Jeff59
NRG Member-
Everything posted by Jeff59
Absolutely marvellous job Jolle, those ships boats are something else 😵💫 Can’t imagine how the Captain explained to the sailor where the funnel went 😂 Can remember working on the photo etch grills for funnel tops, they were fun 🤪 drove me nuts.. AWESOME job your doing 🤛
- 104 replies
- Russo-Japanese War
- Mikasa
Another stunning ship model on the way, l have the IOWA to build so shall follow this with interest. Can already see it being a beautiful model 🤛
😂 did think when l cut the bottom out, what have l done, but now fingers crossed, hope it’s going to work out, shall plod on with it, am sure it will look nice in the end 🤞Thanks Yves 🤛
Thanks Jolle , l hope it turns out okay and shows the lovely lines of what is possibly the best looking hull ever made for a warship, that’s just my opinion though, we all have our favourites. 🤛
That’ll be me for a bit, next post shall hope to have aft hull completed 👍 thanks for looking 🤛
One photo there is another person’s building and their fix on said problem of hull, this just shows how far out the hull actually is. Incidentally the small holes in the thin skin are me fixing air bubbles that have formed where liquid cement hasn’t quite caught the skin, just add a bit more cement through these holes and then fill and sand 👍 Also decided possibly to motorise propellers so have used 2mm brass rod for shafts and have purchased suitable bearings, shall put them in and take photo.
Filling out the hull between the stern keel and the outer port and starboard shaft housings is probably the hardest part of fixing the hull, theirs no quick or easy way here, you just have to build up the hull with strips of styrene and contour it till you think you’re happy, takes ages, am just about there now, shall be less difficult after this part, at least that’s what lm telling myself 😂 got some more thin styrene sheet grafted onto hull, can see it starting to change now, some more photos now.
Hello again guys, know it’s been a little while since my last posting on this build so happy to at last reached a point off progress. Try to get this in right order. Decided to split the hull even more towards stern to help with easing it apart, you need all the flex you can get to allow for increasing the hull line on the horizontal plane, think l have increased the width of hull slightly over 4mm at some points on the aft part of hull. Doesn’t sound a lot but with this and filling out the hull profile some points as much as 5mm it actually makes a nice difference to the look of the hull, certainly got rid of the long run of on the keel, on the point of the keel l had tapered it down on either side like on drawings in Seffans book , only to stumble across a photo off Tirpitz lying upside down being scraped in 1948 so changed my mind and made it full width again, makes more sense this way with construction and displacement in mind. Put some photos up to showing this.
You absolutely nailed it with the height for the 12 pounder guns on boat deck Jolle and the figures are working a treat 🤛 a little pointer as to where l was at at this stage , find the logical way to proceed with ship models is from the centre outwards and upwards so your not working over details that can easily be damaged, think if you have a look at the funnel next along with the etching details for the boat cradles, since your obviously using the Micromaster boats these sit on three cradles per boat and when positioning said boats the cradles don’t tie into the Pontos etch setup so ended up adding extra etch in to catch cradles and at the same time theses extra pieces helped with funnel rigging. Rigging, that’s another challenge to work out, old photos and common sense best way forward with this, you can possibly see the tie points and etch used for this on my build log, did mention this model isn’t as straight forward as you’d like it to be, no books or 3D drawings for this one. Hope this is off help to you. Brilliant job so far 🤛 regards Jeff.
