Doug McKenzie
Posts posted by Doug McKenzie
2 changes bring Leon to the point where she is ready to go into the bottle - the bottle, of course, is not yet ready for her! The first change is that the main topmast, previously made of wood and broken in three places, has been replaced by a brass rod which looks much better. The second change is that the braces have been added and require some explanation. All 5 braces are single with no tackle at all. My thinking is that the likelihood of tangling when trying to raise the mast with double or triple braces was just too great. The two lower braces run to the bulwark (not to the mainmast) and so could be installed in a loop fashion - yard arm to yard arm still allowing the two masts to be lowered and raised independently. For the three upper yards, the braces lead to eyes on the mainmast but are only fastened to the port yard arms. This allows the two mast to operate independently. Then when the masts are raised the braces can be fastened to the starboard yardarms. All 5 yards will be able to be braced appropriately and then the braces can be glued in place and the excess cordage cutoff.
I've sent off for the 'equipment' needed to 'pour' the ocean so I'll be able to do that in a few days.
I realized that there might be interest in a few details so I took a couple of closeups: Pic 1 shows how the shrouds were handled at the foremast top. An 1.0 mm hole (blue arrow) was drilled through the heel of the fore topmast. All 5 shrouds were made from a single thread which was taken up from a notch at the waterline, through the lubber's hole of the top, through the hole in the heel of the fore topmast, back down through the opposite lubber's hole and down to a notch at the waterline, under the bottom (Pic 2) and the pattern repeated. The 2 backstays on the foremast were also included in this single thread.
The problem with the backstays was that the topgallant mast and royal mast were so thin that I couldn't drill a hole that the backstays could pass through. I had the same problem with the topgallant and royal yard lifts which need to slip freely at the mast so that the yards can be canted to slip inside the bottle and then be put level again after the ship is in the bottle. Pic 3 show the little wire eye that serves to support both the lifts and the backstays. It's not accurate, of course, but it works pretty well!
- AON, vossiewulf, ccoyle and 3 others
6
Things are getting ready for the bottle. Pic 1 shows the masts vertical with the 4 main stays and 5 fore stays rigged to the stick that keeps them neat. The main stays pass through holes in the foremast and then go to the stick. The main stays will be glued and cut off on the forward side of the foremast. The fore stays pass through 1 hole in the anchor deck and 4 holes in the jibboom and then to the stick. The fore stays will be glued and cut off on the bottom of the jibboom. I left out the fore topgallant stay. The missing rigging is the 5-on-a-side fore lower shrouds, 2-on-a- side fore backstays (there are supposed to be 4) and the 5 pairs of braces. The clamp at the foot of the foremast holds it inplace until the shrouds are installed.
Pic 2 shows the masts folded aft.
Pic 3 shows the yards canted to be more or less parallel the the foremast
Pic 4 shows the collapsed model inserted into the neck of the bottle
After the rigging is completed, it will be time to 'pour' the ocean. I'm going to be using Max EPC (Electronic Potting Compound) because it generates much less heat than other epoxies.
- pmckenzie, AON and vossiewulf
2
1
Alan,
Thanks for your comments! I used Ships-in-Bottles by Don Hubbard and some youtube videos for my instruction. It is my first ship in a bottle and it is my first ship model to such a small scale. The hardest part, of course, is doing the spars and rigging to scale which is the point of the whole effort. The running rigging already in place will have to be replaced with some new stuff that I just got. Presumably you'll see that in the next post. I've also never made a point of sharing my mistakes the way I have on this blog. Those lovely thin masts have broken 5 times so far but CA glue (thick and medium) have always come to the rescue.
Thanks again for your interest,
Doug
PS the 1:8 sailing 'model' was the dream of a 12 year old building his first wooden shipmodel (Model Shipways Young America) 65 years ago - talk about a labor of love.
