src
Posts posted by src
Jay, I dont think I will try, those "rivets" are brass rod hammered over to form a head and epoxied in also. On a side note I wish I had seen the posting here about making nails, I could have made mine on less than half the time it took to heat and mushroom over.
Based on Keith's observations, if I can get the reaction to stop I will try to airbrush some color over them. It was something I planed to do anyway. I was ok with the pintles, from normal viewing distances they looked aged and I kid of liked the look. I was going to try to get the gudgeons a bit closer and call it a learning experience.
Sam
Below is the PM I just sent Keith.
A couple of things occurred to me as I was responding.
- Minor detail - parts were filed to #4 cut file not #6. I dont think this played a part
- The gudgeons were blackened separately not at the same time. I know because I remember trying to match the color on the gudgeons to the pintles.
- I believe all the parts were made from the same brass stock but I cant swear to it. I bought a full box of 1/64x1/16 brass strips from an online hobby store, I need to look up the store but I want to say omnimodels.com. I think I may have had a package from my LHS but it was still K&S brand
- I am 90% certain we started a new bottle of dish soap between blackenings.
- Somebody asked about flux, yes I used Ottoflux from OttoFrei.com
- all excess solder was filed off and I had a nice bright shiny bras part when I started the cleaning process
- All my water was distilled water - I have done a fair amount of chemical wood staining in the past and learned the hard way about tap water and chemicals.
- The oil used is Tried and True Boiled linseed oil - a true boiled oil; no chemical dryers used, its non-toxic they claim you can use it on wooden bowls but I have never tried it.
The rest of the process is detailed below
Keith,
Thanks for responding. My gut was telling me that you would give me an answer like that. No worries.
I cant say for sure whether the pintles and gudgeons were from the same brass stock, I want to say yes of course. I have bought numerous brass pieces over the last several months. It is very possible they came from two different sources although my memory is that they all came from the same box of brass. I have found its easier to buy a whole box of brass online rather than one or two sleeves. 7 bags of two strips was almost the same price as 2 bags at my LHS. But like I said I have bought brass several times over the last year both online and at my LHS so I really cant say for sure.
Thinking back the gudgeons were blackened separately but the process was the same. With the exception of the soapy water and first and final rinses the containers had the same solutions in them
As far as touching the parts, once they were cleaned in soap and water I used latex gloves and tweezers to tie them to some 2 lb fishing leader.
The entire process was
- Anneal
- form
- silver solder
- Mark and drill the "rivet" holes
- File with #2 then #4 cut swiss files
- rub with purple nylon scrubby pad where I could
- tie o fishing leader
- Wash with hot distilled water
- rinse with distilled water
- soak in 50/50 muriatic acid - diluted with distilled water - agitated every 10 minutes or so for an hour
- Quick dunk in distilled water and baking soda
- final rinse in distilled water
- soak in 50/50 blacken-it and distilled water for 10-15 minutes agitating every couple of minutes and watching for color
Not sure what happened between blackening one set of parts to the next but now I am thinking something contaminated one of the solutions. They are kept in tupperware style containers - glad disposables.
We did change dish soaps come to think of it, I wonder if that may have anything to do with it?
Thanks again for your time
Sam
BTW, loving the Pink Floyd themed build!
Hey Rich, how is the build coming?
sam
Robbyn, Looks great, great work! do you like the rope your using? Morerope i think? I am thinking about replacing my kit rope. Heard good things about both Morerope and Chucks rope
Rotties are great dogs - is there truly a bad dog though? A friend had one that thought it was a lap dog.
Sam
Jay, you posted while I was responding. I wore gloves and tied everything to some 2lb nylon leader material
sam
Hi Druxey,
thanks for getting back to me. I used 1/64x1/16 brass strips from K&S. I annealed, formed, silver soldered then filled with a #6 jewelers file and scrubbed with a nylon brillo pad where I could. Cleaned with Soap and water with distilled water, rinsed with distilled water. soaked in muratic acid then rinsed in distilled water. Blackened in Blacken-It diluted about 50-50 with distilled water. Glued on with 5 minute epoxy as well as "nailing" with blackened nails and some epoxy.
Sam
Can anybody tell me what is happening here?
I finished installing my pintles and gudgeons a couple of weeks ago. Had a bit of a issue with the blackening rubbing off when I oiled over them. I am ok with the rudder pintles, it looks weathered, the gudgeons came out differently. My plan has been to go back and touch up the gudgeons and try to match them to the pintles. Work has kept me from sitting down and working on the problem till this morning. Now I see what appears to be sweat on the gudgeons as well as some green corrosion starting.
Anybody have any idea what the "sweat" is a and what I need to do about it? It is hard to see in the photo but in the areas where the blackening has rubbed/flaked off there is little tiny drops of what looks like water or glycerin. I will try to get a better photo. for now there is this one.
Hmmm Interesting idea. Like the others it sounds like a recipe for disaster but then I am not a real big fan of CA myself; I use it but very sparingly.
There are a couple of chemists here, if they dont respond here in a couple of days try searching the user names, at least one of them has chemist in his name. Give him a PM, I have not interacted with him but he seems like a very friendly decent person.
Edwin, I missed you somehow, thanks for stopping by and the kind words, I've been enjoying the journey.
Sjors, Thank You! Dont tell the Foreman but I borrowed a couple of the Gnomes, hope you dont mind.
Russ, Robbyn, Thanks!! I had started out with brass pins in mind, then looked at my Fumbling Fat Fingers and thought to myself, "Self, you're never gonna get these steps lined up and spaced correctly this way." In my mind at least a mortice gave me some adjustability left and right.