- 104 replies
- Mikasa
It’s a lot of work at this stage of build Herby , the model becomes more and more delicate from this point. Little point to watch for that l had problems with is the actual fitting of masts to ship, the fixing point isn’t particularly strong and can easily work lose, which is rather difficult to repair once in position, guessing this isn’t suitable for this rather heavy piece of metal construction, worth having a look at for a remedy. I tell you, you do forget how much work this model actually is, doing a brilliant job. 🤛 👍
- 127 replies
- Mikasa
- Merit International
Done a lovely job on this Tim 👍 hope you are keeping well regards Jeff 🤛
- 79 replies
- Fifie
- Victory Models
Great progress on your Mikasa Herby, think everyone who completes this model should get a medal, it’s such an involved built, certainly a gem for the ones who love to work with photo etch, it’s good to watch others tackling it especially when the pain is behind me 😂 doing a splendid job Herby 🤛
- 127 replies
- Mikasa
By the way, the deck finish and texture is excellent. 🤛👍
- 104 replies
- Mikasa
Thanks Jolle, extreme ? no more than what you did with your own Bismarck model and indeed on your own Mikasa build, incidentally on that, you were puzzling over the coal scuttles in boat deck, might have some left in my second set if that could help you? Anyhow am kind of committed to this now, am sure it will make a difference, the positive side is if it works or looks good it might make manufacturers pause before putting out a hull that’s not correct on Tirpitz, l hope so cause l don’t want to do this twice 👀 🤛 Thanks for having a look 👍
Thanks Mike, think just marking of the hull for the plating would make a big difference if you’re up for that 👍 Thanks for looking in 🤛
Thanks Yves, you’re right, a ton of work, but l suppose the way lm looking at it, between the hull, deck and the first two deck structures this amounts to about half the model so know it’s going to take a while, don’t think l will get board though, shall enjoy the challenge 👍 thanks for your input 🤛
Another little solution for hull profile was this 5mm screwed rod and nuts with pipe to use as jacking system then glue in place when happy, think this shall help me as well, as it progresses, that’s me for now thanks, got a lot to be getting on with 😵💫👍
My solution to hull profile was splitting hull and forcing apart and building up outer profiles with styrene stock then dressing down the plastic till close to required shape, then when happy use thin styrene sheet to wrap on the outside of hull using liquid cement gradually forming around hull, then it’s down to filling and sanding, when satisfied it’s back to lightly engraving hull detailing back onto hull, yip, this is going to take a while 👀 on a lighter note the degaussing strip on outside of hull, 1mm half round styrene strip fitted around hull, straight out of packet, perfect , what a doddle 😂
This lets you see my reference points, next thing was to trace the hull profiles from the drawings for frames l was requiring then transfer this onto 2mm plastic styrene sheets and cut these out so l had the outer profile of hull at these points. Then it was a case of marking of the hull, this really does show a clear difference on the hull. Next stage is how do l fix this. This is were you cringe, after pondering for a while l decided best plan was to cut through hull and force hull apart till it got closer to my template, ended up with similar solution for the shaft housings for port and starboard propellers, they were totally the wrong angle, shall put some more photos up before you go daft reading this.
As you can see , had to change a few design ideas from earlier attempts as it progressed. Probably wouldn’t have went down this road if l hadn’t decided to mark off the hull detailing from Stefan Draminski’s excellent book, looking at drawings details highlighted the errors in the Trumpeter hull so have kind of been sucked into this approach on the model, not everyone is daft enough to cut their expensive model to bits, takes a certain madness 🫣🤪 Put some pictures up showing how the drawings work for hull profiles, right hand side is looking from stern starboard side, this is were I’ve started, this part being the worst part of Trumpeter hull, you can see the hull profile numbers at the top, these numbers correspond with the drawings on previous page showing their position on hull. Obviously the left hand side off this drawing shows the profiles looking from the bow starboard side 👍
Happy New Year guys, hope it was a good one for everyone 🤛 said l would post when the bottom of ship was back in place so have been quite busy, made some good progress, we’ll progress for me that is, able to dedicate a bit more time to this now being retired, wished l had retired thirty years ago, would have been on my fifth model by now 😂, anyhow, still haven’t found the model mag that highlighted the Bismarck hull being wrong, it’s not Tamiya or Fine Scale Modlers for sure, hopefully shall find it eventually. On the flat bottom, two 3mm plates made up the outer part and a further two were used to strengthen and thicken this up to add strength and required thickness. I marked of the hull plating and drilled out all holes and apertures prior to laminating both sides together, ended up quite sturdy. It was then a case of carefully dressing till it all fitted back into hull then gluing in place, hull starting to look different even with this done, shall put up some photos cause know how it can be tedious reading without these to make it interesting, like a book with pictures 😂