- Ryland Craze and AON
2
This will be a short posting. The three lowest yards have been mounted using the same technique: A fine wire is wrapped around the mast, crimped and glued. That wire is threaded through a hole in the yard and it is bent to prevent the yard from coming off. This allows the yard to rotate for entry into the bottle and then rotated back to the horozontal position. The upper and lower topsail yards have a tiny block of wood between them at their centers and the pivot hole is drilled in that block of wood. This was necessary because they are both metal. The lower yard and the upper topsail yard have lifts which pass through athrawtship holes in the mast. Without these holes the yards would not be able to rotate as described above. I haven't figured out yet how to let the topgallant and the royal yards rotate with their lifts yet because the mast is way too thin to take a hole.
Pic 1 shows the mainmast folded down and in the neck of the bottle. There appears to be plenty of room for the foremast and its yards (thank heavens!)
Pic 2 shows a few new things: 1) A block of wood fastened to the bottom of the hull which allows it to be clamped - I'm using a clamp designed for a drill press. All the instructions that I've seen use a block like this but I didn't use it until I finally saw how useful it is for parts of the rigging process. 2) The foremast is complete (but not hinged) and 3) the head gear is started. Oh and 4) you can see a sailor leaning against the port bulwark rail.
The bowsprit is wood but the jibboom and martingale are 1mm brass rod that have been flattened so that 0.50mm holes can be drilled in them Pic 3. I've rigged a single bobstay rather than the correct double because I just could not figure out how to get the second one in there and it might look too cluttered anyway. The martingale stays are in but I won't be installing any head stays below the jibboom - they'll just end at the jibboom after they have been used to raise the foremast. I haven't figured out what to do with the guys yet because they may look too bulky and I can't fit whisker booms because they won't fit in the neck
Lastly for this post is the yards Pic 4. Wood is used for the fore yard but wire is used for the upper four yards as they would be just too fragile if made from wood. I'll taper the fore yard but the other four will have to be straight.
- AON, Knocklouder and Bryan Woods
3
If you did leave MSW then it really is odd since both myself and ccoyle experienced the same problem. Maybe you did something before you left that initiated a save?
James did you completely leave MSW or just go to a different window. If you did leave MSW then it really is odd since both myself and ccoyle experienced the same problem. Maybe you did something before you left that initiated a save?
Thanks all! I found some on Amazon - I don't know why I couldn't find this the first time I was looking.
I have only been able to find thread down to 0.3mm and I'm working on a Leon-in-a-bottle model at 1:300 which requires some 0.1mm tan thread for running rigging. Does anyone know of a source for thread this fine? I've attached a picture that shows the peak halyards as 0.3mm black and you can see that it is way to heavy. The hull is about 4" long.
Thanks in advance.
Doug
Pic 1 shows the hinged mast vertical. Pic 2 shows it folded down.
Pic 3 shows the hinge - wire through the base of the mast bent down along the mast and inserted into two holes in the deck just aft of the gallows,
Pic 4 shows the shrouds in place. These are all one piece of thread wrapped around the hull and passing through one relatively large hole just above the trestle-trees between the lower mast and the topmast. The two backstays will be placed correctly later. The peak halyards pose a pretty big problem because they are too thick, 0.30mm, they should be 0.10mm. In addition, they should be tan instead of black. I am going to ask one of the forums for help on finding finer thread because this just doesn't look right.
- AON, JacquesCousteau, ccoyle and 1 other
4
Folks,
It used to be that I could start to build a posting and then quit MSW and when I came back my work was saved. I could continue to build the posting and then eventially submit it. Now my work is deleted. Is there some way I can have the old functionality back or is this a permenant change?
Thanks
Doug
The main top, consisting of trestle-trees and cross-trees along with the cap (made of thread), is shown in Pic 1. Pic 2 shows most of the rigging for the mainmast as it will appear in the finished bottle. There are only two classes of rigging that are not included yet. One is the main lower shrouds which can't go on until the mast is hinged to the hull. The other is the fore braces. I haven't decided yet whether to put the braces on the mainmast before hinging or after. To have another 10 braces hanging around before they can be fastened to their respective yards seems to be too messy - we'll see. I also haven't decided whether to build the foremast next with its five yards or whether to hinge the mainmast and rig the main lower shrouds and the backstay next.
- pmckenzie, njmckenzie and AON
3
We are starting with the mainmast for two reasons -First, It is thinner than the foremast and therefore a good way to test construction tecniques. The second reason to start with the mainmast is that it folds down independent of the foremast whereas the foremast folds down on top of the mainmast.
