Posts posted by capnharv2
The problem I've always had with the smaller collets and bits is runout. The just don't run true.
Another solution is to order 1/8" shank drill bits from a place like Drill Bit City. They have #80 bits with a 1/8" shank. I've found they work very good.
Thanks
Harvey
Eeek! Take care Nenad. Hope your residence is high and dry. And remind Hothead that motorcycles and high water don't mix.
Harvey
Thanks Jay. When you mentioned the ratios, I thought it was West System. I haven't had the best of luck with it, but I'm sure it's user error.
Glad to see your progress on Pelican. One day (when or if I get caught up with my unfinished/unopened kits) I want to do a model to one of his plans-I think I have copies of them all.
Harvey
Jay,
What epoxy are you using?
Thanks,
Harvey
Nenad,
I like that. "Not bad, but it can be better. On the next model" I think there comes a time, in the build of each of our models, that we have rebuilt something 2-3-4-40 times, and realize that the return on time invested in that particular model just isn't there. Why should I spend 3 years working on the rigging of my model when the hull (to me) looks awful?
The important thing is that we have fun in this hobby. Hopefully we learn from our previous models (and mistakes) and the next model comes out better than the previous one, and so on.
And, your model is looking better every day.
Thanks,
Harvey
"Interesting idea. I have no clue what the difference is between the two Prides other than a couple decades between their construction. I think they modernized Pride II a bit but I don't know if the general design itself was changed."
I don't remember that many details, but Pride 2 is bigger than Pride 1 and meets more CG regs (such as water tight bulkheads). I believe Pride 1 was more "authentic" and inherently more dangerous.
Baltimore Clippers were not necessarily designed for offshore use, yet Pride of Baltimore 1 went to Europe and the West Coast several times. I read that, when she sailed in a good blow, her topside planking would open up, and she would leak very badly.
Your model is looking good!
Thanks,
Harvey
Pink Paint. That's a good idea. Tell him it will help him find it in a parking lot
Harvey
- michael mott, mtaylor, NenadM and 2 others
5
You do know that the smoke you see from mixing HCL and NH3 will produce Chlorine gas
As Elmer Fudd would say
“BE VE-W-W-WY, VE-W-W-WY CAREFUL” -
Nenad,
I would have done same thing as you
Harvey
Kimberley,
Thanks for the pictures of the paint pens. I'll want to take a look next time I'm in the hobby shop.
Your deck is looking good!
Harvey
Is the cutout for the prop??
(as Harvey ducks and runs. . . .)
Crackers,
Beethoven is excellent, but I'd prefer Mendelssohn's Scottish Synphony.
Can't go wrong with the Brandenburg Concerti or Handel's Water Music either.
If I were building more modern warships (especially WW2) i'd go with Richard Roger's music from "Victory at Sea".
But to each their own.
Glad to see a build log of the Gorch Fock in the works.
Thanks,
Harvey
If you start spraying with paint cans, one useful device is somethin called a "can gun". I basically slips over the top of the open spray can and remotely activiates the spray button. Some people have had great results with it, others, not so much.
They run about 4-5 dollars at the hardware store. I like them-they seem to help the spray stay more uniform when it comes out.
And, I assume you've heard/read about the turning the spary can upside down when you're done, and spraying till only clear propellant comes out. That, and a wipe down of the nozzle with paint thinner, should give you a fresh start on your next spray job.
Could you post a pic of the Testor's paint pen? I believe I've seen it, but would like to see it again.
BTW, great job on the white stripe! Looks good an crisp!
Thanks,
Harvey
Well Floyd, sometimes you gotta take things into your own hands . . .
Harvey
USS Constitution by Hipexec - FINISHED - Constructo - 1:82
Rich,
Have you thought about making your own cleats? Floyd Kershner has a neat little method for making them:
http://modelshipworld.com/index.php?/topic/1906-wooden-cleats/
