About Matt D
- Birthday 03/21/1972
Gender
Commerce Township, Michigan
Interests
Building models of ships, airplanes, and rockets; photography; bicycling; scouting; skiing; boating; trying to fly RC helicopters
Matt D reacted to a post in a topic:
Sloop Speedwell 1752 by Rustyj - Syren Ship Model Company - 1:32 Scale - POF Sloop
HMS Portland 1770 by Rustyj - Portland Scale Ship Co. - 1:48 - 50 gun 4th rate
Sloop Speedwell 1752 by Chuck - Ketch Rigged Sloop - POF - prototype build
Chucks Prototype Double Capstan (3D print and laser cutting group)
USS Constitution by Herbert Heger
de Havilland Tiger Moth by rvchima - Easy Built Models - 1:17 - balsa
Speedwell Battle Station Kit 1752 by CiscoH - Syren Ship Model Company - 3/8" or 1:32
Sterling59 reacted to a post in a topic:
DONATE NOW TO SUPPORT MSW
FrankWouts reacted to a post in a topic:
HMS Winchelsea 1764 by shauer - 1:48
shauer reacted to a post in a topic:
daHeld73 reacted to a post in a topic:
Frigate USS United States 1789 by threebs - FINISHED - 1:72
Chuck reacted to a post in a topic:
Ordering CNC milled carving sets for the Winnie or resin cast sets
Virginia 1819 by Matt D - FINISHED - Artesania Latina - 1:41
I can’t believe the dumb mistake I just discovered. Way back in chapter two, I put the anchor shield in the wrong spot. Now I’m faced with a dilemma and I’d love to get some opinions. As I see it, I have a few options. 1: leave it as is and install the billboard above it, also in the wrong place. 2: try to remove it and install it in the right place. As I see it, this is very risky. I’m not sure if I used CA or PVA to attach it. Regardless, taking it off could cause a lot of damage. 3: leave that one there and install a replacement in the right place. 4: leave it where it is and install the billboard in the correct location. What do you think?
Wow! Well done. These boats are so neat, but they really look challenging to build. You’ve done an excellent job on yours.
- 28 replies
- 22 ft yawl boat
- Vanguard Models
Looking great, Steve. Welcome to the Winnie Group. This is a fantastic project and I hope you enjoy it. I’ve said this to others, and it keeps getting to be more true: you’ve picked a great time to start the project. Chuck’s new parts are getting better all the time, like the laser cut caps for the cannon, 3d printed deadeyes, and the new version of gun port cover hinges. Plus, there are a lot of logs to look through and still a lot of people working on their models. I look forward to watching your progress.
I’m still making slow progress on my HMS Winchelsea. I have a milestone to report: I’ve finished chapter six! I was short by eight cannon and found time to finish them. It was a concerted effort as it started to bother me. One consequence of dragging my feet was that I could not use the belaying pins from The Crafty Sailor for the last few. I ran out and they closed shop. So I broke down and did it the way Chuck said to do it: I turned them in my Dremel. I’ve also started chapter eleven. I assembled all of the chainplates as prescribed. I’ve mounted one as you can see in my pictures. I was very nervous about removing the molding, but it wasn’t really that hard. I just took my time on the cuts and loosened them with CA Un-Cure. I’m using the new 3D printed deadeyes in Swiss Pear. They look fantastic. There’s a ton of work to do in chapter 11 so I’m sure it will take me a while to finish it. Moldings removed to make room for the chain plate Ship’s Wheel and binacle set in place Chapter six complete! Kind of - they aren’t fixed in place yet. Port side foremast chain plate in place. I had to see how a deadeye looks in place. It looks surprised!
Hi Frank. I’ve make a little progress, but nothing ready for pictures. I have the chain plates assembled (chapter 11) but not installed. I also finally finished the last of the gun deck cannon. I was short by six for the past two years. I should be done traveling for work. But life is getting in the way of hobbies right now.
It’s looking great, Peter! I’m glad to see you’re still at it.
- 222 replies
- sultana
- model shipways
Hi David. I recommend reading build logs for any model ship kit before taking the plunge. Then base your decision on what you see in the build logs.
I can’t tell you the last time I made any progress on my Winchelsea. And it’s not getting better soon. I’m in the UK for work for three weeks this month and coming back late next month for four more. Today was my first day off since I arrived, so I went down to Greenwich to visit the NMM. Unfortunately, they’re renovating it and a lot of models are off display. Here are a few pictures of what I saw.