I sanded a 3/32" x 3/32" piece strip of balsa down to the 1.6mm size at the parners using a sanding stick. My gut says that balsa wood soaked in very thin CA glue will be a) Easy to size and taper and b) Also have plenty of strength, so that is my first try. That same guy Marty suggested using the thin CA to make the card bulwarks strong so we just adapted the idea to the spars. Having tapered the lower main with a square cross section down to 1mm at the head, I realized that drilling the various holes might be easier if I kept the square cross section. Unfortunately, this increases the visual diameter by 41% (the diagonal of the square being the new visual diameter. So what I'm going to try is leaving rougly the top half square, breaking the corners for a bit below and in the lowest part, rounding it off. Making the main topmast the same way and joing them at the doubling gives Pic 2 which is before soaking the mast in CA glue. The toothpick is 1.8 mm in diameter (5/64').
After the very thin CA is applied and sanded, the nice yellow color seems appropriate (Pic 3) for the final appearance of the spars. The glue brought up a lot of the balsa fiber and so a good fine sanding was needed because I imagine that to raise the masts in the bottle easily, we don't want the rigging to be catching on rough fibers on any of the spars. Next we'll be constructing the main top and then start rigging the mainmast.
- pmckenzie, AON and njmckenzie
3
The 4 parts of the hull, that will be inserted into the bottle separately, have been prepared with toothpicks to be properly aligned when glued together - Pic 1. . The toothpicks, of course, need to be trimmed! Credit for this solution goes to my friend Marty Nusbaum - I didn't want to drill down from the top and mar the roofs but I couldn't drill from the bottom because the model wouldn't sit securly on the drill press. Marty pointed out that if I drilled down from the top, I could just fill the holes (which I did with toothpick plugs) and paint over! Work was delayed about 2 weeks until this problem was solved.
The main fife rail has been added along with the gallows (to support the main staysail boom) - Pic 2). The heads of the bilge pumps have also been added (black, just forward of the gallows). And the wheel shelter has been added with two little life buoy rings painted on the aft bulkhead.
The 'Leon' name plate is on the transom - (Pic 3).
And, lastly, a moderately successful attempt has been made to show the wale emphasizing the lovely sheer curve - (Pic 4). A thin wire + glue was used. I've included the dime not so much to show scale but to make excuses for the not-exactly perfect wale.
The hull is now complete and we can begin work on the spars and rigging - oh boy, I can only hope that lady fortune will be with us when we try to produce scale spars!
- pmckenzie, njmckenzie, AON and 1 other
4
The windlass supports were so out of scale I just had to improve them. In the last post, those supports are about 23" thick. The best estimates I could make from various drawings was that they would be somewhere between 6" and 12" thick. So I sanded them down to about 12". Next we have the wheel-shelter and the main fife-rail and the hull will be complete.
The aft house is complete. As is the taffrail and the 3 hatches Pic1 .
2 errors have been found: The first is that a painted door was made on the forward bulkhead of the aft house and this is incorrect - there probably was no door so that has been removed. The second error is a bit more difficult to fix. The anchor deck has been cut as if there was an aft bulkhead, Referring to my research notes for the 4' Leon model, however, this is not correct in two ways: first, there was probably no bulkhead and second, the after edge of the anchor deck was not straight but rather followed the angle of the catheads. Future posts will document how this error was corrected - you know, once I figure out how to correct it!
First improvement is stem and stern post and then painting the hull so that the lines on the 3x5 card are not visible. In junction with Jeppe, I selected topsides white and bottom copper as she was coppered in 1890. The deck is tan. Houses will be white. The hull has been sawn into two pieces at the WL. Pic 1 This gives the spars a little more room in the neck of the bottle as the bottom slice will be installed first. LWL is 4.25" (10.8 cm). LOA is 4.75" (12.2 cm). Pic 2.
