John Ruy
Everything posted by John Ruy
  1. Display Case from scratch… Using a table saw to cut dado joints in corner pieces. Ready for assembly… Clamping Top Frame… Used L-Brackets to support corners… Attaching the Top… Painted Black Semi Gloss… Cut Green Edge Plexiglass with table saw. Mounting the Robert E Lee. Used two spots of PVA Glue on the Flat Bottom Hull and mounted directly on the bottom of the Display Case. Display Case completed. She now resides in my Gallery and I can get back to my studio and work on my current projects the Corsaro II and the Bluenose. Cheers 🍻
  2. Mainmast continued… winches Cleats and things… Adding Striping tape for the rail… O-Rings to attach sails… Attaching Mainmast Great Shrouds… Covering the cable to turnbuckle connection with heat shrink. Great Shroud connection to the Mainmast… Tightening the Great Shrouds with the turnbuckles to align and support the Mainmast. Mainmast completed w/boom… Ready for Fore Stays and Flying Backstays. Here are few closeups of the Topping Lift, Out Haul and Sheet Lines. Looks like I need to move that sheet line block forward on the boom. Why is it you find your mistakes in front of everyone on MSW. 🙄 I’ll fix the sheet line tomorrow… Cheers 🍻
  3. Progress on the Mainmast… Mainmast shaped and first coat of paint. Adding Rail… Added sheaves for Halyard and Topping Lift… Mast cap… Winch mounts… Working on shaping Double spreader out of kit supplied 4mm x 6mm Fir. Main Boom completed… Cheers 🍻
  4. Hull ready for waterline… Her bottom will be painted red below the waterline. After taking another look at her deck, I decided she needed a redress of the deck planking. Just wasn’t satisfied with the finish. More sanding… 😆
  5. Ventilators… I replaced the kit supplied ventilators with these from Bluejacket. Carefully drilled out the Dorade Boxes Ventilators installed and the deck is now ready for installation of the Main Mast. Cheers 🍻
  6. Mizzenmast running rigging… Inspiration photo from the book “In a Class by Herself”, the Bolero Browns out for an afternoon sail. (circa 1950) This photo and lots of PMs with my friend in Montreal @rshousha , got this mizzenmast rigged. Shout out again to Rick and the lessons in seamen ship. I replaced the kit supplied wood blocks with these beauties from Bluejacket Shipcrafters @MrBlueJacket Ready to rig that Mainmast… Cheers 🍻
  7. Found some interesting research materials in the magazine rack at the grocery store.
  8. Mizzenmast… cut spreader out of 2x4 mm fir. paint booth… hardware for shroud attachments… back in the paint booth… shroud fittings w/ heat shrink… Turnbuckles fitted… backstays attached… Mizzenmast complete with shrouds and stays… Cheers 🍻
  9. I have found Acrylic products to be less toxic, although the do still have those warnings for ventilation and/or respirators. Minwax has a good line of color match wood fillers and an acrylic glazing and spot putty works for those final touch ups. John
  10. Some more carpentry performed to build the Dorade Boxes and hatch covers for the deck. Cheers 🍻
  11. Here’s a drone shot. LOL 😆 Pardon the mess, it’s how I work. 😆
  12. Deck Furnishings and Fittings complete (I think 🤔)… Dorade boxes installed waiting for Ventilators. Kudos to Rick @rshousha His support is invaluable regarding rigging, Corel “Instructions” are useless, the drawings are good. I just need technical support to understand what I am looking at so I can make sure I have everything in place to rig these mast I am about to build. Thanks Rick @Roger Pellett bought that book used that should help too. Cheers 🍻
  13. Thanks Roger… I will look into that book, sounds interesting. I am enjoying building this model, it is different than others I have completed it’s large scale certainly lends to much more attention to the details. 😎 John
  14. Yes it is beautiful… Quality is good, for the most part. Just a few adjustments needed for my own OCD. 😉
  15. Dorade Boxes… As I have said, I am not impressed with Corel’s supplied fittings and precut parts. These Dorade Boxes and Cowl Ventilators supplied in the kit are just not acceptable to me. I am replacing the Corel supplied Ventilators with fittings from Bluejacket Shipcrafters. These will look more like what I am seeing in this photo of The Corsaro in Italy. I have started building the new Dorade Boxes as I continue with the deck furnishings. Onwards 🍻
  16. Update… Ordered Cowl Ventilators from Bluejacket and began building Dorade Boxes. These should look much more appropriate. Here is the Ventilator look I am going for… 4 of 6 Dorade boxes are built… Here is a link to my Build Log. I am always looking for advice, if you are interested in following along please check It out. 😎 Cheers John
  17. Rick, I have no idea who Briggs Cunningham is, or that he invented the Destroyer Ships Wheel. 😆 All I know is I look for details that the model manufacturer has overlooked. It’s pretty easy to bash this kit. Here is a video I found on an Italian Site. https://www.nauticareport.it/dettnews/barche_e_navi_depoca/corsaro_ii_1961-4808-6020/ Very interesting video to watch the crew working the sails. It’s also a great way to pick up on those extra details. LOL Next up: I will be changing up the Cowl Ventilators to be more accurate.
  18. I want to thank you all, this has been a helpful discussion and has led me to a couple of confirmations and decisions. 1. The parts supplied by Corel have got to go. (Just wrong 😑) 2. I will eliminate the forward center ventilator and shorten that forward hatch. 3. I have ordered some Cowl vents to replace the Corel parts. 5/8” Cowl opening and an inch off the deck should be good. We will see… Onwards 🍻 John
  19. Yep… Young Buck recruits in the Italian Navy, playing tug of war with the wind.
  20. I found this video on an Italian Site. The ventilators are definitely stowed while they are underway. Makes sense… https://www.nauticareport.it/dettnews/barche_e_navi_depoca/corsaro_ii_1961-4808-6020/ Very interesting video to watch the crew working the sails.