Looking back at it, I could have used the cad program to do the layout and pin locations then used a straight edge to keep everything even. Ah well, this kept me busy for a few hours (days) and kept Captain Grumpy banished to the cornfield.
Sam
Sjors, she looks great!
Sam
John and Rich thank you !!
Been slow here, that evil nasty four lettered word WORK has interfered with play time again, gonna be busy till the end of November it looks like. Which is good, just limits playtime.
I have found time to make my entry steps. As of right now I have just done four between the wales. The spacing I used would put a fifth right on the joint of the two lower wales. I looked at a tighter spacing but it looked cramped to me.
Since I have already put several coats of oil on I didnt really trust a simple butt joint, even scraping I was concerned that I wouldnt get a nice strong adhesion. I chose to mortice the steps into the hull. The instructions called for 1.5mm x 4mm planks but that left me nothing for a tenon so I dug up some of the scrap 2mm caprail material. 2mm looked really thick so I tapered the edge. That left me with a more narrow face and a reasonable tenon. It was also, to my eye at least, hinted at the shape in "Fully Framed".
I drew up a template on some address labels in a cad program I have here, I really miss AutoCad, Cadintosh is just a toy compared to ACad. But it was free, you get what you pay for I guess and once it was drawn up it really helped keep everything lined up and spaced properly. I could have drawn them up at work but it was Saturday and I was on a roll.
I managed to fit all the starboard steps in about an hour, the port steps took me more than 3 for some reason. They are done though. When I got down to the fourth step I realized I had a problem, the taper didnt work with the upper wale so I made a second set with a "More Different Kind of Taper'
Found another use for my true sander
A nice little taper to clean up the parts
Drew up a pattern in "Cadentosh"
Chopped some mortices
Oiled and glued in with a More Different Kind of taper on the lower step
Thats it for now.
Sam
Sjors, I go away for a few days. come back to a celebration and string everywhere!! looks good.
ummm.......Whats a "Gasbag"??
Sam
Brilliant! I wish I had seen this when I was making the bolt heads for my pintles and gudgeons last month. Next time.
Thanks for sharing
Sam
Robbyn, yes I think they want to be clear of the water, I dont know how much something small like that would affect performance, an engineer could tell us I am sure. My best guess is they would have been mortised and then through bolted into the hull, even then the constant beating of the water would tear them apart. I think
I nowI need to go one higher.Sjors, Thank you! Yes I am not sure if I can look at the steps that close together, I could thin them down of course. My only source of reference with scale drawings is "Fully framed II" That shows a 12" rise and much more detailed steps. I will stick with the simple steps from the kit since I havent done any elaborate molding anywhere else. Next Build....
Brian, The difference in average heights crossed my mind but but my couple of reference books showed a larger spacing. I think if I were to make a more "accurate" step they would not look so cramped. I am sure Constructo has simplified the steps as they have everything els on this kit.
As far as aging Admirals go, I wonder. People were more active then, my guess is an "old" man of 50 back then was probably more fit then a lot of mid 20's men today. I certainly wasnt there then so i dont really know.
In the end, as Sjors and many others have pointed out here and elsewhere, I have to look at her when she is done.
Sam
Robbyn, I am, I just try not to let it go to my head and know I can always do better. Most, not all, of my grumbling is my way of reminding myself where I would like to improve on my next build.
Sam
Sjors, Thank you!! Always a pleasure to see a new face. No apology needed, there are so many great builds here you can never see them all. I am always pleasantly surprised when somebody new finds my humble little offering.
Work has kept me busy for the last couple of weeks so no real progress has been made. I have not wanted to work on the rudder and feel rushed so its sits the way it was last week.
I have had a minute here and there to work on some simple things like the entry steps. Got a question if somebody can help. The instructions call for 5 entry steps between the upper and lower wales. the space between is 18.5mm or 3.1 feet, Thats 7.25" rise, seems a bit close to me. The picture below shows about where I think the water line would be, the plans dont show a water line. The red lines on the left are an approximation of the kit spacing. The lines on the right are my best guess and scale out at about 12" rise. I am strongly leaning towards the right but not sure how far down to go.
Feel free to edit my photo if there is a better way to approach this
Edit: the above pic really doesnt show up well, this is a little better:
In honor of todays visiter and since I never posted a picture of the finished door, an extra picture.
- popeye the sailor, mtaylor and Sjors
- 3
Sjors, Looks GOOD! Hope mine looks 1/2 as good when I get there.
And yes, keep the Gnomes busy. idle gnomes are bad.
Sam
Robbyn,
Not sure if I understand the situation correctly but your disk idea may not work, I would be concerned that when you hit the metal going through your predrilled holes you may follow the old holes in the metal. Your best bet might be the JB Weld others mentioned. at work we use a product called PolyGem to work all sorts of "magic." I undersand there is a consumer version used here call Sculpy. That ma be another option.
Edit - looks like we replied over each other and you have a solution
Sam
1) Yeah, caught with my pants down and no gun!
2) If this happened in Texas, it'd be a whole different outcome!!
Rich,
1) There is a joke there some where I am sure!!
2) Yes! "Dont Mess With Texas!"
As much as I want to see updates, I am kind of hopeing there wont be any for a bit since that will mean you got the job!
sam
Enterprise 1799 by Archicar - FINISHED - Constructo - 1:51
Rich, great Job!! Congratulations!! Something to look back on and WHY would you want a dislike button??!
Sam