The midship house, Pic 3, is completed but it will not be glued in place until after the hull and spars have been installed in the bottle. This is because the foremast, which passes through the midship house, will pivot close to the main deck rather than the top of the house to make entry into the bottle neck easier. The house will be split down its centerline and then glued around the upright foremast. The black stack is the galley stove vent. The aft house has been started. When it is completed it also will not be glued in place until after the hull and spars have been installed in the bottle. The main mast will be about 3/4" (19 mm) forward of the aft house. To allow it to pivot down to the taffrail, a grove will be filed in the forward part of the poop deck and the the aft house will cover the groove.
Starting the hull with the sheer and deck cuts. Pic 1 shows the block after the two bandsaw cuts. The pencil line shows where the wale will be is. I made the sheer cut first so that the maximum amount of flat wood would be on the bandsaw table as possible. The "waterline' that I used is about the 80% full load waterline because, in my opinion, when she's fully loaded (as in the picture above) she looks pretty deep in. The deck cut was easier because the entire water line surface is on the table. Pic 2 shows the shape of the waterline. As a start to shaping the hull to match the section curves, I'll make cuts that connect the waterline shape with this wale. The only exception to this is forward of station 4, at the bow, the cuts will connect the waterline shape with the fo'csle deck. These cuts will minimize that amount of material that has to removed with a roto tool to complete the matching to the section curves.
Pic 3 shows the stern after the cuts (and subsequent wood removal) and Pic 4 shows the stern after some roto work. It turns out that it would have been easier to just roto out the stern without using the cuts except that the cuts enabled me to see the shape of the stern pretty clearly before using the roto tool. I should have mentioned before that my carving and roto tool experience is very very limited and so this part of the modeling effort caused me some anxiety.
Pic 5 shows the exposure of the main deck with the fo'cs'le and poop decks still intact. All of the instructional material that I have seen recommend chiseling out the main deck. The problem with this is that the bulwarks would be too thick. The main rail on Leon was about 6" wide which scales down to about 0.5 mm (for my skills, impossibly thin). I have 3x5 cards, however, that are 0.3 mm thick which will make lovely bulwarks. The 2 challenges with this technique will be to 1) reproduce the proper sheer line and 2) fair the bulwarks into the hull nicely. In Pic 6, the bulwarks are on with the sheer curve roughly correct and the fairing issue is clearly illustrated. Everyting on this model will, of course , be painted. For me, this is unusual, because unless the model is for sailing it is ALWAYS left as wood with a clear satin finish - not this one. Even Little Leon, the 22' psuedo model of Leon, which does sail, had a clear gloss finish!
Enough for this post. Next I need to clean the hull up, add the stem and stern post and prepare for all the deck fixtures.
This will be my third rendition of Leon - one might surmise that I'm rather fond of this ship!
The first attempt was a 2 1/2 year build with launch in about 2007 of about a 1:8 scale model (about 22' sparred length). Pic 1 shows her with the wind off her port beam with a crew of 3. I described her construction in a now defunct website. She nows lives on a lake somewhere in Kansas. She's a model of Leon like a movie that is based on a book. The only picture known of the real boat is shown in Pic 2.
The second model was a 1:48 scale model about 3.5' sparred length documented here on the NRG MSW website and shown in Pic 3. An interesting aspect of this model is that it is based on some contemporary documents such as an 1890 DMV survey as well as Underhill's book "Plank-On-Frame Models". These contemporary documents were found and translated by Jeppe Jul Nielson while the model was being built. The two most intriguing unexpected details (to me) uncovered in these documents was 1) Leon's use of "diagonal hanging knees" for the deck beams rather than the more conventional hanging knee and lodging knee combination and 2) her windmill pump for 'automatically' pumping out the bilge. She lives now in the Colin Archer's House Museum in Larvik, Norway where the original Leon was built in 1890. Colin Archer designed and built Leon.
The third model, and the one that will be documented here, will be a 1:300 scale ship-in-a-bottle. I've never enjoyed the commercial ships-in-a-bottle that I've seen because they seem not to be in scale with spars and rigging too heavy and beams too narrow. Also, I've mostly not been interested in sails (just a personal preference). So when the idea appeared of building a true scale model in a bottle, I thought that might be fun to round out the scales of models of Leon. The first job was to find bottle. A search in my local liquor store yielded this Woodward Reserve whiskey bottle (Pic 3) which had a slightly larger neck opening (3.1 cm) than most of the other bottle. In addition, the height to length measurements were an almost perfect for Leon. The narrow width of the bottle (5.2 cm) will not be a problem since, without sails, Leon will be at dock and her yards will be braced around.
