Everything posted by Valeriy V
Ras, your path of growth in skill makes me watch without stopping! Remarkable progress!👍
- 128 replies
- zulu
- sternwheeler
Phil, if you haven't made a final decision on the planking option for your ship, I suggest you consider my option. I recently used it instead of diagonal planking as an experiment, and was pleasantly surprised by the result. - plywood thickness for frames - 6 mm - ash veneer thickness for side planking sheets - 1 mm Ash veneer fibers must be placed along the length of the hull, and then it will tightly fit the frame contour without internal stress. The strength of ash allows for a minimum veneer thickness of 0.8-1 mm. The hull will then be covered with a layer of fiberglass and resin. This method is not suitable for a floating model, as the hull will be heavy, but it is quite applicable for a static model.
- 378 replies
- minesweeper
- Cape
Phil, your stories are no less interesting than building a model! I will watch your work with interest. Will your model float on water?
- 378 replies
- minesweeper
- Cape
