robert952
Everything posted by robert952
  1. I realized how often I look at your posts on this build as I peruse recent posts. I am jumping on board to watch the rest of the build. As with most projects there's problems we have to solve (like the deteriorated decal) that need unique solutions. Part of the challenge and rewards when assembling model.s The model looks good. I look forward to the rest of the build.
  2. Both look great. I enjoyed reading along as you built your log here. Thanks for sharing.
  3. I go back to the basic concept of what is of interest to me. I temper that with a bit of what will I learn or get better at skill set-wise. I won't be surprised if I pick out a non-ship model plastic model (or even metal) in the future as variety is the spice of life. I know I need to relearn and improve my plastic assembly, detailing and painting skills. So, that may be in my future, too.
  4. Welcome to the madness of MSW. Your tale is similar to mine. I still have a skelton hull about half-way planked of the Golden Hinde from Mamoli. I enjoyed what I did and what I learned from that work, but realize I had to get some of the basics under my belt. Start a log on your build. You'll find a lot of people who like to learn from others and share their experiences and expertise. (From me, you get more of the former than the latter.) Have fun. And remember:
  5. This is looking good. Yep...learning process continues with every build. Yep...every kit has some 'anomaly' that doesn't show up until you assemble it. And you probably will notice the errors more than a lot of other people when the project is complete. We tend to be harder on our own critique of our work. However, you are doing (IMHO) the correct procedure: Keep Calm and Carry On. And as a QA manager told me what they did on the factory floor: File to fit. Hammer to adjust. Paint to Hide.
  6. I read through your log again and I may have overlooked whether you beveled each plank as you added them. Like you, I soaked the plank and clamped it in place overnight. I left them a bit long so I could cut to size. Keep in mind that my method here is based on upside down hull. So top and bottom is relative to that position. The top of the previously installed plank is left untouched. After next plank dried I put a slight bevel on the bottom edge of the next plank. It was just enough to allow the plank to fit flush on the lower plank and to the frame. I think that helps avoid the clinker effect. I also beveled the planks on each end a bit to fit to stem posts. I was careful to mark stern and bow on each plank since they were 'custom fit.' Finally, I beveled the backside (closest to the bulkheads) of each plank (as you did) to fit to the posts. Entry #6 of my build has some pictures that may help. As for gluing the bilge area, I did like you and used a lot of rubber bands. I also put a piece of wood under the building base to keep the rubber bands tight to the form. It is a tedious job to shape those planks to size. My results weren't pretty. I had to cut some filler pieces. From the beginning as I put the planks on I knew I'd be doing a lot of filling and sanding. (No matter how new the blade on my knife, I couldn't keep the cuts neat.) Entry 15 of my build log shows the ugly details. (However, filler and sanding made it look better.) I think the kit is rated at the proper skill level of 2. Over the years I have seen similar definitions as those that appear on this kit defining the skill level requiring cutting and shaping of wood. When I began working in wood, I started on a model of The Golden Hinde. Like a lot of beginners, I (finally) figured out I needed to learn some basics. A lot of modelers quit at this point. I (luckily) found MSW and read through a LOT of posts. That encouraged me to keep on trying. So, I got a Level 1 kit and built it in a weekend. I figured Level 2 would be the next step. But I found, as you did, it's still a challenge. (And I added more challenge by modifying my build with a keel and sail.) Now whether this should be the second or fourth model someone builds is a personal call. I feel each model we build should offer some kind of challenge. When I look at a model, it's hard (for me at least) to deterimine if my skills are up to snuff. However, I know it's going to be a learning experience. With all that said, I am impressed with how your build is going. You have overcome the challenges very well. So, don't be too hard on yourself. In some areas I wish my build looked as good as yours at the same point. As to 'plunging in for hours,' you'll probably get there. My wife was working a late shift and usually got off about 1AM. Sometimes she'd get off early. I was working on a plastic model one night. I started about 7:30ish. The model was fitting togther well. I was moving along in the process. I heard the door open. I yelled out, "Things slow at work tonight?" figuring she got off early. She said, "Are you alright?" I relied, "Yeah, why?" "Do you know it's almost 2 AM?" Uhhhh...nope. I guess I had made the plunge.
  7. This seems to be a great model to start on for a first build. Don't be afraid to ask questions. Ships are a bit different that Gundam. 😁 Good Luck.
  8. Sitting on the dock of the bay, watching this build on the way. I like watching the smaller builds.
  9. @JacquesCousteau Thanks. Lots of photos and art works and various modeling sites too. The choices and inspiration won''t be the problem. Deciding how to go will be the challenge. @Bryan Woods Except that Ihave too much invested in this new house and yard, I probably would. However, lawnwork and gardening run in my genes. My Dad (in his 90s) works daily and has an beautiful lawn. @Desertanimal Thanks for the well wishes. I feel I am still feeling my way around to find my true interest. I do like the small boats and may gravitate towards those. However, I have some large models/ships in my stash. They still pique my interest.
  10. For now I am calling this an 'non-build log.' I didn't realize how long it has been since I posted (January, 18!!!). But there's nothing to update per se on the build. Lots of RL excuses: major yard work, getting contractor to build fence, staining same, and a couple of similar projects that took me up to April. Then RL decided to throw me a curve and introduce me to lower lumbar back pain in early-May. Without the details: I can't sit for long periods of time except in my recliner with various pain management stuff. After visiting four doctors to cover my options, I am scheduled for surgery in mid-October. Hopefully, a few weeks after that I can return to 'active duty.' That said, I haven't been completely ignoring the project. While in my recliner I have been researching gaff sails and rigging, pintles (of sorts), making sails, rudders, reviewing air brush techniques and weathering techinques. Lots of reading of logs here on similar small boat builds and these subject matters. I even did a couple of 'test runs on stuff.' I'll cover that later when I get back to the build. I have also been making plans for a future project with a dory kit a friend gave me. One of my first completed wood models was the same kit. The kit is a basic kit (level 2). But as I pointed out early in this log, I believe that simple kits provide an opportunity to challenge builders with changes to the basic model or a vision of a different techinque for the build or display. On this next build of the dory, I plan to do a 'diorama' of sorts. I will weather the boat and (current plan - subject to change) have it tied to a weathered dock set in some form of expoxy 'water' shoreline. So, I have lots of videos in my faves on a whole bunch of stuff related to weathering, creating water, even model train terrain making. I also found what I think will be a suitable display base. Again-subject to change. Just making plans and looking at options. So, I am not abandoning the build. I just have to get some things fixed healthwise. I felt I needed to let the world know I am around. Maybe not kicking much. And to let those following, this project is not abandoned.
  11. Following along. Good start. (You reminded me I need to update my 'un-build' log.)
  12. @DerekMc It also looks like you have quite a store room for your stash.
  13. @Dave_E A very ecclectic collection of items in your work area: Lava lamp, Greek vase (well it looks Greek), Tommy Emmanuel poster (great entertainer - seen him in concert a couple of times), etc.
  14. Great progress on this build. I probably speak for others by thanking you for the detailed photos on the project.
  15. Great progress on this build. Looks very nice. Thanks for the detailed pictures showing how you did the work.
  16. My workbench area. Bench itself. I have a computer station in the room, too. I use the same wheeled chair for both. And my humble nautical/modeling library.
  17. Nice looking boat. Great build. Thanks for taking time to detail your adventure.
  18. Coming in late to this party. Read through the log tonight. Thanks for all the photos. They really show the methods for building all the smaller pieces.
  19. Both look super nice. Each is unique and shows how there's more than one way to build models. Good job on both.