There will be plenty of engineering and modeling challenges ahead and ain't that great!
- Ryland Craze, ccoyle, AON and 3 others
6
Translation from German
"Hello Mr. McKenzie, I would like to thank you very much for your construction report, which will help me a lot when building my Colin Archer."
You are most welcome, Andreas. I wish you good fortune with your build.
Doug
Leon by Doug McKenzie - 1:300 - Ship-in-a-bottle
Well, a couple of days has turned into 2 months but whose counting. At least the ocean is done now! My friend Marty and I managed to get the epoxy resin into the bottle without making too much of a mess and the neck of the bottle is quite clean. The basic technique used I saw in a YouTube video about a year ago but I can not find it again so I can not properly give credit other than say thank you.
We used the MAX CLR products of The Epoxy Experts of Canada. A 45 minute phone conversation with them was instrumental in the successful creation of the ocean. The first problem was that epoxy normally generates an enormous amount of heat as it cures. When thin films are involved there is no problem as the heat can dissipate easily but in this application a very thick glob of epoxy is curing and the heat could easily damage the bottle. To prevent this, equal parts (by weight) of a Calcium Carbonate Epoxy Filler is mixed with the resin. This filler conducts heat apparently and solves the problem. After mixing these two components we mixed in the hardner (1 part by weight of hardner to 2 parts of resin or 1 part of hardner to 4 parts of resin + filler). All this mixing, by the way, was done with little plastic stirrers driven by an electric drill. Lastly, the blue dye is mixed in. We had about 750 grams of epoxy and we used less than 1 drop of dye to acheive the color in the photo. We broke off the tip of a toothpick and stuck the blunt end into the bottle of dye so that about 3/16" of the toothpick was covered in dye. That was enough to acheive the color in the photo. One alert here- when mixing the dye into the epoxy, it took almost 30 seconds before the epoxy had any coloring at all. The first time I tried this, I thought I was going to have to add more dye - If I had, the color would have been much too dark.
Now to getting the epoxy into the bottle. The tools used, in order of use, are 1) the red funnel (the big open part of the funnel is not shown - it screws in to the long narrow part shown), 2) the clear plastic tubing 7/8" ID, 3) the plunger made out of wooden dowels and lastly 4) a strip of aluminum foil bent around the plastic tubing that fits into the neck of the bottle. 6 of these strips were made before starting to insert the epoxy. The aluminum foil covered about 1/2 of the circumference of the tubing. A lot of square pieces of paper towel were made available to assist in any cleanup necessary.
Loading the Tubing - The plunger was pulled out of the tubing right to the end (roughly as shown in the photo). The funnel was inserted into the othe end of the tubing and the tubing was held near verticle over a garabage can. The epoxy was slowly added to the funnel and the tubing was filled up with an 1" or 2" to spare.
Inserting the Tubing into the Bottle - The aluminum foil was wrapped around the tubing and the tubing extended about 1" further than the aluminum foil. The end of the tubing is wiped clean of any epoxy that may have stuck to it. The tubing was inserted into the neck of the bottle until the end of the tubing was about in the middle of the bottle. The plunger is pushed in to the tubing ejecting the epoxy out to fall to the bottom of the bottle.
Extracting the Tubing from the Bottle - Problem - we don't want any dripping of the epoxy to get in the neck of the bottle. Before extracting the tubing, we push the aluminum foil forward so that it captures any drips from the tubing. Then the tubing is extracted, pulling aluminum foil with it. The aluminum foil is tossed into the garbage.
It took 5 injections to bring the ocean up to the required level. The working time of the epoxy mixture is beteen 1 and 2 hours so we had no difficulty finishing the job.
The surface of the ocean is actually quite flat whereas the picture makes it look concave. There are two little bubbles that are not supposed to be there. Also note that the bottle has been clamped to the workbench. This turned out to be a really good idea because with all the inserting and extraction of the tubing, there would have been problems if it had been loose.
Leon is ready so it just remains to fold her up, insert her into the bottle and then raise her up again!
