Everything posted by John Ruy
Bow Pulpit… @rshousha Note repair of Bow Pulpit as follows. I found the Bow Pulpit provided by Corel to not be a proper fit and needing quite some bit of adjustment (bending). I’m sure this how you found yourself breaking the part. In fact I had planned to fit the original part and cement the broken piece in place on the bow. Unfortunately, I too broke the other leg of the bow pulpit. So, I came up with a plan B and custom fitted the Pulpit into the railing. 🧐 I have found many of the parts provided needing to be “adjusted”. I personally am not impressed with the quality of the kit. I certainly would not recommend this kit for a beginner. 😆 Used my finger clamp method to hold in place while the CA glue cured. Successfully installed the busted Bow Pulpit. Onwards 🍻
- 84 replies
- Corsaro II
- Corel
- 84 replies
- Corsaro II
- Corel
Deck House and Cockpit… Trivit mounted in the cockpit… Wheel pedestal in cockpit… Deckhouse and Wheel mounted… Details added to Deckhouse Hatch, etc… Progress on Deck Furnishings/Fittings… Onwards 🍻
- 84 replies
- Corsaro II
- Corel
You must mean this break right on the tiny hole for the hand rail wire. Should be interesting 🧐 May have to build a new one from scratch. I will certainly post the fix when I get it done. That piece should be coming up soon. Unless I work the deck fittings from stern to stem. LOL 😆 Truth is I will probably put this off for it but to give it some real thought. 🤨
- 84 replies
- Corsaro II
- Corel
- 84 replies
- Corsaro II
- Corel
Found a short video of the Corsaro II and captured some stills that will help with placement and finish of the deck furnishings and fittings. Onwards 🍻
- 84 replies
- Corsaro II
- Corel
Making brass parts chrome
John Ruy replied to John Ruy's topic in Painting, finishing and weathering products and techniques
I decided to stick with the Model Master Custom Enamel. It seems to have good adhesion properties and shines when dry. Thanks again… 🍻 -
Thanks Bob… So gorgeous, I’m working on her jewelry as we speak. Very challenging, given Corel’s translated instructions. Although I’m not sure it be any better if I could read Italian. 😂
- 84 replies
- Corsaro II
- Corel
Thanks for all these great suggestions. I can always depend on this forum to come up with great solutions. I will probably go with a combination of chrome/clear coat paint and aluminum parts. I will definitely share my results here on this thread. Meanwhile, keep the suggestions coming if there are any other solutions out there. Cheers 🍻 -
I am looking for the best way to turn brass parts into chrome. I have just painted a brass propeller chrome with Model Master Custom Enamel System. Are there other products or methods out there? This looks good but will it work well for all of the small fittings in my Corel kit. Corel has supplied all brass fittings for the Corsaro. The photo above shows chrome for most of the hardware. Your collective knowledge will be appreciated. John
The Mahogany Rail continued… The stern planksheer is shown here as part 47. Unfortunately part 47 is 1.5 mm ply and the Rail is 2mm x 4mm solid mahogany. As seen here I will need to laminate the 2x4mm Mahogany to create this curved section of rail. The Rail or Planksheer as it is called out on the Corel Drawings and instructions, is now finished. Cheers 🍻
- 84 replies
- Corsaro II
- Corel
Hi Rick Agreed… Building the rails aren’t even mentioned in the instructions. I personally have not found any good instructions with the exception of Model Shipways New Bedford Whaleboat. That kit came with a book that was a build log of the prototype. It had very good instructions with photos it was written by the kit designer. That’s where I was able to improve my wood modeling skills. Most of these kits just aren’t assembly type model kits. I consider our “hobby” an art form some experience required. That’s why there are so many unassembled kits out there on eBay and in closets. Thanks for the opportunity, this kit is definitely challenging my skills. John
- 84 replies
- Corsaro II
- Corel
More sanding and another coat… She is coming along rather nicely, sure is a lot of sanding and painting. It’s getting there. Another sanding and we should be ready for the color coat. 😎 Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
One more coat of poly… Rudder… Cut from 1/14” pine lattice… Rudder fitted… Primer coat… Display stand painted Matt Black. I added felt pads to hold her hull. I could not bring myself to permanently attach this stand to this hull. Mahogany Rail… First coat of Polyurethane on short bulwarks and rail. It will need another coat or two. Onwards 🍻
- 84 replies
- Corsaro II
- Corel
It was an ink-jet printer. The water slide paper and acrylic sealer are readily available and MS Word has every font and word art to creat the decals. Vinyl Pin-Striping is a great way to add the striping, as well. John
- 84 replies
- Corsaro II
- Corel
Wow! Nice detail at this scale. Excellent Work. 👍
- 200 replies
- Whaling Bark
- Charles W Morgan
- 84 replies
- Corsaro II
- Corel
- 84 replies
- Corsaro II
- Corel
- 282 replies
- Bluenose
- Model Shipways
Decals and Strping… Decals produced in MS Word and printed on ink jet water slide decal paper. Bow markings and yellow striping. Stern markings… @rshousha Rick’s beautiful deck planking with its first coat of semi gloss poly. I’ll probably do another coat or two before I clear coat this hull. Cheers 🍻
- 84 replies
- Corsaro II
- Corel
Decking completed… …and Finished. Sanding the hull… Using an Acrylic Auto Body glazing and spot filler. The glazing worked well, you will want to keep it thin. It does sand easily… Ready for the paint booth with some Filling Primer. Cheers 🍻
- 282 replies
- Bluenose
- Model Shipways
It’s pin-striping for rc’s fuel resistant @rcmdrvr It also formed to the tight curve on the stern. You are correct Yves, I will be spraying on a Gloss Clear coat as soon as I get the yellow sheer stripe and Script completed. Photo courtesy @rshousha and the Italian Naval Academy. Thanks Rick. John
- 84 replies
- Corsaro II
- Corel
Finishing the Hull… I am using the above photos as my guide to finishing the hull of this impressive sea-faring yacht. I really want to get this right. 🧐 After 3 sanding and coats of paint, the final fine sanding is complete and we are ready for striping prior to the clear coat. Water Line striping completed… I am going to have to create my own lettering decals for the stern and bow. She is coming along. Cheers 🍻
- 84 replies
- Corsaro II
- Corel
- 282 replies
- Bluenose
- Model Shipways
