better this time, is a question of the gun ports. Is there a formula for the size of the ports and the distance between ports depending on the size of the cannon carried or were they a kind of one size fits all? I was thinking that I would establish the initial distance and location of the cannon based on the location of the back stays and chain plates so that the cannons have a clear field of fire. From that point it looks like the gun ports are about equal to the width of the gun carriage and squared shape and that the distance between guns is about twice the distance as the gun port size, if that makes any sense. Does that seem about right? I do not want to cut the gun ports or finalized the top rail design until I figure out these issues. Looking forward to see what others more knowledgeable than I come up with. Lou
  23. Hello helmsman. Anja, and Eddie Thank you for the welcome. Eddie I kind of feel like you, can I finish all that sits in my horde before i die! I would add the list to my profile like yours but I have not figured out how yet. In some things I am a little dense. Lou
  24. David Yes a couple of the plastic ships that I have in my horde fall into that category. Ships like the USS Oregon, (Glenco) that with the documentation I have would have to almost be completely redesigned to make it right. I would never be able to live with myself if I was to build it straight out of the box and try and call it the Oregon. Ignorance can be nice sometimes. On the other hand the old Revell Olympia with only slight embellishments and modifications could hold up OK to being representative of its namesake. Some of the others land somewhere in between the two extremes as well. With some of the newer kits and all of the photo etch options it truly is almost a new world for the plastic modeler. I do not own any of these newer ship kits but in the past I found that I reached my limit when it came to painting and weathering. I have very little artistic skill and have problems "Envisioning" how to reproduce the final desired result. I suspect that I will have the same problems when it comes to period ships and their colors. Hello mtaylor Thank you for the welcome It will take me a while to gather much of my Lanikai stuff together as some of it is from here and other stuff is from there. In some cases the information I have would have to be hand copied as it is from non internet sources or protected files. (You don't happen to have a copy of Pacific Marine Review volume 13 1914 do you?) {:^) But if I can put a comprehensive understandable presentation together in some manner that can be presented in a online environment I certainly will. I am afraid that I am a bit of a fossil and do not have many of the digital means that some people here possess and use so well. You are right The Lanikai was obtained from civilian ownership in both wars, although I do not think "buying " would be a fitting term for either time. She was originally built as the Hermes in 1914 at the W.F. Stone Shipyard in Oakland CA. for a German company. Here is a somewhat condensed history; Patrol Yacht: YX-12 Built in 1914 by the W. F. Stone and Co., Oakland, CA Taken over by the Navy on Executive order, (1917) and commissioned USS Hermes 1 April 1918 Decommissioned 16 January 1919 and turned over to the Hawaiian territorial government (Where it appears she spent some time dealing with rum runners and such). Turned over to the Pacific Air Detachment Struck from the Navy list 1 July 1926 Sold 21 October 1926 to the Lanikai Fish Co. of Oahu, Territory of Hawaii and renamed Lanikai Sold in 1929 to the Hawaiian Sea Products Co. Laid up in 1931 Sold in 1933 to Northrup Castle of Honolulu Sold in 1936 to Harry W. Crosby of Seattle, WA Sold in 1937 to Metro-Goldwin-Mayer for the making of the movie "Hurricane" Sold in 1939 to E. M. Grimm of the Philippines for the Luzon Stevedoring Co. Chartered by the Navy 5 December 1941 and commissioned USS Lanikai Transferred 22 August 1942 to the Australian Navy Commissioned HMAS Lanikai 9 December 1942 Returned to U.S. custody 22 August 1945 Sunk in 1947 off Nabasan wharf during typhoon at Subic Bay, Philippines. Hermes Specifications: Displacement 340 t. Length 89' 4" Beam 25.4' Draft 7' 6" Complement 26 Armament: Two 3-pounders Propulsion: Steam, one shaft. Lanikai Specifications: Displacement 150 t. Length 87' 3" Beam 25.4' Draft 9' Speed 7 kts. Complement 19 Armament: One 3-pounder and two .30 cal. machine guns Propulsion: One diesel engine, one shaft. One of my sources lists her as wooden hauled and copper sheathed. Another says that she had stainless steel sheathing. In both cases it appears that she was painted with anti fouling paint below the waterline. Lou
  25. Hello Robert and David I do not know if I am done with plastic ships yet, I still have a bunch of them in the hording stash as well! After all I have to retain at least a few vices in my old age, most of the others have been taken away and are no longer available or I have been told they are not good for me! David Thanks for the welcome home. It's kind of funny, I never even heard of that phrase until I had been home for over twenty years. But then I kind of kept it a secret that i had even been gone for most of that time. Not something you spread around to loud back in the 70s and 80s, at least not where I was living. I spent most of my time in Hueys so got more of a birds eye view most of the time and tried to never be too late for the chow line. {:^) As for the Lanikai, even though it officially carried USN numbers on paper in two wars there is virtually no documentation useful for building in the Navy data base. All I was able to find there was a picture, class identification and hull number. Also some hull measurements from both wars that don't match! Sometimes the US Navy does not care much about some of the ships that have served the cause so well. I personally think the escape of the Lanikai and her crew should have been plastered all over the newspapers of the time as a moral booster for people at home who were not getting to much in the way of good news. Welcome home to you also. Lou
