Posts posted by DanielD
Good evening mates, in addition to working on the small boat I-beam structure, I have been detailing the OcCre supplied hull to a more realistic small boat by adding a scratch built propeller and rudder. A few more details to add, small railing at the stern, rope coil at the stern and of course the boat ID, NC 90.
- Desertanimal, Knocklouder, hof00 and 6 others
- 9
- Dave_E, clearway, theoracle09 and 2 others
- 5
- Alexander Bulimov, Dave_E, hof00 and 5 others
- 8
- ccoyle, theoracle09, clearway and 1 other
- 4
Good afternoon mates, it’s been awhile since last update…life has just been busy.
Been working (slowly) on a set of stairs leading to above the main bridge. The real Amerigo Vespucci has wooden steps, almost ladder like, with brass handrails and brass stair tread protectors. I’ve attempted to build something similar.
Welcome to MSW!
Good evening mates, it’s been well over a week since my last update. It’s not because I’ve been lazy, but rather the fore mast has been a bit of a challenge as it has an additional platform with spot lights and railings. Also, it has a radar installation with a wire cage that was a challenge to get to look more like the real AV. Not to mention the marker light at the top of the mast and deck lighting under the platform and all the associated wiring. It’s now ready to primer and paint. Should be another week or so before final installation on ship.
- hof00, JacquesCousteau, clearway and 2 others
- 5
Update on my search for a lantern. Below is an image that shows a lantern on the stern of the Amerigo Vespucci. I believe this to be a decorative option that they sometimes install it when in port as I have seen many current and past images with and without the lantern. I have decided to showcase this lantern on my AV with LED illumination. To be close to scale, I need a hollow lantern that is between 10-15mm tall that I can paint to make look like brass. I have checked into the Caldercraft lanterns for the HMS Victory which are unassembled brass except that the smallest one available is at 16-18mm. This option is about $19 plus shipping; however, finding it available in the U.S. has been difficult. A second option that I found (smallest version) fits right in at 15mm is a 3D printed set of lanterns for the HMS Victory from Shapeways $13.50 plus $8 shipping arriving in about 3 weeks.
Both of these options are viable. 1) Having a metal brass lantern would be wonderful, but hard for me to get, and slightly too big, and assembly may be a challenge. Option 2) 3D printed version manufactured in the U.S. without much assembly but delivery time is long as they are manufactured upon request so no stock on hand. Hmmm.... Has anyone used either of these options in their models? How have they worked out?
Good day mates. Have you ever had "one of those days"? Well, I have been having "one of those weeks!" It started when I realized that I needed to drill a 1mm hole in 3 places on my mizzen mast for future rigging. As you may know, I have wires running through the middle of the masts so these holes should have been drilled before I put the wires inside. My new plan was to gently drill the missed holes. Well...I apparently nicked one of the wires on my first try and as a result the red marker light at the top of the mast no longer worked. As such, I had to dissemble the entire mast, pull out the damaged wire, DRILL THE MISSED HOLES, reinstall the wires with a new LED as I damaged the old one getting it off, remove the paint and primer as I scratched up the mast adding the holes, and sprayed a new coat of primer. This time before adding the final color, I added the strings of rivets to the lower two sections of the mast I forgot to add the first time around. Last night I sprayed three coats of the final color and set to dry over night. Tonight I hope to touch up the white and black details and re-install into the ship (hopefully for the last time) with working lights! All in all, about an 8 hour mistake.
What is your biggest model screw up that cost you more then a couple hours of time?
Updated pictures coming once I have the mast installed again.
Good evening mates, here is the latest from the Amerigo Vespucci shipyard. Finished the mizzen mast except for the rigging hardware. The white light on the main boom is for a lantern that I have yet to source. Currently I’m looking at a set of lanterns designed for the HMS Victory. The main requirement is that I need it to be between 10-15mm tall. Any ideas?
- SiriusVoyager, ERS Rich, Knocklouder and 4 others
- 6
- 1
Good evening mates, I finally started the masts for my Amerigo Vespucci. Here is the progress on the mizzen mast. The real AV has metal masts and I needed to get some wire to the top of the masts for the red marker light, so another modification to the OcCre plans in that I used appropriate sized brass tube so that I could run the wire inside the tube and all but be invisible. It’s hard to see in the images, but the red marker light is working as planned!
Amerigo Vespucci by DanielD - OcCre - 1:100
Good evening mates, I have completed the first of eleven small boats present on the Amerigo Vespucci. It’s as close as I can get as I have been unable to find many pictures of the NC 90.
