Posts posted by CRI-CRI
With vertical frames, it's possible to draw floating line as reference, and that's I preview :
- Ondras71, GrandpaPhil, captain_hook and 3 others
6
I try to follow my built with a paper frame of head's knee :
I answer J-C Lemineur about a curiosity (I've never saw that before...) : the gammoning's notches sink under the floating line...
I shall tell you the response when received -
Following work about the keel :
- GrandpaPhil, Bill Morrison, mtaylor and 1 other
4
Beginning of curving rabbet, 1 mm deep for 2 mm planking :
- GrandpaPhil, Bill Morrison, mtaylor and 2 others
5
Beginning of work by the keel, which will be horizontal, with equidistant and vertical frames, to improve the general look :
Beginning of cut of frame's patterns
Waterline in blue (like a famous Rhapsody... 😋), and first gun-deck figured in red color :
It's also possible to use blind cannons barrel for the two down invisible gun desks, to simplify... No desk built would be necessary 😋
- mtaylor, Bill Morrison and bruce d
3
After verification with Jean-Claude Lemineur, author of Saint-Philippe's monograph, the ship has a rear inclined keel :
For exact construction, reproduce this angle pf 1.2 ° by a 1.2 cm part placed under fore keel, and install vertically all frames
For a closed hull construction, it's possible to ignore this particularity, because the difference is very small with 1.2 cm for one meter length, but, in such a case, it will be necessary to prepare a new draw of the horizontal keel, the result of general look could be even a little more "elegant"
3
I have now some wooden orders to place with my supplier, before following the work ☺️
- mtaylor and Bill Morrison
2
The keel was copied from the 1/72 source plan, and it's dimensions verified with compass :
You can see the notches (green on the screen), placed towards the position line for the frames AR (rear), and forward for noted AV (front)
The keel is subdivided into two parts : the keel itself, and a thinner false keel, placed above it, that receives the down notches, the difference in thickness between high and down parts providing an uniform bulkhead (râblure in french), without to dig it into wooden mass (this simplified process was successfully used on USS Confederacy, and Niña, both in closed built)
The other functions of this false keel is to support the first gun deck with adapted camber, which will be applied to all other desks of ship
- bruce d, Bill Morrison, davyboy and 2 others
5
The drawing of all frames at scale 1/72 is done (following step of plan's report will be the keel) :
I received this morning the 1/72 edition :
First step : preparing all paper frames and order the different woods for building skeleton...
- davyboy, mtaylor, Hubac's Historian and 4 others
7
New simulation of colors harmony :
Comparing the sizes between the future Saint-Philippe at scale 1/72 and Model Shipways USS Confederacy :
I inform you that my order for the 1/72 mono of St Philippe will be send to me next Monday...
After recept, I hope starting this new challenge 😀- mtaylor, Edwardkenway, Archi and 6 others
9
On 2/11/2021 at 11:55 PM, Louie da fly said:
Congratulations, Cri-Cri. That's a beautiful model. Do you know what you're going to do next?
Steven
Thanks Steven
I have the project of modelling a simplified version of the Saint-Philippe, a french at time of Louis XIVth, a three decked war ship, but I have first to read all the documentation (weight = 4 kg... 😘)
At scale 1/48, it's a 1.20 m length baby :
- bruce d, GrandpaPhil, mtaylor and 3 others
6
Saint Philippe 1693 by CRI-CRI - scale 1/72 - French warship from Lemineur monograph
in - Build logs for subjects built 1501 - 1750
Jean-Claude Lemineur wrote me that verticalised and equidistant frames will be without real visible difference about shape of hull
Here, as previewed, pics of a simulation of gammoning :
