Posts posted by CRI-CRI
Now, after the eighth frame, the shape moves slowly near the quarterdeck, 50% is done :
- GrandpaPhil, mtaylor, bruce d and 2 others
- 5
Could an administrator move this interessant discussion into appropriated topic : Charles Galley by Allan ?
Thanks,
Christian
- allanyed and Bill Morrison
- 2
And the seventh frame is done :
- bruce d, Sea Hoss, Bill Morrison and 4 others
- 7
And the sixth is done : the fore frame beginning to appear out of close nothing :
- GrandpaPhil, mtaylor, Bill Morrison and 2 others
- 5
Hi Bruce,
I fix my bulwarks with two opposed half notches (male and female), one down the mould, and other up the keel
Regards,
Christian
- mtaylor and Bill Morrison
- 2
Five / sixteen bulwarks = 31 % done :
- davyboy, GrandpaPhil, mtaylor and 2 others
- 5
25 % of bulkheads cut (but not glued) :
- Bill Morrison, davyboy, GrandpaPhil and 1 other
- 4
Following skeleton of ship :
- 4
i have a dictionnary of marine vocabulary of 18th century... but you have to open it for use...
Moby Dick's monograph exists also at scale 1/36 = length 2.20 m 😘
- mtaylor, flyer, GrandpaPhil and 1 other
- 4
First frame in position, it will be a fat boy, miraculous, floating line is OK 😘
- davyboy, Bill Morrison, mtaylor and 1 other
- 4
A test of a simulated trailboard shock (not glued) :
The two solutions without sinking gammonings :
I suppose that the piece 204 don't arrive at height of upper volute (hances and standard knee are different pieces)
- Bill Morrison, mtaylor, bruce d and 1 other
- 4
Today work without gammoning holes (and not glued) :
- Archi, GrandpaPhil, bruce d and 2 others
- 5
On 3/16/2021 at 4:19 PM, Hubac's Historian said:
[...] if it were me, I might redraw the timbering, so that the gammoning didn’t pierce at an awkward place below the lower cheek, and I would probably cheat the waterline down by a 1/16” - 1/8”.
It may not be exactly right, but it is more correct LOOKING than what Lemineur provides for [...]
Here I show you a redraw of plan using your recommendation, and water line cheated down 1/8" (around 3-4 mm) :
The ropes will be out of water, but with the decorative element hidden by
gamonning, without inconvenient, it's not an immortal masterpiece of Art 😋
- GrandpaPhil, mtaylor, bruce d and 1 other
- 4
The first rail is almost finished, closer to a work of sculpture than of engraving :
Then, like pancakes, turn it, and start again the same work of cook, without burn out 😘
I had inform you that I decided to follow my first idea about gammoning of S-Philippe, I cannot follow the sinking ropes... 😘
I received a notification of a message titled "test" send by you, but I found any message on site ? What a curious mystery ! 😋
- Bill Morrison and mtaylor
- 2
I have the "choice" between an historic "probability of truth", and another approach, more "creative"
J-C Lemineur wrote to me that my proposition had existed, but later, then it would be an anachronism, that's also your point of view...
I shall take a moment of reflection before a definitive decision 😘
Yes, it's what you've understood, If you know the kit of USS Conferderacy, it's the model i'm following for improve the S-P gamonning
I shall not modify the waterline position, because it's an absolute reference for all the built
Don't forget that these holes will be hidden under a furring deck, SP seems to be a little difficult, but nothing really impossible for me... 😘
Some end of afternoon small work :
These illustrations show little more about this rather difficult question :
Possible rectified gammoning's holes simulation :
- Sea Hoss, GrandpaPhil, Bill Morrison and 1 other
- 4
Saint Philippe 1693 by CRI-CRI - scale 1/72 - French warship from Lemineur monograph
in - Build logs for subjects built 1501 - 1750
The ninth frame, 56% is done (not glued) :
After each adding of wooden cut, I verify all curves and alignments to be safe
